Attention is currently required from: Nico Huber, Patrick Rudolph, Angel Pons, Julius Werner, Arthur Heymans. Hello build bot (Jenkins), Nico Huber, Patrick Rudolph, Julius Werner, Angel Pons,
https://review.coreboot.org/c/coreboot/+/52879
Change subject: arch/x86/walkcbfs.S: Use FMAP instead of "cbfs master header" ......................................................................
Tested on qemu/i440fx on X86_64: - Page tables are found in cbfs (finding a file works) - returns 0 when a file is not found - works when there is no cbfs file at the start of the FMAP, e.g. with the cbfs master header removed.
Change-Id: Ibab657cc40cd5c09c3a73c54950b98ac45a98dbf Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M src/arch/x86/Makefile.inc M src/arch/x86/walkcbfs.S 2 files changed, 6 insertions(+), 25 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/79/52879/5
