Tim Wawrzynczak has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/43313 )
Change subject: soc/intel/tigerlake: Move tco_configure to bootblock ......................................................................
On ChromeOS systems with a serial-enabled BIOS and vboot writing a new firmware image to the Chrome EC, it was possible for the TCO watchdog timer to trip 2 times before tco_configure() was called in romstage. This caused an extra reboot of the system (at a rather inopportune time) and because the EC didn't perform a full reset, the system boots into recovery mode.
This patch moves the call to tco_configure() for Tiger Lake from romstage to bootblock, in order to make sure the TCO watchdog timer is halted before vboot_sync_ec() runs in romstage. It should be harmless to configure the TCO device earlier in the boot flow.
BUG=b:160272400 TEST=boot Volteer (to a non-recovery kernel!) with a freshly imaged EC
Signed-off-by: Tim Wawrzynczak twawrzynczak@chromium.org Change-Id: Iefdc2c861ab8b5fde7f736c04149be7de7b3ae0c --- M src/soc/intel/tigerlake/bootblock/bootblock.c M src/soc/intel/tigerlake/romstage/pch.c 2 files changed, 4 insertions(+), 3 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/13/43313/1
diff --git a/src/soc/intel/tigerlake/bootblock/bootblock.c b/src/soc/intel/tigerlake/bootblock/bootblock.c index 54ad85a..e7d97c5 100644 --- a/src/soc/intel/tigerlake/bootblock/bootblock.c +++ b/src/soc/intel/tigerlake/bootblock/bootblock.c @@ -2,6 +2,7 @@
#include <bootblock_common.h> #include <intelblocks/systemagent.h> +#include <intelblocks/tco.h> #include <intelblocks/uart.h> #include <soc/bootblock.h>
@@ -25,4 +26,7 @@ { report_platform_info(); pch_init(); + + /* Programming TCO_BASE_ADDRESS and TCO Timer Halt */ + tco_configure(); } diff --git a/src/soc/intel/tigerlake/romstage/pch.c b/src/soc/intel/tigerlake/romstage/pch.c index e800ce5..6297dda 100644 --- a/src/soc/intel/tigerlake/romstage/pch.c +++ b/src/soc/intel/tigerlake/romstage/pch.c @@ -6,9 +6,6 @@
void pch_init(void) { - /* Programming TCO_BASE_ADDRESS and TCO Timer Halt */ - tco_configure(); - /* Program SMBUS_BASE_ADDRESS and Enable it */ smbus_common_init(); }
Aaron Durbin has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43313 )
Patch Set 1: Code-Review+2
Daisuke Nojiri has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43313 )
Patch Set 1:
https://review.coreboot.org/c/coreboot/+/43313/1/src/soc/intel/tigerlake/rom... File src/soc/intel/tigerlake/romstage/pch.c:
https://review.coreboot.org/c/coreboot/+/43313/1/src/soc/intel/tigerlake/rom... PS1, Line 4: #include <intelblocks/tco.h> Can you remove this?
Caveh Jalali has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43313 )
Hello Furquan Shaikh, Caveh Jalali, Duncan Laurie, Daisuke Nojiri, Nick Vaccaro, Aaron Durbin, Patrick Rudolph,
Signed-off-by: Tim Wawrzynczak twawrzynczak@chromium.org Change-Id: Iefdc2c861ab8b5fde7f736c04149be7de7b3ae0c --- M src/soc/intel/tigerlake/bootblock/bootblock.c M src/soc/intel/tigerlake/romstage/pch.c 2 files changed, 4 insertions(+), 4 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/13/43313/2
Tim Wawrzynczak has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43313 )
Patch Set 1:
Done
Patch Set 2: Code-Review+2
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43313 )
This should probably be done for all Intel SoCs?
Patch Set 2:
I was thinking about that, it would make things simpler and avoid the problem on other platforms. Although AFAIK we never saw this on CML.
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43313 )
Nick Vaccaro has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43313 )
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/43313 )
Signed-off-by: Tim Wawrzynczak twawrzynczak@chromium.org Change-Id: Iefdc2c861ab8b5fde7f736c04149be7de7b3ae0c Reviewed-on: https://review.coreboot.org/c/coreboot/+/43313 Reviewed-by: Daisuke Nojiri dnojiri@chromium.org Reviewed-by: Caveh Jalali caveh@chromium.org Reviewed-by: Furquan Shaikh furquan@google.com Reviewed-by: Angel Pons th3fanbus@gmail.com Reviewed-by: Nick Vaccaro nvaccaro@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/intel/tigerlake/bootblock/bootblock.c M src/soc/intel/tigerlake/romstage/pch.c 2 files changed, 4 insertions(+), 4 deletions(-)
Approvals: build bot (Jenkins): Verified Furquan Shaikh: Looks good to me, approved Daisuke Nojiri: Looks good to me, approved Nick Vaccaro: Looks good to me, approved Caveh Jalali: Looks good to me, approved Angel Pons: Looks good to me, approved
@@ -25,4 +26,7 @@ { report_platform_info(); pch_init(); + + /* Programming TCO_BASE_ADDRESS and TCO Timer Halt */ + tco_configure(); } diff --git a/src/soc/intel/tigerlake/romstage/pch.c b/src/soc/intel/tigerlake/romstage/pch.c index e800ce5..9fd8a1e 100644 --- a/src/soc/intel/tigerlake/romstage/pch.c +++ b/src/soc/intel/tigerlake/romstage/pch.c @@ -1,14 +1,10 @@ /* SPDX-License-Identifier: GPL-2.0-only */
#include <intelblocks/smbus.h> -#include <intelblocks/tco.h> #include <soc/romstage.h>
