nsekar@codeaurora.org has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/30714
Change subject: mistral: qcs405: copy calibration data to CBMEM ......................................................................
This pacth adds support to copy the wifi calibration data to CBMEM so that the depthcharge can use it to populate the data into wifi dt node.
Change-Id: Ia8184e48a7176bb3b52e4d43866b7d065952c13e Signed-off-by: Nitheesh Sekar nsekar@codeaurora.org --- M src/mainboard/google/mistral/mainboard.c 1 file changed, 5 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/14/30714/1
diff --git a/src/mainboard/google/mistral/mainboard.c b/src/mainboard/google/mistral/mainboard.c index f4fc31e..3605fba 100644 --- a/src/mainboard/google/mistral/mainboard.c +++ b/src/mainboard/google/mistral/mainboard.c @@ -17,6 +17,7 @@ #include <bootblock_common.h> #include <timestamp.h> #include <soc/usb.h> +#include <vendorcode/google/chromeos/chromeos.h>
#if 0 static struct usb_board_data usb0_board_data = { @@ -46,6 +47,10 @@ static void mainboard_init(device_t dev) { setup_usb(); + if (IS_ENABLED(CONFIG_CHROMEOS)) { + /* Copy WIFI calibration data into CBMEM. */ + cbmem_add_vpd_calibration_data(); + } }
static void mainboard_enable(device_t dev)
Patrick Georgi has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/30714 )
Patch Set 14: Code-Review+1
https://review.coreboot.org/#/c/30714/14/src/mainboard/google/mistral/mainbo... File src/mainboard/google/mistral/mainboard.c:
https://review.coreboot.org/#/c/30714/14/src/mainboard/google/mistral/mainbo... PS14, Line 23: IS_ENABLED(CONFIG_CHROMEOS that's CONFIG(CHROMEOS) now
Patch Set 14:
https://review.coreboot.org/#/c/30714/14//COMMIT_MSG Commit Message:
https://review.coreboot.org/#/c/30714/14//COMMIT_MSG@9 PS14, Line 9: This pacth adds support to copy the wifi calibration "patch"
Hello build bot (Jenkins), Patrick Georgi,
This patch adds support to copy the wifi calibration data to CBMEM so that the depthcharge can use it to populate the data into wifi dt node.
Change-Id: Ia8184e48a7176bb3b52e4d43866b7d065952c13e Signed-off-by: Nitheesh Sekar nsekar@codeaurora.org --- M src/mainboard/google/mistral/mainboard.c 1 file changed, 5 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/14/30714/15
Patch Set 15: Code-Review+2
Patrick Georgi has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/30714 )
Change-Id: Ia8184e48a7176bb3b52e4d43866b7d065952c13e Signed-off-by: Nitheesh Sekar nsekar@codeaurora.org Reviewed-on: https://review.coreboot.org/c/coreboot/+/30714 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Patrick Georgi pgeorgi@google.com --- M src/mainboard/google/mistral/mainboard.c 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/src/mainboard/google/mistral/mainboard.c b/src/mainboard/google/mistral/mainboard.c index 568d486..b45657f 100644 --- a/src/mainboard/google/mistral/mainboard.c +++ b/src/mainboard/google/mistral/mainboard.c @@ -16,10 +16,14 @@ #include <device/device.h> #include <bootblock_common.h> #include <timestamp.h> +#include <vendorcode/google/chromeos/chromeos.h>
static void mainboard_init(struct device *dev) { - + if (CONFIG(CHROMEOS)) { + /* Copy WIFI calibration data into CBMEM. */ + cbmem_add_vpd_calibration_data(); + } }
static void mainboard_enable(struct device *dev)
