Yidi Lin has submitted this change. ( https://review.coreboot.org/c/coreboot/+/85360?usp=email )
Change subject: mb/google/rauru: Add 2nd source TAS2563 amps to support beep ......................................................................
Derive the audio amplifier from FW_CONFIG, and set up I2C and I2S for TAS2563. Also pass the corresponding GPIO(s) to the payload.
TEST=build pass and driver init ok BUG=b:357969183
Change-Id: I10cba7964d3847f2a74341b3130ff1e7bfd8d37a Signed-off-by: Darren Ye darren.ye@mediatek.corp-partner.google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/85360 Reviewed-by: Yu-Ping Wu yupingso@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Yidi Lin yidilin@google.com --- M src/mainboard/google/rauru/chromeos.c M src/mainboard/google/rauru/devicetree.cb M src/mainboard/google/rauru/gpio.h M src/mainboard/google/rauru/mainboard.c 4 files changed, 54 insertions(+), 2 deletions(-)
Approvals: Yu-Ping Wu: Looks good to me, approved Yidi Lin: Looks good to me, approved build bot (Jenkins): Verified
diff --git a/src/mainboard/google/rauru/chromeos.c b/src/mainboard/google/rauru/chromeos.c index 7f2fd05..f530396 100644 --- a/src/mainboard/google/rauru/chromeos.c +++ b/src/mainboard/google/rauru/chromeos.c @@ -2,6 +2,7 @@
#include <boot/coreboot_tables.h> #include <drivers/tpm/cr50.h> +#include <fw_config.h> #include <gpio.h>
#include "gpio.h" @@ -24,9 +25,7 @@ { struct lb_gpio chromeos_gpios[] = { { GPIO_XHCI_INIT_DONE.id, ACTIVE_HIGH, -1, "XHCI init done" }, - { GPIO_EN_SPKR.id, ACTIVE_HIGH, -1, "speaker enable" }, { GPIO_EC_AP_INT_ODL.id, ACTIVE_LOW, -1, "EC interrupt" }, - { GPIO_BEEP_ON_OD.id, ACTIVE_HIGH, -1, "beep enable" }, { GPIO_GSC_AP_INT_ODL.id, ACTIVE_HIGH, -1, "TPM interrupt" }, }; lb_add_gpios(gpios, chromeos_gpios, ARRAY_SIZE(chromeos_gpios)); @@ -37,6 +36,20 @@ }; lb_add_gpios(gpios, sd_card_gpios, ARRAY_SIZE(sd_card_gpios)); } + + struct lb_gpio nau8318_gpios[] = { + {GPIO_EN_SPKR.id, ACTIVE_HIGH, -1, "speaker enable"}, + {GPIO_BEEP_ON_OD.id, ACTIVE_HIGH, -1, "beep enable"}, + }; + + struct lb_gpio smartamp_gpios[] = { + {GPIO_EN_SPKR.id, ACTIVE_LOW, -1, "speaker reset"}, + }; + + if (fw_config_probe(FW_CONFIG(AUDIO_AMP, AMP_TAS2563))) + lb_add_gpios(gpios, smartamp_gpios, ARRAY_SIZE(smartamp_gpios)); + else + lb_add_gpios(gpios, nau8318_gpios, ARRAY_SIZE(nau8318_gpios)); }
int cr50_plat_irq_status(void) diff --git a/src/mainboard/google/rauru/devicetree.cb b/src/mainboard/google/rauru/devicetree.cb index df65b3f..7f6dc59 100644 --- a/src/mainboard/google/rauru/devicetree.cb +++ b/src/mainboard/google/rauru/devicetree.cb @@ -1,5 +1,12 @@ ## SPDX-License-Identifier: GPL-2.0-only
+fw_config + field AUDIO_AMP 28 29 + option AMP_NAU8318 0 + option AMP_TAS2563 1 + end +end + chip soc/mediatek/mt8196 device cpu_cluster 0 on end
diff --git a/src/mainboard/google/rauru/gpio.h b/src/mainboard/google/rauru/gpio.h index d513dceab..6191e05 100644 --- a/src/mainboard/google/rauru/gpio.h +++ b/src/mainboard/google/rauru/gpio.h @@ -16,6 +16,10 @@ #define GPIO_AP_FP_FW_UP_STRAP GPIO(EINT27) #define GPIO_EN_PWR_FP GPIO(PERIPHERAL_EN3)
+#define GPIO_I2SI4_BCK GPIO(I2SIN1_BCK) +#define GPIO_I2SI4_LRCK GPIO(I2SIN1_LRCK) +#define GPIO_I2SO4_D0 GPIO(I2SOUT1_DO) + void setup_chromeos_gpios(void);
#endif diff --git a/src/mainboard/google/rauru/mainboard.c b/src/mainboard/google/rauru/mainboard.c index 94a257f..9c238c7 100644 --- a/src/mainboard/google/rauru/mainboard.c +++ b/src/mainboard/google/rauru/mainboard.c @@ -2,14 +2,41 @@
#include <console/console.h> #include <device/device.h> +#include <fw_config.h> #include <gpio.h> +#include <soc/addressmap.h> #include <soc/bl31.h> #include <soc/dpm_v2.h> +#include <soc/gpio_common.h> +#include <soc/i2c.h> #include <soc/pcie.h> #include <soc/usb.h>
#include "gpio.h"
+#define AFE_SE_SECURE_CON1 (AUDIO_BASE + 0x5634) + +static void configure_i2s(void) +{ + /* Switch to normal mode */ + write32p(AFE_SE_SECURE_CON1, 0x0); + + /* SoC I2S */ + gpio_set_mode(GPIO_I2SI4_BCK, GPIO_FUNC(I2SIN1_BCK, I2SIN4_BCK)); + gpio_set_mode(GPIO_I2SI4_LRCK, GPIO_FUNC(I2SIN1_LRCK, I2SIN4_LRCK)); + gpio_set_mode(GPIO_I2SO4_D0, GPIO_FUNC(I2SOUT1_DO, I2SOUT4_DATA0)); +} + +static void configure_audio(void) +{ + if (fw_config_probe(FW_CONFIG(AUDIO_AMP, AMP_TAS2563))) { + mtk_i2c_bus_init(I2C3, I2C_SPEED_FAST); + configure_i2s(); + } + + printk(BIOS_INFO, "%s: done\n", __func__); +} + static void power_on_fpmcu(void) { /* Power on the fingerprint MCU */ @@ -26,6 +53,7 @@ { setup_usb_host(); power_on_fpmcu(); + configure_audio();
if (dpm_init()) printk(BIOS_ERR, "dpm init failed, DVFS may not work\n");
