Chen Wisley has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/36098 )
Change subject: mb/google/hatch/var/dratini: Update DPTF parameters ......................................................................
The change applies the DPTF parameters.
BUG=b:142849037 TEST=build and verified by thermal team
Change-Id: I5da8d373f38d23929ffec95bc1c9e942f131297f Signed-off-by: Wisley Chen wisley.chen@quantatw.com --- M src/mainboard/google/hatch/variants/dratini/include/variant/acpi/dptf.asl 1 file changed, 106 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/98/36098/1
diff --git a/src/mainboard/google/hatch/variants/dratini/include/variant/acpi/dptf.asl b/src/mainboard/google/hatch/variants/dratini/include/variant/acpi/dptf.asl index 31f72b3..0281913 100644 --- a/src/mainboard/google/hatch/variants/dratini/include/variant/acpi/dptf.asl +++ b/src/mainboard/google/hatch/variants/dratini/include/variant/acpi/dptf.asl @@ -1,7 +1,7 @@ /* * This file is part of the coreboot project. * - * Copyright (C) 2019 Intel Corporation. + * Copyright 2019 Google LLC * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by @@ -13,4 +13,108 @@ * GNU General Public License for more details. */
-#include <baseboard/acpi/dptf.asl> +#define DPTF_CPU_PASSIVE 90 +#define DPTF_CPU_CRITICAL 105 +#define DPTF_CPU_ACTIVE_AC0 91 +#define DPTF_CPU_ACTIVE_AC1 85 +#define DPTF_CPU_ACTIVE_AC2 78 +#define DPTF_CPU_ACTIVE_AC3 71 +#define DPTF_CPU_ACTIVE_AC4 64 + +#define DPTF_TSR0_SENSOR_ID 0 +#define DPTF_TSR0_SENSOR_NAME "Thermal Sensor - Charger" +#define DPTF_TSR0_PASSIVE 65 +#define DPTF_TSR0_CRITICAL 85 + +#define DPTF_TSR1_SENSOR_ID 1 +#define DPTF_TSR1_SENSOR_NAME "Thermal Sensor - 5V" +#define DPTF_TSR1_PASSIVE 45 +#define DPTF_TSR1_CRITICAL 75 +#define DPTF_TSR1_ACTIVE_AC0 51 +#define DPTF_TSR1_ACTIVE_AC1 48 +#define DPTF_TSR1_ACTIVE_AC2 45 +#define DPTF_TSR1_ACTIVE_AC3 42 +#define DPTF_TSR1_ACTIVE_AC4 39 +#define DPTF_TSR1_ACTIVE_AC5 36 +#define DPTF_TSR1_ACTIVE_AC6 33 + +#define DPTF_ENABLE_CHARGER +#define DPTF_ENABLE_FAN_CONTROL + +/* Charger performance states, board-specific values from charger and EC */ +Name (CHPS, Package () { + Package () { 0, 0, 0, 0, 255, 0x6a4, "mA", 0 }, /* 1.7A (MAX) */ + Package () { 0, 0, 0, 0, 24, 0x600, "mA", 0 }, /* 1.5A */ + Package () { 0, 0, 0, 0, 16, 0x400, "mA", 0 }, /* 1.0A */ + Package () { 0, 0, 0, 0, 8, 0x200, "mA", 0 }, /* 0.5A */ +}) + +/* DFPS: Fan Performance States */ +Name (DFPS, Package () { + 0, // Revision + /* + * TODO : Need to update this Table after characterization. + * These are initial reference values. + */ + /* Control, Trip Point, Speed, NoiseLevel, Power */ + Package () {90, 0xFFFFFFFF, 6700, 220, 2200}, + Package () {80, 0xFFFFFFFF, 5800, 180, 1800}, + Package () {70, 0xFFFFFFFF, 5000, 145, 1450}, + Package () {60, 0xFFFFFFFF, 4900, 115, 1150}, + Package () {50, 0xFFFFFFFF, 3838, 90, 900}, + Package () {40, 0xFFFFFFFF, 2904, 55, 550}, + Package () {30, 0xFFFFFFFF, 2337, 30, 300}, + Package () {20, 