Martin L Roth has submitted this change. ( https://review.coreboot.org/c/coreboot/+/82639?usp=email )
Change subject: mb/qemu-{i440fx,q35}: reduce default ROM size to 8 MiB ......................................................................
By default, QEMU bails when trying to use bigger images mounted with '-drive if=pflash', which is required to make use of writable flash introduced in CB:82555. This changes both default size in Kconfig as well as FMAP layouts.
Since QEMU 5.0.0 it is possible to change the limit of firmware size with `max-fw-size` machine configuration option, up to 16 MiB, as bigger sizes would overlap with IO APIC memory range. Default is still 8 MiB, so it makes sense to have identical default in coreboot.
Error thrown by QEMU when trying to use too big ROM:
qemu-system-x86_64: combined size of system firmware exceeds 8388608 bytes
Change-Id: If36cb754a8e75e23bce49ff568dd88e5db279bb8 Signed-off-by: Krystian Hebel krystian.hebel@3mdeb.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/82639 Reviewed-by: Patrick Rudolph patrick.rudolph@9elements.com Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Maciej Pijanowski maciej.pijanowski@3mdeb.com Reviewed-by: Maximilian Brune maximilian.brune@9elements.com --- M src/mainboard/emulation/qemu-i440fx/Kconfig R src/mainboard/emulation/qemu-i440fx/vboot-rwa-8M.fmd M src/mainboard/emulation/qemu-q35/Kconfig D src/mainboard/emulation/qemu-q35/vboot-rwa-16M.fmd C src/mainboard/emulation/qemu-q35/vboot-rwa-8M.fmd R src/mainboard/emulation/qemu-q35/vboot-rwab-8M.fmd 6 files changed, 15 insertions(+), 34 deletions(-)
Approvals: Maciej Pijanowski: Looks good to me, but someone else must approve Patrick Rudolph: Looks good to me, approved Maximilian Brune: Looks good to me, approved build bot (Jenkins): Verified
diff --git a/src/mainboard/emulation/qemu-i440fx/Kconfig b/src/mainboard/emulation/qemu-i440fx/Kconfig index 842c053..6d6181c 100644 --- a/src/mainboard/emulation/qemu-i440fx/Kconfig +++ b/src/mainboard/emulation/qemu-i440fx/Kconfig @@ -12,7 +12,7 @@ select HAVE_PIRQ_TABLE select HAVE_ACPI_TABLES select BOARD_ROMSIZE_KB_4096 if !VBOOT - select BOARD_ROMSIZE_KB_16384 if VBOOT + select BOARD_ROMSIZE_KB_8192 if VBOOT select MAINBOARD_HAS_NATIVE_VGA_INIT select MAINBOARD_FORCE_NATIVE_VGA_INIT select HAVE_ASAN_IN_ROMSTAGE @@ -52,7 +52,7 @@ endif
config FMDFILE - default "src/mainboard/$(CONFIG_MAINBOARD_DIR)/vboot-rwa-16M.fmd" if VBOOT_SLOTS_RW_A + default "src/mainboard/$(CONFIG_MAINBOARD_DIR)/vboot-rwa-8M.fmd" if VBOOT_SLOTS_RW_A
config VBOOT_VBNV_OFFSET hex diff --git a/src/mainboard/emulation/qemu-i440fx/vboot-rwa-16M.fmd b/src/mainboard/emulation/qemu-i440fx/vboot-rwa-8M.fmd similarity index 65% rename from src/mainboard/emulation/qemu-i440fx/vboot-rwa-16M.fmd rename to src/mainboard/emulation/qemu-i440fx/vboot-rwa-8M.fmd index 0d2c9da..55a38b7 100644 --- a/src/mainboard/emulation/qemu-i440fx/vboot-rwa-16M.fmd +++ b/src/mainboard/emulation/qemu-i440fx/vboot-rwa-8M.fmd @@ -1,8 +1,8 @@ -FLASH@0xff000000 