Patrick Georgi (patrick@georgi-clan.de) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/4546
commit 7069516c6035617ef01c2da395f65d65b0e0b09d Author: Patrick Georgi patrick@georgi-clan.de Date: Sat Dec 21 11:02:14 2013 +0100
armv7: Prepare tables code for dynamic CBMEM
The CBMEM API is different for dynamic CBMEM, so hide the functions that get in the way (but our compiler complains about)
Change-Id: I7634a202059548e56c74fe3fe6eff57bc60f1a1b Signed-off-by: Patrick Georgi patrick@georgi-clan.de --- src/arch/armv7/tables.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/src/arch/armv7/tables.c b/src/arch/armv7/tables.c index b566ff6..cf4e4e0 100644 --- a/src/arch/armv7/tables.c +++ b/src/arch/armv7/tables.c @@ -29,12 +29,14 @@
#define MAX_COREBOOT_TABLE_SIZE (8 * 1024)
+#if !CONFIG_DYNAMIC_CBMEM void __attribute__((weak)) get_cbmem_table(uint64_t *base, uint64_t *size) { printk(BIOS_WARNING, "WARNING: you need to define get_cbmem_table for your board\n"); *base = 0; *size = 0; } +#endif
void cbmem_arch_init(void) { @@ -44,7 +46,9 @@ struct lb_memory *write_tables(void) { unsigned long table_pointer, new_table_pointer;
+#if !CONFIG_DYNAMIC_CBMEM cbmem_base_check(); +#endif
post_code(0x9d);
