Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/60117 )
Change subject: soc/amd/common/include/spi: add Cezanne-specific comment ......................................................................
The Cezanne PPR #56569 Rev 3.03 has one more SPI FIFO bytes defined compared to the previous generations. It is unclear if adding some special handling for Cezanne would be worth the effort, since the current code just doesn't use the last byte which should be safe to do, since this only affects the maximum number of bytes that can be used for one SPI transaction. Having another byte to use on Cezanne wouldn't reduce the number of SPI transactions to write a 256 byte data block.
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: Ic730f4fe838f59066120c811833995c132c84c1c Reviewed-on: https://review.coreboot.org/c/coreboot/+/60117 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Raul Rangel rrangel@chromium.org --- M src/soc/amd/common/block/include/amdblocks/spi.h 1 file changed, 1 insertion(+), 1 deletion(-)
Approvals: build bot (Jenkins): Verified Raul Rangel: Looks good to me, approved
diff --git a/src/soc/amd/common/block/include/amdblocks/spi.h b/src/soc/amd/common/block/include/amdblocks/spi.h index 4efed68..4be3739 100644 --- a/src/soc/amd/common/block/include/amdblocks/spi.h +++ b/src/soc/amd/common/block/include/amdblocks/spi.h @@ -71,7 +71,7 @@ #define SPI_RD4DW_EN_HOST BIT(15)
#define SPI_FIFO 0x80 -#define SPI_FIFO_LAST_BYTE 0xc6 +#define SPI_FIFO_LAST_BYTE 0xc6 /* 0xc7 for Cezanne */ #define SPI_FIFO_DEPTH (SPI_FIFO_LAST_BYTE - SPI_FIFO + 1)
struct spi_config {
