Attention is currently required from: Angel Pons, Benjamin Doron, Jean Lucas, Lean Sheng Tan, Martin L Roth, Sean Rhodes.
Hello Angel Pons, Benjamin Doron, Lean Sheng Tan, Martin L Roth, Matt DeVillier, Sean Rhodes,
https://review.coreboot.org/c/coreboot/+/82000?usp=email
Change subject: paylods/edk2: Add Kconfig to use LAPIC timer ......................................................................
GM45 / Core 2 Duo platforms have issues with HPET. Enable support to use the LAPIC driver so machines actually boot and don't hang. Tested on a Lenovo X200.
Change-Id: I33144d6c1c120e7faa47b99e8262b0997c45c9b9 Signed-off-by: Jean Lucas jean@4ray.co --- M payloads/external/Makefile.mk M payloads/external/edk2/Kconfig M payloads/external/edk2/Makefile M src/northbridge/intel/gm45/Kconfig 4 files changed, 16 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/00/82000/3
