Attention is currently required from: Dinesh Gehlot, Eran Mitrani, Jakub Czapiga, Kapil Porwal, Subrata Banik, Tarun.
Hello Dinesh Gehlot, Eran Mitrani, Jakub Czapiga, Kapil Porwal, Tarun, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/80664?usp=email
The following approvals got outdated and were removed: Code-Review+2 by Kapil Porwal, Verified+1 by build bot (Jenkins)
The change is no longer submittable: Code-Review and Verified are unsatisfied now.
Change subject: mb/google/rex/var/deku: Refactor SSD power sequencing ......................................................................
Improve SSD readiness time by enabling earlier power sequencing.
Here are the two GPIOs to look for: * GPP_A19: Power Enable * GPP_A20: PERST
The flow is presented as `stage (GPIO PAD/Value)` for easy understanding:
bootblock (A20/0, A19/1) | v romstage (A20/1)
Ideally, we don't need SSD power sequencing at ramstage, hence, remove the logic from ramstage.
TEST=Able to build and boot google/deku using NVMe without any problems. S0ix and read/write from/to SSD are also normal.
Change-Id: Iedaff8a793f1ba5d2b97352b95c4dfdd2b818ebd Signed-off-by: Subrata Banik subratabanik@google.com --- M src/mainboard/google/rex/variants/deku/gpio.c 1 file changed, 6 insertions(+), 7 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/64/80664/2
