Timothy Pearson (tpearson@raptorengineeringinc.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/11957
commit b6567ae0290b8147e4e74308147fd2ce9d383825 Author: Timothy Pearson tpearson@raptorengineeringinc.com Date: Sat Sep 5 18:56:05 2015 -0500
northbridge/amd/amdfam10: Set DIMM voltage based on SPD data
Change-Id: I67a76cf0e4ebc33fbd7dd151bb68dce1fc6ba680 Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- src/northbridge/amd/amdfam10/Kconfig | 4 ++ src/northbridge/amd/amdfam10/acpi.c | 3 +- src/northbridge/amd/amdfam10/northbridge.c | 75 ++++++++++++++++++++++++----- src/northbridge/amd/amdmct/mct_ddr3/mct_d.c | 8 +++ src/northbridge/amd/amdmct/mct_ddr3/mct_d.h | 6 +++ 5 files changed, 81 insertions(+), 15 deletions(-)
diff --git a/src/northbridge/amd/amdfam10/Kconfig b/src/northbridge/amd/amdfam10/Kconfig index dbf13df..b01b4f5 100644 --- a/src/northbridge/amd/amdfam10/Kconfig +++ b/src/northbridge/amd/amdfam10/Kconfig @@ -87,6 +87,10 @@ config DIMM_REGISTERED bool default n
+config DIMM_VOLTAGE_SET_SUPPORT + bool + default n + if DIMM_FBDIMM config DIMM_SUPPORT hex diff --git a/src/northbridge/amd/amdfam10/acpi.c b/src/northbridge/amd/amdfam10/acpi.c index 4b86e96..92433bb 100644 --- a/src/northbridge/amd/amdfam10/acpi.c +++ b/src/northbridge/amd/amdfam10/acpi.c @@ -307,8 +307,7 @@ void northbridge_acpi_write_vars(device_t device) } else { if((sysconf.pci1234[0] >> 12) & 0xff) { //sb chain on other than bus 0 CBST = (u8) (0x0f); - } - else { + } else { CBST = (u8) (0x00); } } diff --git a/src/northbridge/amd/amdfam10/northbridge.c b/src/northbridge/amd/amdfam10/northbridge.c index d4fe986..ff324cd 100644 --- a/src/northbridge/amd/amdfam10/northbridge.c +++ b/src/northbridge/amd/amdfam10/northbridge.c @@ -950,19 +950,38 @@ static int amdfam10_get_smbios_data16(int* count, int handle, unsigned long *cur
static uint16_t amdmct_mct_speed_enum_to_mhz(uint8_t speed) { - switch (speed) { - case 1: - return 200; - case 2: - return 266; - case 3: - return 333; - case 4: - return 400; - case 5: - return 533; - default: - return 0; + if (IS_ENABLED(CONFIG_DIMM_DDR2)) { + switch (speed) { + case 1: + return 200; + case 2: + return 266; + case 3: + return 333; + case 4: + return 400; + case 5: + return 533; + default: + return 0; + } + } else if (IS_ENABLED(CONFIG_DIMM_DDR3)) { + switch (speed) { + case 3: + return 333; + case 4: + return 400; + case 5: + return 533; + case 6: + return 667; + case 7: + return 800; + default: + return 0; + } + } else { + return 0; } }
@@ -1048,6 +1067,36 @@ static int amdfam10_get_smbios_data17(int* count, int handle, int parent_handle, snprintf(string_buffer, sizeof (string_buffer), "%08X", mem_info->dct_stat[node].DimmSerialNumber[slot]); t->serial_number = smbios_add_string(t->eos, string_buffer); } + if (IS_ENABLED(CONFIG_DIMM_DDR2)) { + /* JEDEC specifies 1.8V only, so assume that the memory is configured for 1.8V */ + t->minimum_voltage = 1800; + t->maximum_voltage = 1800; + t->configured_voltage = 1800; + } else if (IS_ENABLED(CONFIG_DIMM_DDR3)) { +#if IS_ENABLED(CONFIG_DIMM_DDR3) + /* Find the maximum and minimum supported voltages */ + uint8_t supported_voltages = mem_info->dct_stat[node].DimmSupportedVoltages[slot]; + if (supported_voltages & 0x8) + t->minimum_voltage = 1150; + else if (supported_voltages & 0x4) + t->minimum_voltage = 1250; + else if (supported_voltages & 0x2) + t->minimum_voltage = 1350; + else