Kyösti Mälkki has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/43047 )
Change subject: mb/lenovo/x230s: Add MAINBOARDS_HAS_LPC_TPM ......................................................................
With devicetree listing drivers/pc80/tpm, it is compulsory to have the corresponding driver included in the build. Followup work will drop the associated weak function declaration that util/sconfig currently generates.
Change-Id: Ife8deb2c973ab7c7b820244b6f72efd3b56570ae Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- M src/mainboard/lenovo/x230/Kconfig 1 file changed, 1 insertion(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/47/43047/1
diff --git a/src/mainboard/lenovo/x230/Kconfig b/src/mainboard/lenovo/x230/Kconfig index 39238f5..a6fdd7b 100644 --- a/src/mainboard/lenovo/x230/Kconfig +++ b/src/mainboard/lenovo/x230/Kconfig @@ -19,7 +19,7 @@ select HAVE_ACPI_RESUME select INTEL_INT15 select DRIVERS_RICOH_RCE822 - select MAINBOARD_HAS_LPC_TPM if BOARD_LENOVO_X230 || BOARD_LENOVO_X230T + select MAINBOARD_HAS_LPC_TPM select MAINBOARD_HAS_TPM1 if BOARD_LENOVO_X230 || BOARD_LENOVO_X230T select MAINBOARD_HAS_LIBGFXINIT select GFX_GMA_PANEL_1_ON_LVDS if BOARD_LENOVO_X230 || BOARD_LENOVO_X230T
Hello Alexander Couzens, Patrick Rudolph,
Change subject: mb/lenovo/x230s: Add MAINBOARD_HAS_LPC_TPM ......................................................................
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/47/43047/2
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43047 )
Patch Set 2:
a
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43047 )
Patch Set 2: Code-Review+2
Checked Rogue-1 schematics, it can have a LPC TPM.
Nico Huber has submitted this change. ( https://review.coreboot.org/c/coreboot/+/43047 )
Change-Id: Ife8deb2c973ab7c7b820244b6f72efd3b56570ae Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/43047 Reviewed-by: Angel Pons th3fanbus@gmail.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/mainboard/lenovo/x230/Kconfig 1 file changed, 1 insertion(+), 1 deletion(-)
