Tim Chu has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/49347 )
Change subject: arch/x86/smbios: Update SMBIOS type 17 type detail ......................................................................
Update SMBIOS type 17 type detail. Define this field by module type.
Tested=Execute "dmidecode -t 17" to check type detail is correct.
Signed-off-by: Tim Chu Tim.Chu@quantatw.com Change-Id: I6700056edad5db2b86f6da526329b1343b026385 --- M src/arch/x86/smbios.c 1 file changed, 7 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/47/49347/1
diff --git a/src/arch/x86/smbios.c b/src/arch/x86/smbios.c index aaf989d..f1d11ba 100644 --- a/src/arch/x86/smbios.c +++ b/src/arch/x86/smbios.c @@ -303,17 +303,22 @@ case SPD_RDIMM: case SPD_MINI_RDIMM: t->form_factor = MEMORY_FORMFACTOR_RIMM; + t->type_detail = MEMORY_TYPE_DETAIL_REGISTERED; + break; + case SPD_MICRO_DIMM: + t->form_factor = MEMORY_FORMFACTOR_DIMM; break; case SPD_UDIMM: - case SPD_MICRO_DIMM: case SPD_MINI_UDIMM: t->form_factor = MEMORY_FORMFACTOR_DIMM; + t->type_detail = MEMORY_TYPE_DETAIL_UNBUFFERED; break; case SPD_SODIMM: t->form_factor = MEMORY_FORMFACTOR_SODIMM; break; default: t->form_factor = MEMORY_FORMFACTOR_UNKNOWN; + t->type_detail = MEMORY_TYPE_DETAIL_UNKNOWN; break; }
@@ -331,7 +336,7 @@ t->maximum_voltage = dimm->vdd_voltage;
/* Synchronous = 1 */ - t->type_detail = MEMORY_TYPE_DETAIL_SYNCHRONOUS; + t->type_detail |= MEMORY_TYPE_DETAIL_SYNCHRONOUS; /* no handle for error information */ t->memory_error_information_handle = 0xFFFE; t->attributes = dimm->rank_per_dimm;
