Martin L Roth has submitted this change. ( https://review.coreboot.org/c/coreboot/+/69201 )
Change subject: device & commonlib: Update pci_scan_bus postcodes ......................................................................
The function pci_scan_bus had 3 post codes in it: 0x24 - beginning 0x25 - middle 0x55 - end
I got rid of the middle postcode and used 0x25 for the code signifying the end of the function. I don't think all three are needed.
0x24 & 0x25 postcodes are currently also used in intel cache-as-ram code. Those postcodes should be adjusted to avoid conflicting.
Signed-off-by: Martin Roth gaumless@gmail.com Change-Id: I19c9d5e256505b64234919a99f73a71efbbfdae3 Reviewed-on: https://review.coreboot.org/c/coreboot/+/69201 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Elyes Haouas ehaouas@noos.fr Reviewed-by: Angel Pons th3fanbus@gmail.com --- M src/commonlib/include/commonlib/console/post_codes.h M src/device/pci_device.c 2 files changed, 41 insertions(+), 4 deletions(-)
Approvals: build bot (Jenkins): Verified Elyes Haouas: Looks good to me, approved Angel Pons: Looks good to me, approved
diff --git a/src/commonlib/include/commonlib/console/post_codes.h b/src/commonlib/include/commonlib/console/post_codes.h index 8ab069b..d838815 100644 --- a/src/commonlib/include/commonlib/console/post_codes.h +++ b/src/commonlib/include/commonlib/console/post_codes.h @@ -66,6 +66,20 @@ #define POST_ENTRY_C_START 0x13
/** + * \brief Entry into pci_scan_bus + * + * Entered pci_scan_bus() + */ +#define POST_ENTER_PCI_SCAN_BUS 0x24 + +/** + * \brief Entry into pci_scan_bus + * + * Entered pci_scan_bus() + */ +#define POST_EXIT_PCI_SCAN_BUS 0x25 + +/** * \brief Pre-memory init preparation start * * Post code emitted in romstage before making callbacks to allow SoC/mainboard diff --git a/src/device/pci_device.c b/src/device/pci_device.c index 16c31ea..8651586 100644 --- a/src/device/pci_device.c +++ b/src/device/pci_device.c @@ -1423,7 +1423,7 @@ max_devfn=0xff; }
- post_code(0x24); + post_code(POST_ENTER_PCI_SCAN_BUS);
if (pci_bus_only_one_child(bus)) max_devfn = MIN(max_devfn, 0x07); @@ -1464,8 +1464,6 @@ } }
- post_code(0x25); - /* * Warn if any leftover static devices are found. * There's probably a problem in devicetree.cb. @@ -1516,7 +1514,7 @@ * side of any bridges that may be on this bus plus any devices. * Return how far we've got finding sub-buses. */ - post_code(0x55); + post_code(POST_EXIT_PCI_SCAN_BUS); }
typedef enum {
