Attention is currently required from: Angel Pons, Jan Philipp Groß, Nicholas Chin.
Hello Angel Pons, Nicholas Chin, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/84672?usp=email
The following approvals got outdated and were removed: Code-Review+1 by Angel Pons, Verified+1 by build bot (Jenkins)
Change subject: mb/asrock: Add Z87 Extreme4 (Haswell) ......................................................................
This port was done via autoport and subsequent manual tweaking.
The board features two socketed DIP-8 SPI flash chips, as well as a BIOS selection via jumper and onboard Power and Reset switches.
Working: - Haswell MRC.bin - All four DDR3/DDR3L DIMM slots - HDMI-Out Port - DVI-D Port - RJ-45 Gigabit LAN Port - Both USB 2.0 Ports - All four USB 3.1 Gen1 Ports - Both USB 3.1 Gen1 headers - Vertical Type A USB 3.1 Gen1 (located next to RAM slots and PCH) - All six SATA3 6.0 Gb/s connectors by Intel - All three PCI Express 3.0 x16 slots (tested with NV 1080 Ti dGPU) - Both PCI Express 2.0 x1 slots (tested with TL-WDN4800 WiFi adapter) - HD Audio Jack (Audio output tested only) - Front Audio Jack (Audio output tested only)
Working (board-specific) - Power Switch with LED (functional, yet no LED) - Reset Switch with LED (functional, yet no LED) - BIOS Selection via jumper
not working: - both SATA3 6.0 Gb/s connectors by ASMedia ASM1061
not (yet) tested: - IR header - COM Port header - DisplayPort - eSATA connector - USB 2.0 headers - PS/2 Mouse/Keyboard Port - HDMI-In Port - PCI slots
not (yet) working: - Software fan control: While the Nuvoton chip is correctly discovered, the numbering of the fan connectors is faulty, resulting in the wrong fan being controlled. - Dr. Debug: on vendor firmware, the LEDs turn off after successful boot. On coreboot, the LED shows two bright zeros after boot.
Change-Id: I78791aa9877a3ad79bf8b896c583fedf37e96d9a Signed-off-by: Jan Philipp Groß jeangrande@mailbox.org --- A src/mainboard/asrock/z87_extreme4/Kconfig A src/mainboard/asrock/z87_extreme4/Kconfig.name A src/mainboard/asrock/z87_extreme4/Makefile.mk A src/mainboard/asrock/z87_extreme4/acpi/ec.asl A src/mainboard/asrock/z87_extreme4/acpi/platform.asl A src/mainboard/asrock/z87_extreme4/acpi/superio.asl A src/mainboard/asrock/z87_extreme4/board_info.txt A src/mainboard/asrock/z87_extreme4/bootblock.c A src/mainboard/asrock/z87_extreme4/data.vbt A src/mainboard/asrock/z87_extreme4/devicetree.cb A src/mainboard/asrock/z87_extreme4/dsdt.asl A src/mainboard/asrock/z87_extreme4/gma-mainboard.ads A src/mainboard/asrock/z87_extreme4/gpio.c A src/mainboard/asrock/z87_extreme4/hda_verb.c A src/mainboard/asrock/z87_extreme4/romstage.c 15 files changed, 531 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/72/84672/3
