Hello Aaron Durbin, Julius Werner, Subrata Banik, Duncan Laurie, build bot (Jenkins), Kai Michaelis, Patrick Georgi, Furquan Shaikh, Amol N Sukerkar, Roy Wen, David Hendricks, Philipp Deppenwiese, Nico Huber, Martin Roth, Jens Drenhaus,
https://review.coreboot.org/c/coreboot/+/31493
Change subject: cbfstool: Add ifittool ......................................................................
Add the IntelFirmwareInterfaceTable-tool to modify the FIT. As cbfstool is overloaded with arguments, introduce a new tool to only modify FIT, which brings it's own command line syntax.
Provide clean interface to: * Clear FIT * Add entry to CBFS file * Add entry to REGION * Delete entries * Add support for types other than 1 * Add support to dump current table * Add support for top-swap * Sort entries by type
Most code is reused from existing cbfstool and functionality of cbfstool is kept. It will be removed once the make system uses only ifittool.
Based on "Intel Trusted Execution Technology (Intel TXT) LAB Handout" and https://github.com/slimbootloader/slimbootloader .
Change-Id: I0fe8cd70611d58823aca1147d5b830722ed72bd5 Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com --- M util/cbfstool/Makefile M util/cbfstool/Makefile.inc M util/cbfstool/fit.c M util/cbfstool/fit.h A util/cbfstool/ifittool.c 5 files changed, 1,096 insertions(+), 142 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/93/31493/12
