Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/75913?usp=email )
Change subject: mb/google/brya/var/vell: update FW_config to sync config.star ......................................................................
We have found inconsistencies in turn of FW_CONFIG settings/definitions, so sync setting to vell config.star
BUG=b:282189358 BRANCH=firmware-brya-14505.B TEST=emerge-brya coreboot
Change-Id: I676b719ecc711a6f59e76465a3566bf63924d90f Signed-off-by: Shon Wang shon.wang@quanta.corp-partner.google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/75913 Reviewed-by: YH Lin yueherngl@google.com Reviewed-by: Derek Huang derekhuang@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/mainboard/google/brya/variants/vell/overridetree.cb 1 file changed, 16 insertions(+), 28 deletions(-)
Approvals: build bot (Jenkins): Verified YH Lin: Looks good to me, but someone else must approve Derek Huang: Looks good to me, approved
diff --git a/src/mainboard/google/brya/variants/vell/overridetree.cb b/src/mainboard/google/brya/variants/vell/overridetree.cb index 1100628..5298a7e 100644 --- a/src/mainboard/google/brya/variants/vell/overridetree.cb +++ b/src/mainboard/google/brya/variants/vell/overridetree.cb @@ -1,24 +1,19 @@ fw_config - field DB_SD 0 1 - option SD_ABSENT 0 - option SD_GL9750 1 + field DB_CELLULAR 0 0 + option DB_CELLULAR_ABSENT 0 + option DB_CELLULAR_PCIE 1 end - field KB_BL 2 2 - option KB_BL_ABSENT 0 - option KB_BL_PRESENT 1 + field KB_COLOR 1 1 + option KB_COLOR_WHITE 0 + option KB_COLOR_BLUE 1 end - field AUDIO 3 5 - option AUDIO_UNKNOWN 0 - option MAX98360_ALC5682I_I2S 1 - option MAX98360_ALC5682IVS_I2S 2 + field NAND 2 2 + option NAND_MICRON 0 + option NAND_KIOXIA 1 end - field DB_LTE 6 7 - option LTE_ABSENT 0 - option LTE_USB 1 - end - field EPS 10 10 - option PRIVACY_SCREEN_ABSENT 0 - option PRIVACY_SCREEN 1 + field WIFI_SAR_ID 30 31 + option WIFI_SAR_ID_0 0 + option WIFI_SAR_ID_1 1 end end chip soc/intel/alderlake @@ -97,18 +92,11 @@ device ref igpu on chip drivers/gfx/generic register "device_count" = "1" + # DDIA for eDP register "device[0].name" = ""LCD"" - # Use ChromeOS privacy screen _HID - register "device[0].hid" = ""GOOG0010"" - # Internal panel on the first port of the graphics chip - register "device[0].addr" = "0x80010400" - register "device[0].privacy.enabled" = "1" - register "device[0].privacy.gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_H21)" - device generic 0 on - probe EPS PRIVACY_SCREEN - end - end - end # Integrated Graphics Device + device generic 0 on end + end + end # Integrated Graphics Device device ref dtt on chip drivers/intel/dptf ## sensor information
