the following patch was just integrated into master: commit 6a106943d020015fdeccb7a40a1e1f3e04ef9369 Author: Paul Kocialkowski contact@paulk.fr Date: Mon Aug 3 23:03:27 2015 +0200
chromeos: vboot: Adaptations for using a separate object out directory
$(obj) might be defined either as a relative or an absolute path. Thus, it has to be filtered out before adding $(top) to it (in case of an absolute path) when building vboot. It is then provided separately in CFLAGS (as an absolute path).
In addition, VB2_LIB inherits $(obj), so it might also already be an absolute path, and prefixing $(top) to it doesn't apply. Thus, the absolute path to it should be passed to the vboot make command.
Change-Id: I13e893ebdf22c4513ee40d9331a30ac7de8f9788 Signed-off-by: Paul Kocialkowski contact@paulk.fr Reviewed-on: http://review.coreboot.org/11120 Tested-by: build bot (Jenkins) Reviewed-by: Patrick Georgi pgeorgi@google.com
See http://review.coreboot.org/11120 for details.