if (supported_voltages & 0x1) + t->minimum_voltage = 1500; + + if (supported_voltages & 0x1) + t->maximum_voltage = 1500; + else if (supported_voltages & 0x2) + t->maximum_voltage = 1350; + else if (supported_voltages & 0x4) + t->maximum_voltage = 1250; + else if (supported_voltages & 0x8) + t->maximum_voltage = 1150; + + t->configured_voltage = mem_info->dct_stat[node].DimmConfiguredVoltage[slot]; +#endif + } t->memory_error_information_handle = 0xFFFE; /* no error information handle available */ single_len = t->length + smbios_string_table_len(t->eos); len += single_len; diff --git a/src/northbridge/amd/amdmct/mct_ddr3/mct_d.c b/src/northbridge/amd/amdmct/mct_ddr3/mct_d.c index b92375b..148644e 100644 --- a/src/northbridge/amd/amdmct/mct_ddr3/mct_d.c +++ b/src/northbridge/amd/amdmct/mct_ddr3/mct_d.c @@ -340,6 +340,11 @@ restartinit: goto fatalexit; }
+#if IS_ENABLED(DIMM_VOLTAGE_SET_SUPPORT) + printk(BIOS_DEBUG, "mctAutoInitMCT_D: DIMMSetVoltage\n"); + DIMMSetVoltages(pMCTstat, pDCTstatA); /* Set the DIMM voltages (mainboard specific) */ +#endif + printk(BIOS_DEBUG, "mctAutoInitMCT_D: SyncDCTsReady_D\n"); SyncDCTsReady_D(pMCTstat, pDCTstatA); /* Make sure DCTs are ready for accesses.*/
@@ -2132,6 +2137,9 @@ static u8 DIMMPresence_D(struct MCTStatStruc *pMCTstat, pDCTstat->DimmBanks[i] = 1ULL << (((mctRead_SPD(smbaddr, SPD_Density) & 0x70) >> 4) + 3); pDCTstat->DimmWidth[i] = 1ULL << ((mctRead_SPD(smbaddr, SPD_BusWidth) & 0x7) + 3); } + /* Check supported voltage(s) */ + pDCTstat->DimmSupportedVoltages[i] = mctRead_SPD(smbaddr, SPD_Voltage) & 0x7; + pDCTstat->DimmSupportedVoltages[i] ^= 0x1; /* Invert LSB to convert from SPD format to internal bitmap format */ /* Check module type */ byte = mctRead_SPD(smbaddr, SPD_DIMMTYPE) & 0x7; if (byte == JED_RDIMM || byte == JED_MiniRDIMM) { diff --git a/src/northbridge/amd/amdmct/mct_ddr3/mct_d.h b/src/northbridge/amd/amdmct/mct_ddr3/mct_d.h index 541c3e6..ea74d31 100644 --- a/src/northbridge/amd/amdmct/mct_ddr3/mct_d.h +++ b/src/northbridge/amd/amdmct/mct_ddr3/mct_d.h @@ -206,6 +206,7 @@ #define JED_MiniRDIMM 0x5 /* Mini-RDIMM */ #define SPD_Density 4 /* Bank address bits,SDRAM capacity */ #define SPD_Addressing 5 /* Row/Column address bits */ +#define SPD_Voltage 6 /* Supported voltage bitfield */ #define SPD_Organization 7 /* rank#,Device width */ #define SPD_BusWidth 8 /* ECC, Bus width */ #define JED_ECC 8 /* ECC capability */ @@ -585,6 +586,10 @@ struct DCTStatStruc { /* A per Node structure*/ struct _sDCTStruct s_C_DCTPtr[2]; /* struct _sDCTStruct s_C_DCT1Ptr[8]; */
+ /* DIMM supported voltage bitmap ([2:0]: 1.25V, 1.35V, 1.5V) */ + uint8_t DimmSupportedVoltages[MAX_DIMMS_SUPPORTED]; + uint32_t DimmConfiguredVoltage[MAX_DIMMS_SUPPORTED]; /* mV */ + uint8_t DimmRows[MAX_DIMMS_SUPPORTED]; uint8_t DimmCols[MAX_DIMMS_SUPPORTED]; uint8_t DimmRanks[MAX_DIMMS_SUPPORTED]; @@ -905,6 +910,7 @@ u32 procOdtWorkaround(struct DCTStatStruc *pDCTstat, u32 dct, u32 val); void mct_BeforeDramInit_D(struct DCTStatStruc *pDCTstat, u32 dct); void mctGet_DIMMAddr(struct DCTStatStruc *pDCTstat, u32 node); void mctSMBhub_Init(u32 node); +void DIMMSetVoltages(struct MCTStatStruc *pMCTstat, struct DCTStatStruc *pDCTstatA); int mctRead_SPD(u32 smaddr, u32 reg); void InterleaveNodes_D(struct MCTStatStruc *pMCTstat, struct DCTStatStruc *pDCTstatA); void InterleaveChannels_D(struct MCTStatStruc *pMCTstat, struct DCTStatStruc *pDCTstatA);
