Benjamin Doron has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/81937?usp=email )
Change subject: soc/intel/common/block/crashlog: Add Early CrashLog feature ......................................................................
CrashLog is a useful feature for debugging critical errors, but until now, it has only been used by ramstage code to generate an ACPI table. This doesn't help if system firmware itself contains bugs.
To help with these sorts of early issues, dump any CrashLog data found to the console, where it can be retrieved as used for debugging. SoC code should call this as early as possible.
While this code also does not perform the CrashLog enablement performed by some FSPs, it's assumed not necessary: it was already performed on a previous boot. Now, all that's necessary is to read the data.
Change-Id: I7a02f29a3bb63ed210ab3a6812c8575569e43c07 Signed-off-by: Benjamin Doron benjamin.doron@9elements.com --- M src/soc/intel/common/block/crashlog/Makefile.mk A src/soc/intel/common/block/crashlog/early_crashlog.c M src/soc/intel/common/block/include/intelblocks/crashlog.h 3 files changed, 196 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/37/81937/1
diff --git a/src/soc/intel/common/block/crashlog/Makefile.mk b/src/soc/intel/common/block/crashlog/Makefile.mk index 1f101c5..8868765 100644 --- a/src/soc/intel/common/block/crashlog/Makefile.mk +++ b/src/soc/intel/common/block/crashlog/Makefile.mk @@ -1,2 +1,4 @@ ## SPDX-License-Identifier: GPL-2.0-only +bootblock-$(CONFIG_SOC_INTEL_COMMON_BLOCK_CRASHLOG) += early_crashlog.c +bootblock-$(CONFIG_SOC_INTEL_COMMON_BLOCK_CRASHLOG) += crashlog.c ramstage-$(CONFIG_SOC_INTEL_COMMON_BLOCK_CRASHLOG) += crashlog.c diff --git a/src/soc/intel/common/block/crashlog/early_crashlog.c b/src/soc/intel/common/block/crashlog/early_crashlog.c new file mode 100644 index 0000000..51c2689 --- /dev/null +++ b/src/soc/intel/common/block/crashlog/early_crashlog.c @@ -0,0 +1,191 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <console/console.h> +#include <device/mmio.h> +#include <intelblocks/crashlog.h> + +void __weak early_cl_enable_bars(void) +{ + printk(BIOS_WARNING, "%s: Operation unsupported!\n", __func__); +} + +void __weak early_cl_disable_bars(void) +{ + printk(BIOS_WARNING, "%s: Operation unsupported!\n", __func__); +} + +static bool early_cl_dump_data_from_sram(u32 src_bar, + u32 offset, + u32 size, + u32 buffer_index, + bool pmc_sram) +{ + if (src_bar == 0) { + printk(BIOS_ERR, "Invalid bar 0x%x and offset 0x%x for %s\n", + src_bar, offset, __func__); + return false; + } + + u32 src_addr = src_bar + offset; + + u32 data = read32((u32 *)src_addr); + + /* First 32bits of the record must not be 0xdeadbeef */ + if (data == INVALID_CRASHLOG_RECORD) { + printk(BIOS_DEBUG, "Invalid data 0x%x at offset 0x%x from addr 0x%x\n", + data, offset, src_bar); + return false; + } + + /* PMC: copy if 1st DWORD in buffer is not zero and its 31st bit is not set */ + if (pmc_sram && !(data && !(data & BIT(31)))) { + printk(BIOS_DEBUG, "Invalid data 0x%x at offset 0x%x from addr 0x%x" + " of PMC SRAM.\n", data, offset, src_bar); + return false; + } + /*CPU: don't copy if 1st DWORD in first buffer is zero */ + if (!pmc_sram && !data && (buffer_index == 0)) { + printk(BIOS_DEBUG, "Invalid data 0x%x at offset 0x%x from addr 0x%x" + " of telemetry SRAM.\n", data, offset, src_bar); + return false; + } + + printk(BIOS_DEBUG, "%s (buffer %d):\n", pmc_sram ? "PMC SRAM" : "CPU SRAM", buffer_index); + + u32 copied = 0; + while (copied < size) { + /* DW by DW copy: byte access to PMC SRAM not allowed */ + data = read32((u32 *)src_addr); + printk(BIOS_DEBUG, "0x%x 0x%x 0x%x 0x%x ", + (data & 0xff000000) >> 24, + (data & 0x00ff0000) >> 16, + (data & 0x0000ff00) >> 8, + (data & 0x000000ff)); + + src_addr += 4; + copied++; + + if (copied % 4 == 0) + printk(BIOS_DEBUG, "\n"); + } + + printk(BIOS_DEBUG, "\n"); + return true; +} + +static void early_cl_dump_pmc_sram_data(void) +{ + u32 tmp_bar_addr = cl_get_cpu_tmp_bar(); + u32 pmc_crashLog_size = cl_get_pmc_record_size(); + + if (!cl_pmc_sram_has_mmio_access() || !tmp_bar_addr) { + printk(BIOS_DEBUG, "%s: unable to collect data.