shkim has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/35748 )
Change subject: mb/google/kohaku: Assign GPP_A19 as reset_gpio of stylus device ......................................................................
Applying reset_gpio config of stylus for kohaku. GPP_A19 has been assigned in latest schematics.
BUG=b:141914474 BRANCH=none TEST=verified stylus works internally Signed-off-by: Seunghwan Kim sh_.kim@samsung.com
Change-Id: I61f0f9a4378f47bf455f0726d44beeaf2f67197b --- M src/mainboard/google/hatch/variants/kohaku/gpio.c M src/mainboard/google/hatch/variants/kohaku/overridetree.cb 2 files changed, 6 insertions(+), 8 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/48/35748/1
diff --git a/src/mainboard/google/hatch/variants/kohaku/gpio.c b/src/mainboard/google/hatch/variants/kohaku/gpio.c index 9654388..84270b3 100644 --- a/src/mainboard/google/hatch/variants/kohaku/gpio.c +++ b/src/mainboard/google/hatch/variants/kohaku/gpio.c @@ -23,16 +23,16 @@ PAD_NC(GPP_A0, NONE), /* A6 : SERIRQ ==> NC */ PAD_NC(GPP_A6, NONE), - /* A10 : PEN_RESET_ODL */ - PAD_CFG_GPO(GPP_A10, 1, DEEP), + /* A10 : CLKOUT_LPC1 ==> NC */ + PAD_NC(GPP_A10, NONE), /* A16 : EMR_GARAGE_DET (notification) */ PAD_CFG_GPI_GPIO_DRIVER(GPP_A16, NONE, PLTRST), /* A17 : PIRQA# ==> NC */ PAD_NC(GPP_A17, NONE), /* A18 : ISH_GP0 ==> NC */ PAD_NC(GPP_A18, NONE), - /* A19 : ISH_GP1 ==> NC */ - PAD_NC(GPP_A19, NONE), + /* A19 : PEN_RESET_ODL */ + PAD_CFG_GPO(GPP_A19, 0, DEEP), /* A20 : ISH_GP2 ==> NC */ PAD_NC(GPP_A20, NONE), /* A22 : ISH_GP4 ==> NC */ diff --git a/src/mainboard/google/hatch/variants/kohaku/overridetree.cb b/src/mainboard/google/hatch/variants/kohaku/overridetree.cb index 8c7bb1f..37914fa 100644 --- a/src/mainboard/google/hatch/variants/kohaku/overridetree.cb +++ b/src/mainboard/google/hatch/variants/kohaku/overridetree.cb @@ -189,10 +189,8 @@ register "generic.desc" = ""WCOM Digitizer"" register "generic.irq" = "ACPI_IRQ_LEVEL_LOW(GPP_C7_IRQ)" register "generic.enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_C15)" - # TODO: We can't use GPP_A10 as reset_gpio due to its voltage level, - # so we need to reassign it or remove it. - #register "generic.reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_A10)" - #register "generic.reset_delay_ms" = "1" + register "generic.reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_A19)" + register "generic.reset_delay_ms" = "1" register "generic.has_power_resource" = "1" register "hid_desc_reg_offset" = "0x1" device i2c 0x09 on end
Hello Furquan Shaikh,
Change subject: mb/google/kohaku: Assign GPP_A19 as reset_gpio of stylus ......................................................................
Applying reset_gpio config of stylus for kohaku. GPP_A19 has been assigned in the latest schematics.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/48/35748/2
Shelley Chen has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35748 )
Patch Set 2: Code-Review+2
Patch Set 2: -Code-Review
Patrick Georgi has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35748 )
Patch Set 2:
https://review.coreboot.org/c/coreboot/+/35748/2/src/mainboard/google/hatch/... File src/mainboard/google/hatch/variants/kohaku/gpio.c:
https://review.coreboot.org/c/coreboot/+/35748/2/src/mainboard/google/hatch/... PS2, Line 26: /* A10 : CLKOUT_LPC1 ==> NC */
Comment removed by: Patrick Georgi
There is a concern that we'll break some older devices if we update them with this change. Maybe we can keep GPP_A10 as an output gpio because that's what they expect?
SH Kim has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35748 )
Patch Set 2:
There is a concern that we'll break some older devices if we update them with this change. […]
There is an issue reset_gpio doesn't works on evt and older devices (operation voltage issue, b:137326841). Do you want to just keep GPP_A10 to output high for them? Or we can have another gpio override table for evt and older systems and use it for (board_id <= 3).
