Hello build bot (Jenkins), Nico Huber, Patrick Georgi, Paul Menzel, Jonathan Neuschäfer, Angel Pons, Denis Carikli, Werner Zeh,
https://review.coreboot.org/c/coreboot/+/40955
Change subject: payloads/external/GRUB2: prevent rebuild without actual changes ......................................................................
When the coreboot config changes, grub2 gets rebuilt, too. This is caused by Make detecting a change in the dependency on the config file.
There are two cases where grub2 needs to be rebuilt (partly):
1. Changed list of included modules (CONFIG_GRUB2_EXTRA_MODULES) In this case only the resulting binary has to be repackaged with (or without) the modules changed. This does not require a full rebuild and is intellegently handled by Make / the build system.
2. Changed grub revision or branch in coreboot config In this case grub has to be recompiled from the new sources. Fortunately all this is - again - magically handled by the build system (automake and Make, to be precise) and there is no need to influence that process from coreboot, like removing the build directory for example.
This makes it possible to reduce build times after coreboot config changes by adjusting the payload's Make targets and their dependencies and letting the build system any required (partial or full) rebuilds.
Further, this commit removes the redundant dependeny on `build/config.h` and drops the superfluous `CONFIG_DEP` make parameter.
Signed-off-by: Michael Niewöhner foss@mniewoehner.de Change-Id: Ibf5a316d0c9761426ec2ee306d78cd56d4bf19b5 --- M payloads/external/GRUB2/Makefile M payloads/external/Makefile.inc 2 files changed, 3 insertions(+), 6 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/55/40955/3
