Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/51678 )
Change subject: mb/google/hatch/var/genesis: Fix PCIe root ports ......................................................................
The previous "PCIe port" numbering was incorrect and resulted in several PCIe devices failing to enumerate. With lane reversal, these numbers are all backwards. This explains the confusing mapping of Clock Source #1 to Root Port #9 in https://review.coreboot.org/c/coreboot/+/50101. We were confusing "Root Port" vs "PCIe Lane".
This change addresses the port vs. lane confusion in the device tree configurations. It also adds more detailed documentation to a future reader (i.e., me) to avoid this blunder.
BUG=b:181633452,b:181635072,b:177752570 TEST=build AP firmware; flash device BRANCH=none
Change-Id: I47edf0b0af1bdcf86b89f17ad2a1f128ef9e9f7a Signed-off-by: Joe Tessler jrt@google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/51678 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Furquan Shaikh furquan@google.com --- M src/mainboard/google/hatch/variants/genesis/overridetree.cb 1 file changed, 34 insertions(+), 30 deletions(-)
diff --git a/src/mainboard/google/hatch/variants/genesis/overridetree.cb b/src/mainboard/google/hatch/variants/genesis/overridetree.cb index 20a07ca..b42ca91 100644 --- a/src/mainboard/google/hatch/variants/genesis/overridetree.cb +++ b/src/mainboard/google/hatch/variants/genesis/overridetree.cb @@ -182,42 +182,43 @@ }, }"
- # PCIe port 7 for LAN + # PCIe root port 7 for LAN register "PcieRpEnable[6]" = "1" register "PcieRpLtrEnable[6]" = "1" # Uses CLK SRC 0 register "PcieClkSrcUsage[0]" = "6" register "PcieClkSrcClkReq[0]" = "0"
- # PCIe port 8 for WLAN + # PCIe root port 8 for WLAN register "PcieRpEnable[7]" = "1" register "PcieRpLtrEnable[7]" = "1" # Uses CLK SRC 5 register "PcieClkSrcUsage[5]" = "7" register "PcieClkSrcClkReq[5]" = "5"
- # PCIe port 9 for TPU #0 + # PCIe root port 9 for SSD (PCIe Lanes 11, 12) register "PcieRpEnable[8]" = "1" register "PcieRpLtrEnable[8]" = "1" - # RP 9 uses CLK SRC 2 - register "PcieClkSrcUsage[2]" = "8" - register "PcieClkSrcClkReq[2]" = "2" + # RP 9 uses CLK SRC 1 + register "PcieClkSrcUsage[1]" = "8" + register "PcieClkSrcClkReq[1]" = "1"
- # PCIe port 10 for TPU #1 - register "PcieRpEnable[9]" = "1" - register "PcieRpLtrEnable[9]" = "1" - # RP 10 uses CLK SRC 4 - register "PcieClkSrcUsage[4]" = "9" - register "PcieClkSrcClkReq[4]" = "4" + # PCIe root port 10 disabled + register "PcieRpEnable[9]" = "0"
- # PCIe port 11 (x2) for NVMe hybrid storage devices + # PCIe root port 11 TPU1 register "PcieRpEnable[10]" = "1" register "PcieRpLtrEnable[10]" = "1" # RP 11 uses CLK SRC 1 - register "PcieClkSrcUsage[1]" = "10" - register "PcieClkSrcClkReq[1]" = "1" - # Disable the remaining port 12 - register "PcieRpEnable[11]" = "0" + register "PcieClkSrcUsage[4]" = "10" + register "PcieClkSrcClkReq[4]" = "4" + + # PCIe root port 12 TPU0 + register "PcieRpEnable[11]" = "1" + register "PcieRpLtrEnable[11]" = "1" + # RP 11 uses CLK SRC 1 + register "PcieClkSrcUsage[2]" = "11" + register "PcieClkSrcClkReq[2]" = "2"
# PCIe port 13 for i350 NIC (x4) register "PcieRpEnable[12]" = "1" @@ -225,6 +226,9 @@ # RP 13 uses CLK SRC 3 register "PcieClkSrcUsage[3]" = "12" # RP 13 does not use a source clock request line + # NOTE: Any value other than a valid source-clock-request (0-5) is + # effectively "not connected" + register "PcieClkSrcClkReq[3]" = "0xFF" # Disable the remaining ports 14-16 register "PcieRpEnable[13]" = "0" register "PcieRpEnable[14]" = "0" @@ -415,8 +419,8 @@ device i2c 1a on end end end #I2C #4 - device pci 1a.0 on end # eMMC - device pci 1c.6 on # PCI Express Port 7 (LAN) + device pci 1a.0 off end # eMMC + device pci 1c.6 on # PCI Root Port 7 (LAN) chip drivers/net # RTL8111H Ethernet NIC register "customized_leds" = "0x05af" register "wake" = "GPE0_DW1_07" # GPP_C7 @@ -428,23 +432,23 @@ device pci 00.0 on end end end - device pci 1c.7 on # PCI Express Port 8 (WLAN) + device pci 1c.7 on # PCI Root Port 8 (WLAN) register "PcieRpSlotImplemented[7]" = "1" # M.2 Slot end - device pci 1d.0 on # PCI Express Port 9 (TPU) + device pci 1d.0 on # PCI Root Port 9 (TPU) register "PcieRpSlotImplemented[8]" = "1" # M.2 Slot end - device pci 1d.1 on # PCI Express Port 10 (TPU) - register "PcieRpSlotImplemented[9]" = "1" # M.2 Slot - end - device pci 1d.2 on end # PCI Express Port 11 (X2 NVMe) - device pci 1d.3 off end # PCI Express Port 12 (non-root) - device pci 1d.4 on # PCI Express Port 13 (X4 i350 NIC) + device pci 1d.1 off end # PCI Root Port 10 (Not connected) + device pci 1d.2 on end # PCI Root Port 11 (TPU1) + register "PcieRpSlotImplemented[10]" = "1" # M.2 Slot + device pci 1d.3 on end # PCI Root Port 12 (TPU0) + register "PcieRpSlotImplemented[11]" = "1" # M.2 Slot + device pci 1d.4 on # PCI Root Port 13 (X4 i350 NIC) register "PcieRpSlotImplemented[12]" = "0" # Built-in end - device pci 1d.5 off end # PCI Express Port 14 (non-root) - device pci 1d.6 off end # PCI Express Port 15 (non-root) - device pci 1d.7 off end # PCI Express Port 16 (non-root) + device pci 1d.5 on end # PCI Root Port 14 (non-root) + device pci 1d.6 on end # PCI Root Port 15 (non-root) + device pci 1d.7 on end # PCI Root Port 16 (non-root) device pci 1e.3 off end # GSPI #1 end
