Angel Pons has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/58904 )
Change subject: mb/prodrive/hermes: Rename "internal audio" setting ......................................................................
The "internal audio connection" setting is actually about the front panel audio. Rename functions and variables to reflect this.
Change-Id: I1be8f68ac3e8b91bc4983dc06daa37afb7bdf926 Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/mainboard/prodrive/hermes/mainboard.c M src/mainboard/prodrive/hermes/variants/baseboard/include/eeprom.h M src/mainboard/prodrive/hermes/variants/r04/hda_verb.c 3 files changed, 6 insertions(+), 6 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/04/58904/1
diff --git a/src/mainboard/prodrive/hermes/mainboard.c b/src/mainboard/prodrive/hermes/mainboard.c index a9c8408..6ae6b89 100644 --- a/src/mainboard/prodrive/hermes/mainboard.c +++ b/src/mainboard/prodrive/hermes/mainboard.c @@ -138,7 +138,7 @@ return;
/* Enable internal speaker amplifier */ - if (board_cfg->internal_audio_connection == 2) + if (board_cfg->front_panel_audio == 2) mb_hda_amp_enable(1); else mb_hda_amp_enable(0); diff --git a/src/mainboard/prodrive/hermes/variants/baseboard/include/eeprom.h b/src/mainboard/prodrive/hermes/variants/baseboard/include/eeprom.h index 9ec4604..0d4e9d8 100644 --- a/src/mainboard/prodrive/hermes/variants/baseboard/include/eeprom.h +++ b/src/mainboard/prodrive/hermes/variants/baseboard/include/eeprom.h @@ -47,7 +47,7 @@ uint8_t usb_powered_in_s5; uint8_t power_state_after_g3; uint8_t blue_rear_vref; - uint8_t internal_audio_connection; + uint8_t front_panel_audio; uint8_t pxe_boot_capability; }; uint8_t raw_settings[9]; diff --git a/src/mainboard/prodrive/hermes/variants/r04/hda_verb.c b/src/mainboard/prodrive/hermes/variants/r04/hda_verb.c index f9a3cb3..b4a3370 100644 --- a/src/mainboard/prodrive/hermes/variants/r04/hda_verb.c +++ b/src/mainboard/prodrive/hermes/variants/r04/hda_verb.c @@ -30,9 +30,9 @@ } }
-static u32 get_internal_audio_cfg(uint8_t internal_audio_connection) +static u32 get_front_panel_cfg(uint8_t front_panel_audio) { - switch (internal_audio_connection) { + switch (front_panel_audio) { default: case 0: return AZALIA_PIN_CFG_NC(0); @@ -62,10 +62,10 @@ if (!board_cfg) return;
- const u32 config = get_internal_audio_cfg(board_cfg->internal_audio_connection); + const u32 front_panel_cfg = get_front_panel_cfg(board_cfg->front_panel_audio);
const u32 verbs[] = { - AZALIA_PIN_CFG(0, 0x1b, config), + AZALIA_PIN_CFG(0, 0x1b, front_panel_cfg), 0x0205000d, /* Pin 37 vrefo hidden register - used as port C vref */ get_port_c_vref_cfg(board_cfg->blue_rear_vref), };
