Karthik Ramasubramanian has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/84095?usp=email )
Change subject: mb/google/brox/var/jubilant: Remove STORAGE_UNKNOWN fw_config option ......................................................................
With `probe unprovisioned` fw_config rule, there is no need to define an explicit STORAGE_UNKNOWN option. Hence remove it.
BUG=None TEST=Build Jubilant FW image.
Change-Id: I4f6ace4b39a1ee0b63486d3872b20c8da719ae4a Signed-off-by: Karthikeyan Ramasubramanian kramasub@google.com --- M src/mainboard/google/brox/variants/jubilant/fw_config.c M src/mainboard/google/brox/variants/jubilant/overridetree.cb M src/mainboard/google/brox/variants/jubilant/variant.c 3 files changed, 3 insertions(+), 32 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/95/84095/1
diff --git a/src/mainboard/google/brox/variants/jubilant/fw_config.c b/src/mainboard/google/brox/variants/jubilant/fw_config.c index 7341afe..5076c73 100644 --- a/src/mainboard/google/brox/variants/jubilant/fw_config.c +++ b/src/mainboard/google/brox/variants/jubilant/fw_config.c @@ -74,11 +74,9 @@ gpio_configure_pads(lte_disable_pads, ARRAY_SIZE(lte_disable_pads)); }
- if (!fw_config_probe(FW_CONFIG(STORAGE, STORAGE_UNKNOWN))) { - if (!fw_config_probe(FW_CONFIG(STORAGE, STORAGE_NVME))) { - printk(BIOS_INFO, "Disable NVMe GPIO pins by fw_config.\n"); - gpio_configure_pads(nvme_disable_pads, ARRAY_SIZE(nvme_disable_pads)); - } + if (!fw_config_probe(FW_CONFIG(STORAGE, STORAGE_NVME))) { + printk(BIOS_INFO, "Disable NVMe GPIO pins by fw_config.\n"); + gpio_configure_pads(nvme_disable_pads, ARRAY_SIZE(nvme_disable_pads)); } } BOOT_STATE_INIT_ENTRY(BS_DEV_ENABLE, BS_ON_ENTRY, fw_config_handle, NULL); diff --git a/src/mainboard/google/brox/variants/jubilant/overridetree.cb b/src/mainboard/google/brox/variants/jubilant/overridetree.cb index 6d7c3f8..67b92d5 100644 --- a/src/mainboard/google/brox/variants/jubilant/overridetree.cb +++ b/src/mainboard/google/brox/variants/jubilant/overridetree.cb @@ -1,6 +1,5 @@ fw_config field STORAGE 2 3 - option STORAGE_UNKNOWN 0 option STORAGE_UFS 1 option STORAGE_NVME 2 end @@ -296,7 +295,6 @@ .flags = PCIE_RP_LTR | PCIE_RP_AER, }" probe STORAGE STORAGE_NVME - probe STORAGE STORAGE_UNKNOWN probe unprovisioned end device ref pcie_rp5 on @@ -338,12 +336,10 @@ device generic 0 alias ish_conf on end end probe STORAGE STORAGE_UFS - probe STORAGE STORAGE_UNKNOWN probe unprovisioned end device ref ufs on probe STORAGE STORAGE_UFS - probe STORAGE STORAGE_UNKNOWN probe unprovisioned end device ref i2c0 on diff --git a/src/mainboard/google/brox/variants/jubilant/variant.c b/src/mainboard/google/brox/variants/jubilant/variant.c index 4b214aa..6cbfe19 100644 --- a/src/mainboard/google/brox/variants/jubilant/variant.c +++ b/src/mainboard/google/brox/variants/jubilant/variant.c @@ -24,26 +24,3 @@ { return get_wifi_sar_fw_config_filename(FW_CONFIG_FIELD(WIFI_BT)); } - -void variant_devtree_update(void) -{ - struct device *ufs = DEV_PTR(ufs); - struct device *ish = DEV_PTR(ish); - struct device *nvme_rp = DEV_PTR(pcie4_0); - - if (fw_config_probe(FW_CONFIG(STORAGE, STORAGE_UNKNOWN)) || (!fw_config_is_provisioned())) { - printk(BIOS_INFO, "fw_config is unprovisioned or storage is unknown so enable all storage's configs.\n"); - return; - } - - if (!fw_config_probe(FW_CONFIG(STORAGE, STORAGE_NVME))) { - printk(BIOS_INFO, "NVMe disabled by fw_config.\n"); - nvme_rp->enabled = 0; - } - - if (!fw_config_probe(FW_CONFIG(STORAGE, STORAGE_UFS))) { - printk(BIOS_INFO, "UFS disabled by fw_config.\n"); - ufs->enabled = 0; - ish->enabled = 0; - } -}
