Martin Roth (martinroth@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/13674
commit 0d48c1645fdb13e122e5d1e17c1c40d19523b66b Author: Martin Roth martinroth@google.com Date: Wed Feb 10 16:06:00 2016 -0700
util/kconfig: Ignore extra symbols in configs instead of failing
When updating an old .config file that has a symbol that has been removed from the current Kconfig tree, kconfig will generate a warning and fail to save the updated file. This is incredibly annoying, and not the goal when trying to eliminate Kconfig warnings.
Instead of generating a warning, just print a message that it's being ignored. This will remove the offending symbol, while allowing the updated config file to be saved.
Split the change from 1 line to 3 lines to keep it at 80 characters.
Change-Id: I09d5775c9ed14bde80077b51b862a7f41bee098a Signed-off-by: Martin Roth martinroth@google.com --- util/kconfig/confdata.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/util/kconfig/confdata.c b/util/kconfig/confdata.c index e582463..436d735 100644 --- a/util/kconfig/confdata.c +++ b/util/kconfig/confdata.c @@ -362,7 +362,9 @@ load: if (def == S_DEF_USER) { sym = sym_find(line + strlen(CONFIG_)); if (!sym) { - conf_warning("trying to assign non-existent symbol %s", line + strlen(CONFIG_)); + conf_message( + "ignoring nonexistent symbol %s", + line + strlen(CONFIG_)); sym_add_change_count(1); goto setsym; }