0xFFFFFFFF, 1608, 15, 150}, + Package () {10, 0xFFFFFFFF, 800, 10, 100}, + Package () {0, 0xFFFFFFFF, 0, 0, 50} +}) + +Name (DART, Package () { + /* Fan effect on CPU */ + 0, // Revision + Package () { + /* + * Source, Target, Weight, AC0, AC1, AC2, AC3, AC4, AC5, AC6, + * AC7, AC8, AC9 + */ + _SB.DPTF.TFN1, _SB.PCI0.TCPU, 100, 90, 60, 50, 40, 30, 0, 0, + 0, 0, 0 + }, + Package () { + _SB.DPTF.TFN1, _SB.DPTF.TSR1, 100, 100, 80, 70, 60, 50, 40, 30, + 0, 0, 0 + }, +}) + +Name (DTRT, Package () { + /* CPU Throttle Effect on CPU */ + Package () { _SB.PCI0.TCPU, _SB.PCI0.TCPU, 100, 50, 0, 0, 0, 0 }, + + /* Charger Throttle Effect on Charger (TSR0) */ + Package () { _SB.DPTF.TCHG, _SB.DPTF.TSR0, 100, 60, 0, 0, 0, 0 }, + + /* CPU Throttle Effect on CPU (TSR1) */ + Package () { _SB.PCI0.TCPU, _SB.DPTF.TSR1, 100, 60, 0, 0, 0, 0 }, + +}) + +Name (MPPC, Package () +{ + 0x2, /* Revision */ + Package () { /* Power Limit 1 */ + 0, /* PowerLimitIndex, 0 for Power Limit 1 */ + 3000, /* PowerLimitMinimum */ + 15000, /* PowerLimitMaximum */ + 28000, /* TimeWindowMinimum */ + 32000, /* TimeWindowMaximum */ + 200 /* StepSize */ + }, + Package () { /* Power Limit 2 */ + 1, /* PowerLimitIndex, 1 for Power Limit 2 */ + 15000, /* PowerLimitMinimum */ + 25000, /* PowerLimitMaximum */ + 28000, /* TimeWindowMinimum */ + 32000, /* TimeWindowMaximum */ + 1000 /* StepSize */ + } +})
Paul Fagerburg has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/36098 )
Patch Set 1: Code-Review+1
Tim Wawrzynczak has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/36098 )
Patch Set 1: Code-Review+2
https://review.coreboot.org/c/coreboot/+/36098/1/src/mainboard/google/hatch/... File src/mainboard/google/hatch/variants/dratini/include/variant/acpi/dptf.asl:
https://review.coreboot.org/c/coreboot/+/36098/1/src/mainboard/google/hatch/... PS1, Line 96: /* CPU Throttle Effect on CPU (TSR1) */ : Package () { _SB.PCI0.TCPU, _SB.DPTF.TSR1, 100, 60, 0, 0, 0, 0 }, Just to make sure, you want the 5V thermal sensor to throttle CPU as if it's the CPU thermal sensor? I haven't looked at the layout.
Wisley Chen has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/36098 )
Patch Set 1:
Just to make sure, you want the 5V thermal sensor to throttle CPU as if it's the CPU thermal sensor? […]
yes, 5V thermal sensor to throttle CPU for safety requirement.
Patch Set 1:
Ack
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/36098 )
Change-Id: I5da8d373f38d23929ffec95bc1c9e942f131297f Signed-off-by: Wisley Chen wisley.chen@quantatw.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/36098 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Paul Fagerburg pfagerburg@chromium.org Reviewed-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/mainboard/google/hatch/variants/dratini/include/variant/acpi/dptf.asl 1 file changed, 106 insertions(+), 2 deletions(-)
Approvals: build bot (Jenkins): Verified Tim Wawrzynczak: Looks good to me, approved Paul Fagerburg: Looks good to me, but someone else must approve
