John Su has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/85448?usp=email )
Change subject: mb/google/brya/var/uldrenite: Add HDA verb tables ......................................................................
We use ALC3204 as HDA codec on uldrenite, add the verb table.
BUG=b:374203133 TEST=emerge-nissa coreboot
Change-Id: Ie9d0e17e1ab13adc8aea0d5bcbbe44785a137d7b Signed-off-by: John Su john_su@compal.corp-partner.google.com --- A src/mainboard/google/brya/variants/uldrenite/hda_verb.c 1 file changed, 160 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/48/85448/1
diff --git a/src/mainboard/google/brya/variants/uldrenite/hda_verb.c b/src/mainboard/google/brya/variants/uldrenite/hda_verb.c new file mode 100644 index 0000000..f56cd70 --- /dev/null +++ b/src/mainboard/google/brya/variants/uldrenite/hda_verb.c @@ -0,0 +1,160 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <device/azalia_device.h> + +const u32 cim_verb_data[] = { + /* coreboot specific header */ + 0x10ec0236, //Codec Vendor / Device ID: Realtek ALC3204 + 0x10280D76, // Subsystem ID + 0x00000021, // Number of jacks (NID entries) + + AZALIA_RESET(0x1), + /* NID 0x01, HDA Codec Subsystem ID Verb table */ + AZALIA_SUBVENDOR(0, 0x10280D76), + + /* Pin Widget Verb Table */ + /* + * DMIC + * Requirement is to use PCH DMIC. Hence, + * commented out codec's Internal DMIC. + * AZALIA_PIN_CFG(0, 0x12, 0x90A60130), + * AZALIA_PIN_CFG(0, 0x13, 0x40000000), + */ + AZALIA_PIN_CFG(0, 0x12, 0x90a60140), + AZALIA_PIN_CFG(0, 0x13, 0x40000000), + AZALIA_PIN_CFG(0, 0x14, 0x90170110), + AZALIA_PIN_CFG(0, 0x18, 0x411111f0), + AZALIA_PIN_CFG(0, 0x19, 0x02a11030), + AZALIA_PIN_CFG(0, 0x1a, 0x411111f0), + AZALIA_PIN_CFG(0, 0x1b, 0x411111f0), + AZALIA_PIN_CFG(0, 0x1d, 0x40700001), + AZALIA_PIN_CFG(0, 0x1e, 0x421212f2), + AZALIA_PIN_CFG(0, 0x21, 0x02211020), + + /* RESET to D0 */ + 0x00170500, + 0x00170500, + 0x00170500, + 0x00170500, + /* RESET Register */ + 0x0205001A, + 0x02048003, + 0x0205001A, + 0x0204C003, + /* ALC3204 default-1(Class D RESET) */ + 0x0205003C, + 0x02040354, + 0x0205003C, + 0x02040314, + /* ALC3204 default-2 (Tco) */ + 0x02050040, + 0x02049800, + 0x02050034, + 0x0204023C, + /* ALC3204 Speaker output power - 4 ohm 2W (+12dB gain) + * + Combo Jack TRS setting */ + 0x02050038, + 0x02043901, + 0x02050045, + 0x02045089, + /* H/W AGC setting-1 */ + 0x02050016, + 0x02040C50, + 0x02050012, + 0x0204EBC2, + /* H/W AGC setting-2 */ + 0x02050013, + 0x0204401D, + 0x02050016, + 0x02044E50, + /* Zero data + EAPD to verb-control */ + 0x02050037, + 0x0204FE15, + 0x02050010, + 0x02040020, + /* Zero data */ + 0x02050030, + 0x02048000, + 0x02050030, + 0x02048000, + /* ALC3204 default-3 */ + 0x05750003, + 0x05740DA3, + 0x02050046, + 0x02040004, + /* ALC3204 default-4 */ + 0x0205001B, + 0x02040A4B, + 0x02050008, + 0x02046A4C, + /* JD1 */ + 0x02050009, + 0x0204E003, + 0x0205000A, + 0x02047770, + /* JD2 */ + 0x0205000B, + 0x02047778, + 0x0205000B, + 0x02047778, + /* Microphone + Array MIC security Disable +ADC clock Enable */ + 0x0205000D, + 0x0204A020, + 0x02050005, + 0x02040700, + /* Speaker Enable */ + 0x0205000C, + 0x020401EF, + 0x0205000C, + 0x020401EF, + /* EQ Bypass + EQ HPF cutoff 250Hz */ + 0x05350000, + 0x0534201A, + 0x0535001d, + 0x05340800, + /* EQ-2 */ + 0x0535001e, + 0x05340800, + 0x05350003, + 0x05341EF8, + /* EQ-3 */ + 0x05350004, + 0x05340000, + 0x05450000, + 0x05442000, + /* EQ-4 */ + 0x0545001d, + 0x05440800, + 0x0545001e, + 0x05440800, + /* EQ-5 */ + 0x05450003, + 0x05441EF8, + 0x05450004, + 0x05440000, + /* EQ Update */ + 0x05350000, + 0x0534E01A, + 0x05350000, + 0x0534E01A, +}; + +const u32 pc_beep_verbs[] = { +//=== PCBeep pass through to NID14 for ePSA test-1 (D3 BEEP Detect) + 0x02050010, + 0x02040320, + 0x00170503, + 0x00170503, +//=== PCBeep pass through to NID14 for ePSA test-2 (Beep gain 0dB) + 0x02050036, + 0x02047717, + 0x02050036, + 0x02047717, +//=== PCBeep pass through to NID14 for ePSA test-3 + 0x01470740, + 0x0143B000, + 0x01470C02, + 0x01470C02, +}; + +AZALIA_ARRAY_SIZES;
