Attention is currently required from: Patrick Rudolph. Angel Pons has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/58283 )
Change subject: sb/intel/lynxpoint: Clarify PCIe Non Common Clock mode ......................................................................
The "force ASPM" setting actually controls Non Common Clock mode with Spread Spectrum Clocking. Rename the associated variables accordingly and expand the comments according to document 535127 (BDW PCH-LP BS).
Change-Id: I54e1c3fedd47e7df18b9d4feb0ca7d8636e8236f Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/mainboard/google/beltino/devicetree.cb M src/mainboard/google/slippy/devicetree.cb M src/southbridge/intel/lynxpoint/chip.h M src/southbridge/intel/lynxpoint/pcie.c 4 files changed, 21 insertions(+), 20 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/83/58283/1
diff --git a/src/mainboard/google/beltino/devicetree.cb b/src/mainboard/google/beltino/devicetree.cb index 8c54f6a..1644115 100644 --- a/src/mainboard/google/beltino/devicetree.cb +++ b/src/mainboard/google/beltino/devicetree.cb @@ -40,8 +40,8 @@ register "sata_port_map" = "0x1" register "sata_devslp_disable" = "0x1"
- # Force enable ASPM for PCIe Port 4 - register "pcie_port_force_aspm" = "0x10" + # Force enable Non Common Clock mode with SSC for PCIe Port 4 + register "pcie_port_force_ncc_ssc" = "0x10"
# Enable port coalescing register "pcie_port_coalesce" = "1" diff --git a/src/mainboard/google/slippy/devicetree.cb b/src/mainboard/google/slippy/devicetree.cb index d989545..e7c6e3a 100644 --- a/src/mainboard/google/slippy/devicetree.cb +++ b/src/mainboard/google/slippy/devicetree.cb @@ -47,8 +47,8 @@ register "sio_i2c0_voltage" = "0" # 3.3V register "sio_i2c1_voltage" = "0" # 3.3V
- # Force enable ASPM for PCIe Port 1 - register "pcie_port_force_aspm" = "0x01" + # Force enable Non Common Clock mode with SSC for PCIe Port 1 + register "pcie_port_force_ncc_ssc" = "0x01"
# Route all USB ports to XHCI per default register "xhci_default" = "1" diff --git a/src/southbridge/intel/lynxpoint/chip.h b/src/southbridge/intel/lynxpoint/chip.h index 89bbb1c..45f2fe6 100644 --- a/src/southbridge/intel/lynxpoint/chip.h +++ b/src/southbridge/intel/lynxpoint/chip.h @@ -67,8 +67,8 @@ /* Enable linear PCIe Root Port function numbers starting at zero */ uint8_t pcie_port_coalesce;
- /* Force root port ASPM configuration with port bitmap */ - uint8_t pcie_port_force_aspm; + /* Force root port Non-Common Clock mode with SSC with port bitmap */ + uint8_t pcie_port_force_ncc_ssc;
/* Put SerialIO devices into ACPI mode instead of a PCI device */ uint8_t sio_acpi_mode; diff --git a/src/southbridge/intel/lynxpoint/pcie.c b/src/southbridge/intel/lynxpoint/pcie.c index 3d8bb79..271f7c8 100644 --- a/src/southbridge/intel/lynxpoint/pcie.c +++ b/src/southbridge/intel/lynxpoint/pcie.c @@ -502,7 +502,7 @@ static void pch_pcie_early(struct device *dev) { struct southbridge_intel_lynxpoint_config *config = dev->chip_info; - int do_aspm = 0; + int pcie_ncc_ssc = 0; int rp = root_port_number(dev); int is_lp = pch_is_lp();
@@ -516,21 +516,21 @@ * Bits 31:28 of b0d28f0 0x32c register correspond to * Root Ports 4:1. */ - do_aspm = !!(rpc.b0d28f0_32c & (1 << (28 + rp - 1))); + pcie_ncc_ssc = !!(rpc.b0d28f0_32c & (1 << (28 + rp - 1))); break; case 5: /* * Bit 28 of b0d28f4 0x32c register corresponds to * Root Port 5. */ - do_aspm = !!(rpc.b0d28f4_32c & (1 << 28)); + pcie_ncc_ssc = !!(rpc.b0d28f4_32c & (1 << 28)); break; case 6: /* * Bit 29 of b0d28f5 0x32c register corresponds to * Root Port 6. */ - do_aspm = !!(rpc.b0d28f5_32c & (1 << 29)); + pcie_ncc_ssc = !!(rpc.b0d28f5_32c & (1 << 29)); break; } } else { @@ -543,7 +543,7 @@ * Bits 31:28 of b0d28f0 0x32c register correspond to * Root Ports 4:1. */ - do_aspm = !!(rpc.b0d28f0_32c & (1 << (28 + rp - 1))); + pcie_ncc_ssc = !!(rpc.b0d28f0_32c & (1 << (28 + rp - 1))); break; case 5: case 6: @@ -553,25 +553,26 @@ * Bits 31:28 of b0d28f4 0x32c register correspond to * Root Ports 8:5. */ - do_aspm = !!(rpc.b0d28f4_32c & (1 << (28 + rp - 5))); + pcie_ncc_ssc = !!(rpc.b0d28f4_32c & (1 << (28 + rp - 5))); break; } }
- /* Allow ASPM to be forced on in devicetree */ - if (config && (config->pcie_port_force_aspm & (1 << (rp - 1)))) - do_aspm = 1; + /* Allow Non Common Clock mode with Spread Spectrum to be forced on in devicetree */ + if (config && (config->pcie_port_force_ncc_ssc & (1 << (rp - 1)))) + pcie_ncc_ssc = 1;
- printk(BIOS_DEBUG, "PCIe Root Port %d ASPM is %sabled\n", - rp, do_aspm ? "en" : "dis"); + printk(BIOS_DEBUG, "PCIe Root Port %d Non Common Clock mode with SSC is %sabled\n", + rp, pcie_ncc_ssc ? "en" : "dis");
- if (do_aspm) { - /* Set ASPM bits in MPC2 register. */ + if (pcie_ncc_ssc) { + /* Disable ASPM L0s support in MPC2 register. */ pci_update_config32(dev, 0xd4, ~(0x3 << 2), (1 << 4) | (0x2 << 2));
/* Set unique clock exit latency in MPC register. */ pci_update_config32(dev, 0xd8, ~(0x7 << 18), (0x7 << 18));
+ /* Increase the elastic buffer pointer half full pointer values by 2. */ if (is_lp) { switch (rp) { case 1: @@ -649,7 +650,7 @@ pci_update_config32(dev, 0x318, ~(0xffff << 16), (0x1414 << 16));
/* Set L1 exit latency in LCAP register. */ - if ((pci_read_config8(dev, 0xf5) & 0x1) || do_aspm) + if ((pci_read_config8(dev, 0xf5) & 0x1) || pcie_ncc_ssc) pci_update_config32(dev, 0x4c, ~(0x7 << 15), (0x4 << 15)); else pci_update_config32(dev, 0x4c, ~(0x7 << 15), (0x2 << 15));