\n", __func__); + return; + } + + pmc_ipc_discovery_buf_t discovery_buf = cl_get_pmc_discovery_buf(); + + if (discovery_buf.bits.supported != 1) { + printk(BIOS_DEBUG, "PCH crashlog feature not supported.\n"); + return; + } + + /* Get the size of data to copy */ + if (discovery_buf.bits.discov_mechanism == 1) { + if (discovery_buf.bits.base_offset & BIT(31)) { + printk(BIOS_DEBUG, "PCH discovery to be used is disabled.\n"); + return; + } + printk(BIOS_DEBUG, "PMC crashLog size in discovery mode : 0x%X\n", + pmc_crashLog_size); + } else { + if (discovery_buf.bits.dis) { + printk(BIOS_DEBUG, "PCH crashlog is disabled in legacy mode.\n"); + return; + } + pmc_crashLog_size = (discovery_buf.bits.size != 0) ? + discovery_buf.bits.size : 0xC00; + printk(BIOS_DEBUG, "PMC crashLog size in legacy mode : 0x%X\n", + pmc_crashLog_size); + } + + bool pmc_sram = true; + pmc_crashlog_desc_table_t descriptor_table = cl_get_pmc_descriptor_table(); + + if (discovery_buf.bits.discov_mechanism == 1) { + for (int i = 0; i < descriptor_table.numb_regions; i++) { + early_cl_dump_data_from_sram(tmp_bar_addr, + descriptor_table.regions[i].bits.offset, + descriptor_table.regions[i].bits.size, + i, + pmc_sram); + } + } else { + early_cl_dump_data_from_sram(tmp_bar_addr, + discovery_buf.bits.base_offset, + discovery_buf.bits.size, + 0, + pmc_sram); + } +} + +static void early_cl_dump_cpu_sram_data(void) +{ + u32 cpu_bar_addr = cl_get_cpu_bar_addr(); + u32 cpu_crashLog_size = cl_get_cpu_record_size(); + + if (cpu_crashLog_size < 1) { + printk(BIOS_DEBUG, "%s: no data to collect.\n", __func__); + return; + } + + cpu_crashlog_discovery_table_t cpu_cl_disc_tab = cl_get_cpu_discovery_table(); + + printk(BIOS_DEBUG, "CPU crash data size: 0x%X bytes in 0x%X region(s).\n", + cpu_crashLog_size, cpu_cl_disc_tab.header.fields.count); + + bool pmc_sram = false; + for (int i = 0; i < cpu_cl_disc_tab.header.fields.count; i++) { + if (!cpu_cl_disc_tab.buffers[i].fields.size) { + continue; + } + + if (early_cl_dump_data_from_sram(cpu_bar_addr, + cpu_cl_disc_tab.buffers[i].fields.offset, + cpu_cl_disc_tab.buffers[i].fields.size, + i, + pmc_sram)) { + } else { + /* for CPU skip all buffers if the 1st one is not valid */ + if (i == 0) + break; + } + } +} + +void early_dump_pmc_and_cpu_crashlog_from_srams(void) +{ + early_cl_enable_bars(); + + if (!discover_crashlog()) { + printk(BIOS_DEBUG, "Early CrashLog: not found\n"); + goto end; + } + + if (pmc_crashlog_support() && cl_pmc_data_present() + && (cl_get_pmc_record_size() > 0)) { + early_cl_dump_pmc_sram_data(); + } else { + printk(BIOS_DEBUG, "Skipping PMC crashLog collection. Data not present.\n"); + } + + if (cpu_crashlog_support() && cl_cpu_data_present() + && (cl_get_cpu_record_size() > 0)) { + early_cl_dump_cpu_sram_data(); + } else { + printk(BIOS_DEBUG, "Skipping CPU crashLog collection. Data not present.\n"); + } + +end: + early_cl_disable_bars(); +} diff --git a/src/soc/intel/common/block/include/intelblocks/crashlog.h b/src/soc/intel/common/block/include/intelblocks/crashlog.h index ff80b1c..5659ec6 100644 --- a/src/soc/intel/common/block/include/intelblocks/crashlog.h +++ b/src/soc/intel/common/block/include/intelblocks/crashlog.h @@ -222,6 +222,9 @@ u32 buffer_index, bool pmc_sram); void collect_pmc_and_cpu_crashlog_from_srams(cl_node_t *head); +void early_cl_enable_bars(void); +void early_cl_disable_bars(void); +void early_dump_pmc_and_cpu_crashlog_from_srams(void); static const EFI_GUID FW_ERR_SECTION_GUID = { 0x81212a96, 0x09ed, 0x4996, { 0x94, 0x71, 0x8d, 0x72, 0x9c, 0x8e, 0x69, 0xed }
