Denis Carikli (GNUtoo@no-log.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/3229
commit 42266b8416b74ae3442d28242f9c88388e055fe8 Author: Denis 'GNUtoo' Carikli GNUtoo@no-log.org Date: Thu May 9 23:35:18 2013 +0200
PC Engines ALIX.1C: Add CMOS defaults.
After removing power and the CMOS Battery, putting it back and booting coreboot we have: # ./nvramtool -a boot_option = Fallback last_boot = Fallback ECC_memory = Disable baud_rate = 115200 power_on_after_fail = Disable debug_level = Spew boot_first = HDD boot_second = Fallback_Floppy boot_third = Fallback_Network boot_index = 0xf boot_countdown = 0x7f nvramtool: Warning: Coreboot CMOS checksum is bad.
Change-Id: Iba2701d4611cd2c2e5a2d76d41ffc23ed65574e8 Signed-off-by: Denis 'GNUtoo' Carikli GNUtoo@no-log.org --- src/mainboard/pcengines/alix1c/Kconfig | 2 ++ src/mainboard/pcengines/alix1c/cmos.default | 11 +++++++++++ 2 files changed, 13 insertions(+)
diff --git a/src/mainboard/pcengines/alix1c/Kconfig b/src/mainboard/pcengines/alix1c/Kconfig index 315b7ed..fab8710 100644 --- a/src/mainboard/pcengines/alix1c/Kconfig +++ b/src/mainboard/pcengines/alix1c/Kconfig @@ -12,6 +12,8 @@ config BOARD_SPECIFIC_OPTIONS # dummy select UDELAY_TSC select BOARD_ROMSIZE_KB_512 select POWER_BUTTON_DEFAULT_DISABLE + select HAVE_OPTION_TABLE + select HAVE_CMOS_DEFAULT
config MAINBOARD_DIR string diff --git a/src/mainboard/pcengines/alix1c/cmos.default b/src/mainboard/pcengines/alix1c/cmos.default new file mode 100644 index 0000000..189c691 --- /dev/null +++ b/src/mainboard/pcengines/alix1c/cmos.default @@ -0,0 +1,11 @@ +boot_option=Fallback +last_boot=Fallback +ECC_memory=Disable +baud_rate=115200 +power_on_after_fail=Disable +debug_level=Spew +boot_first=HDD +boot_second=Fallback_Floppy +boot_third=Fallback_Network +boot_index=0xf +boot_countdown=0x7f
