Kyösti Mälkki has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/48499 )
Change subject: arch/x86: Move .id section higher ......................................................................
The (now removed) ID_SECTION_OFFSET=0x80 was actually the secondary address flashrom and FILO are looking for. The primary was 0x10, just below .reset.
If .id does not collide with .fit_pointer, use the higher of the two locations.
Change-Id: I0d3a58c82efd3bbf94f4bc80ec5bbc97d5b1c109 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- M src/arch/x86/bootblock.ld 1 file changed, 5 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/99/48499/1
diff --git a/src/arch/x86/bootblock.ld b/src/arch/x86/bootblock.ld index ad9c2ef..3a4dae7 100644 --- a/src/arch/x86/bootblock.ld +++ b/src/arch/x86/bootblock.ld @@ -19,14 +19,17 @@ .id (.): { KEEP(*(.id)); } - _ID_SECTION = 0xffffff80 - SIZEOF(.id); + _ID_SECTION_END = SIZEOF(.fit_pointer) && SIZEOF(.id) > 0x28 ? 0xffffff80 : _X86_RESET_VECTOR; + _ID_SECTION = _ID_SECTION_END - SIZEOF(.id);
- . = 0xffffffc0; + . = _FIT_POINTER; .fit_pointer (.): { KEEP(*(.fit_pointer)); } + _FIT_POINTER = SIZEOF(.fit_pointer) ? 0xffffffc0 : _X86_RESET_VECTOR;
. = 0xfffffff0; + _X86_RESET_VECTOR = .; .reset . : { *(.reset); . = 15;
Arthur Heymans has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/48499 )
Patch Set 2: Code-Review+2
https://review.coreboot.org/c/coreboot/+/48499/2/src/arch/x86/bootblock.ld File src/arch/x86/bootblock.ld:
https://review.coreboot.org/c/coreboot/+/48499/2/src/arch/x86/bootblock.ld@2... PS2, Line 22: _ID_SECTION_END = SIZEOF(.fit_pointer) && SIZEOF(.id) > 0x28 ? 0xffffff80 : _X86_RESET_VECTOR; : _ID_SECTION = _ID_SECTION_END - SIZEOF(.id); Would it make sense to document this primary/secondary ID section offset here?
Hello build bot (Jenkins), Nico Huber, Julius Werner, Arthur Heymans,
Change-Id: I0d3a58c82efd3bbf94f4bc80ec5bbc97d5b1c109 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- M src/arch/x86/bootblock.ld 1 file changed, 7 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/99/48499/3
Kyösti Mälkki has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/48499 )
Patch Set 3:
Done
Patch Set 3: Code-Review+2
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/48499 )
Change-Id: I0d3a58c82efd3bbf94f4bc80ec5bbc97d5b1c109 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/48499 Reviewed-by: Arthur Heymans arthur@aheymans.xyz Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/arch/x86/bootblock.ld 1 file changed, 7 insertions(+), 2 deletions(-)
Approvals: build bot (Jenkins): Verified Arthur Heymans: Looks good to me, approved
diff --git a/src/arch/x86/bootblock.ld b/src/arch/x86/bootblock.ld index ad9c2ef..479259f 100644 --- a/src/arch/x86/bootblock.ld +++ b/src/arch/x86/bootblock.ld @@ -19,14 +19,19 @@ .id (.): { KEEP(*(.id)); } - _ID_SECTION = 0xffffff80 - SIZEOF(.id);
- . = 0xffffffc0; + /* Flashrom and FILO have two alternatives for the location of .id section. */ + _ID_SECTION_END = SIZEOF(.fit_pointer) && SIZEOF(.id) > 0x28 ? 0xffffff80 : _X86_RESET_VECTOR; + _ID_SECTION = _ID_SECTION_END - SIZEOF(.id); + + . = _FIT_POINTER; .fit_pointer (.): { KEEP(*(.fit_pointer)); } + _FIT_POINTER = SIZEOF(.fit_pointer) ? 0xffffffc0 : _X86_RESET_VECTOR;
