Nico Huber has submitted this change. ( https://review.coreboot.org/c/coreboot/+/84088?usp=email )
1 is the latest approved patch-set. No files were changed between the latest approved patch-set and the submitted one. )Change subject: b64_decode-test: Properly terminate strings before comparison ......................................................................
Undefined behavior in unit-tests is no fun. assert_string_equal() expects properly zero-terminated strings. None of the encoded test strings contain a termination, hence add it manually.
Without this change, the test was often failing with a wrong error message:
[==========] tests_lib_b64_decode-test(tests): Running 1 test(s). [ RUN ] test_b64_decode [ ERROR ] --- "AB" != "AB" [ LINE ] --- tests/lib/b64_decode-test.c:38: error: Failure! [ FAILED ] test_b64_decode [==========] tests_lib_b64_decode-test(tests): 1 test(s) run.
Probably due to unprintable characters in the string. No idea why my system is more susceptible to this issue.
Change-Id: Id1bd2c3ff06bc1d4e5aa21ddd0f1d5802540999d Signed-off-by: Nico Huber nico.h@gmx.de Reviewed-on: https://review.coreboot.org/c/coreboot/+/84088 Reviewed-by: Jakub Czapiga czapiga@google.com Reviewed-by: Nicholas Sudsgaard devel+coreboot@nsudsgaard.com Reviewed-by: Paul Menzel paulepanter@mailbox.org Reviewed-by: Matt DeVillier matt.devillier@gmail.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M tests/lib/b64_decode-test.c 1 file changed, 3 insertions(+), 0 deletions(-)
Approvals: Paul Menzel: Looks good to me, but someone else must approve Matt DeVillier: Looks good to me, approved Nicholas Sudsgaard: Looks good to me, approved Jakub Czapiga: Looks good to me, approved build bot (Jenkins): Verified
diff --git a/tests/lib/b64_decode-test.c b/tests/lib/b64_decode-test.c index 189ce96..8560eb2 100644 --- a/tests/lib/b64_decode-test.c +++ b/tests/lib/b64_decode-test.c @@ -35,6 +35,9 @@ res = b64_decode((uint8_t *)messages[i].enc, strlen(messages[i].enc), decoded);
assert_int_equal(res, (strlen(messages[i].dec))); + + decoded[res] = 0x00; + assert_string_equal((const char *)decoded, messages[i].dec);
free(decoded);