0x1000000 { - SI_BIOS 0x1000000 { - RW_SECTION_A 0x7c0000 { +FLASH@0xff800000 0x800000 { + SI_BIOS 0x800000 { + RW_SECTION_A 0x3c0000 { VBLOCK_A 0x10000 - FW_MAIN_A(CBFS) 0x74ffc0 + FW_MAIN_A(CBFS) RW_FWID_A 0x40 } RW_VPD(PRESERVE) 0x1000 diff --git a/src/mainboard/emulation/qemu-q35/Kconfig b/src/mainboard/emulation/qemu-q35/Kconfig index 2fb180b..70a7437 100644 --- a/src/mainboard/emulation/qemu-q35/Kconfig +++ b/src/mainboard/emulation/qemu-q35/Kconfig @@ -10,7 +10,7 @@ select HAVE_OPTION_TABLE # select HAVE_PIRQ_TABLE select HAVE_ACPI_TABLES - select BOARD_ROMSIZE_KB_16384 + select BOARD_ROMSIZE_KB_8192 select MAINBOARD_HAS_NATIVE_VGA_INIT select MAINBOARD_FORCE_NATIVE_VGA_INIT if !CHROMEOS select MEMORY_MAPPED_TPM @@ -29,8 +29,8 @@ select GBB_FLAG_DISABLE_FWMP
config FMDFILE - default "src/mainboard/$(CONFIG_MAINBOARD_DIR)/vboot-rwa-16M.fmd" if VBOOT_SLOTS_RW_A && !VBOOT_SLOTS_RW_AB - default "src/mainboard/$(CONFIG_MAINBOARD_DIR)/vboot-rwab-16M.fmd" if VBOOT_SLOTS_RW_AB + default "src/mainboard/$(CONFIG_MAINBOARD_DIR)/vboot-rwa-8M.fmd" if VBOOT_SLOTS_RW_A && !VBOOT_SLOTS_RW_AB + default "src/mainboard/$(CONFIG_MAINBOARD_DIR)/vboot-rwab-8M.fmd" if VBOOT_SLOTS_RW_AB
if ARCH_BOOTBLOCK_X86_64
diff --git a/src/mainboard/emulation/qemu-q35/vboot-rwa-16M.fmd b/src/mainboard/emulation/qemu-q35/vboot-rwa-16M.fmd deleted file mode 100644 index 0d2c9da..0000000 --- a/src/mainboard/emulation/qemu-q35/vboot-rwa-16M.fmd +++ /dev/null @@ -1,19 +0,0 @@ -FLASH@0xff000000 0x1000000 { - SI_BIOS 0x1000000 { - RW_SECTION_A 0x7c0000 { - VBLOCK_A 0x10000 - FW_MAIN_A(CBFS) 0x74ffc0 - RW_FWID_A 0x40 - } - RW_VPD(PRESERVE) 0x1000 - - WP_RO { - FMAP 0x800 - RO_FRID 0x40 - RO_PADDING 0x7c0 - RO_VPD(PRESERVE) 0x1000 - GBB 0x1e000 - COREBOOT(CBFS) - } - } -} diff --git a/src/mainboard/emulation/qemu-i440fx/vboot-rwa-16M.fmd b/src/mainboard/emulation/qemu-q35/vboot-rwa-8M.fmd similarity index 65% copy from src/mainboard/emulation/qemu-i440fx/vboot-rwa-16M.fmd copy to src/mainboard/emulation/qemu-q35/vboot-rwa-8M.fmd index 0d2c9da..55a38b7 100644 --- a/src/mainboard/emulation/qemu-i440fx/vboot-rwa-16M.fmd +++ b/src/mainboard/emulation/qemu-q35/vboot-rwa-8M.fmd @@ -1,8 +1,8 @@ -FLASH@0xff000000 0x1000000 { - SI_BIOS 0x1000000 { - RW_SECTION_A 0x7c0000 { +FLASH@0xff800000 0x800000 { + SI_BIOS 0x800000 { + RW_SECTION_A 0x3c0000 { VBLOCK_A 0x10000 - FW_MAIN_A(CBFS) 0x74ffc0 + FW_MAIN_A(CBFS) RW_FWID_A 0x40 } RW_VPD(PRESERVE) 0x1000 diff --git a/src/mainboard/emulation/qemu-q35/vboot-rwab-16M.fmd b/src/mainboard/emulation/qemu-q35/vboot-rwab-8M.fmd similarity index 89% rename from src/mainboard/emulation/qemu-q35/vboot-rwab-16M.fmd rename to src/mainboard/emulation/qemu-q35/vboot-rwab-8M.fmd index fcbfa95..8064fdf 100644 --- a/src/mainboard/emulation/qemu-q35/vboot-rwab-16M.fmd +++ b/src/mainboard/emulation/qemu-q35/vboot-rwab-8M.fmd @@ -1,5 +1,5 @@ -FLASH@0xff000000 0x1000000 { - SI_BIOS 0x1000000 { +FLASH@0xff800000 0x800000 { + SI_BIOS 0x800000 { RW_SECTION_A 0x1c0000 { VBLOCK_A 0x10000 FW_MAIN_A(CBFS)