Patch Set 2:
There is an issue reset_gpio doesn't works on evt and older devices (operation voltage issue, b:1373 […]
Yes, just leave GPP_A10 as output high. The reset gpio was never working for older devices anyway, so I think that that's ok.
SH Kim has uploaded a new patch set (#3) to the change originally created by shkim. ( https://review.coreboot.org/c/coreboot/+/35748 )
Change-Id: I61f0f9a4378f47bf455f0726d44beeaf2f67197b --- M src/mainboard/google/hatch/variants/kohaku/gpio.c M src/mainboard/google/hatch/variants/kohaku/overridetree.cb 2 files changed, 5 insertions(+), 7 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/48/35748/3
SH Kim has uploaded a new patch set (#4) to the change originally created by shkim. ( https://review.coreboot.org/c/coreboot/+/35748 )
We would keep GPP_A10 as output high for old revision devices temporarily.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/48/35748/4
Patch Set 4:
Yes, just leave GPP_A10 as output high. […]
We may need change it to NC config in future for power saving.
Patch Set 4:
Yes, we definitely will update.
Patch Set 4: Code-Review+2
Shelley Chen has submitted this change. ( https://review.coreboot.org/c/coreboot/+/35748 )
Change-Id: I61f0f9a4378f47bf455f0726d44beeaf2f67197b Reviewed-on: https://review.coreboot.org/c/coreboot/+/35748 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Shelley Chen shchen@google.com --- M src/mainboard/google/hatch/variants/kohaku/gpio.c M src/mainboard/google/hatch/variants/kohaku/overridetree.cb 2 files changed, 5 insertions(+), 7 deletions(-)
Approvals: build bot (Jenkins): Verified Shelley Chen: Looks good to me, approved
diff --git a/src/mainboard/google/hatch/variants/kohaku/gpio.c b/src/mainboard/google/hatch/variants/kohaku/gpio.c index 9654388..7bf9a0c 100644 --- a/src/mainboard/google/hatch/variants/kohaku/gpio.c +++ b/src/mainboard/google/hatch/variants/kohaku/gpio.c @@ -23,7 +23,7 @@ PAD_NC(GPP_A0, NONE), /* A6 : SERIRQ ==> NC */ PAD_NC(GPP_A6, NONE), - /* A10 : PEN_RESET_ODL */ + /* A10 : PEN_RESET_ODL for old revision devices */ PAD_CFG_GPO(GPP_A10, 1, DEEP), /* A16 : EMR_GARAGE_DET (notification) */ PAD_CFG_GPI_GPIO_DRIVER(GPP_A16, NONE, PLTRST), @@ -31,8 +31,8 @@ PAD_NC(GPP_A17, NONE), /* A18 : ISH_GP0 ==> NC */ PAD_NC(GPP_A18, NONE), - /* A19 : ISH_GP1 ==> NC */ - PAD_NC(GPP_A19, NONE), + /* A19 : PEN_RESET_ODL */ + PAD_CFG_GPO(GPP_A19, 0, DEEP), /* A20 : ISH_GP2 ==> NC */ PAD_NC(GPP_A20, NONE), /* A22 : ISH_GP4 ==> NC */ diff --git a/src/mainboard/google/hatch/variants/kohaku/overridetree.cb b/src/mainboard/google/hatch/variants/kohaku/overridetree.cb index 8c7bb1f..37914fa 100644 --- a/src/mainboard/google/hatch/variants/kohaku/overridetree.cb +++ b/src/mainboard/google/hatch/variants/kohaku/overridetree.cb @@ -189,10 +189,8 @@ register "generic.desc" = ""WCOM Digitizer"" register "generic.irq" = "ACPI_IRQ_LEVEL_LOW(GPP_C7_IRQ)" register "generic.enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_C15)" - # TODO: We can't use GPP_A10 as reset_gpio due to its voltage level, - # so we need to reassign it or remove it. - #register "generic.reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_A10)" - #register "generic.reset_delay_ms" = "1" + register "generic.reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_A19)" + register "generic.reset_delay_ms" = "1" register "generic.has_power_resource" = "1" register "hid_desc_reg_offset" = "0x1" device i2c 0x09 on end
