Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/13695
commit ca5ae7c4475e01e9a0fe13c8c32f648d4527f32d Author: Duncan Laurie dlaurie@chromium.org Date: Tue Feb 9 09:17:56 2016 -0800
FMAP: Clean up debug output
Reduce the debug output from FMAP lookups. When we had one or two FMAP lookups in a boot this was not a big deal, but now that we do many lookups it is a lot of unnecessary output duplication.
This change reduces these 3 lines:
FMAP: area VBLOCK_A found FMAP: offset: 200000 FMAP: size: 65536 bytes
To just one line:
FMAP: area VBLOCK_A found @ 200000 (65536 bytes)
And makes the header output only print once:
FMAP: Found "FMAP" version 1.0 at c10000. FMAP: base = 0 size = 1000000 #areas = 29
BUG=chrome-os-partner:40635 BRANCH=glados TEST=boot on chell and enjoy non-truncated memconsole
Change-Id: Ib5862b8bfad113a700faae89089557094aa6d499 Signed-off-by: Patrick Georgi pgeorgi@chromium.org Original-Commit-Id: 6890f36536d4ae6fc4988fc8191b0cff4e33e2e6 Original-Change-Id: Ifefee1ab26e6ee406de552880fbbd5b7916fcadd Original-Signed-off-by: Duncan Laurie dlaurie@chromium.org Original-Reviewed-on: https://chromium-review.googlesource.com/326887 Original-Reviewed-by: Aaron Durbin adurbin@chromium.org --- src/lib/fmap.c | 19 ++++++++++++------- 1 file changed, 12 insertions(+), 7 deletions(-)
diff --git a/src/lib/fmap.c b/src/lib/fmap.c index 028bc25..54e54ba 100644 --- a/src/lib/fmap.c +++ b/src/lib/fmap.c @@ -13,6 +13,7 @@ * GNU General Public License for more details. */
+#include <arch/early_variables.h> #include <boot_device.h> #include <console/console.h> #include <fmap.h> @@ -24,6 +25,8 @@ * See http://code.google.com/p/flashmap/ for more information on FMAP. */
+static int fmap_print_once CAR_GLOBAL; + int find_fmap_directory(struct region_device *fmrd) { const struct region_device *boot; @@ -50,10 +53,13 @@ int find_fmap_directory(struct region_device *fmrd) return -1; }
- printk(BIOS_DEBUG, "FMAP: Found "%s" version %d.%d at %zx.\n", - fmap->name, fmap->ver_major, fmap->ver_minor, offset); - printk(BIOS_DEBUG, "FMAP: base = %llx size = %x #areas = %d\n", - (long long)fmap->base, fmap->size, fmap->nareas); + if (!car_get_var(fmap_print_once)) { + printk(BIOS_DEBUG, "FMAP: Found "%s" version %d.%d at %zx.\n", + fmap->name, fmap->ver_major, fmap->ver_minor, offset); + printk(BIOS_DEBUG, "FMAP: base = %llx size = %x #areas = %d\n", + (long long)fmap->base, fmap->size, fmap->nareas); + car_set_var(fmap_print_once, 1); + }
fmap_size += fmap->nareas * sizeof(struct fmap_area);
@@ -97,9 +103,8 @@ int fmap_locate_area(const char *name, struct region *ar) continue; }
- printk(BIOS_DEBUG, "FMAP: area %s found\n", name); - printk(BIOS_DEBUG, "FMAP: offset: %x\n", area->offset); - printk(BIOS_DEBUG, "FMAP: size: %d bytes\n", area->size); + printk(BIOS_DEBUG, "FMAP: area %s found @ %x (%d bytes)\n", + name, area->offset, area->size);
ar->offset = area->offset; ar->size = area->size;
