Attention is currently required from: Cliff Huang, Furquan Shaikh, Selma Bensaid, Tim Wawrzynczak, Rizwan Qureshi, Sridhar Siricilla, Patrick Rudolph. Furquan Shaikh has uploaded a new patch set (#20) to the change originally created by Bernardo Perez Priego. ( https://review.coreboot.org/c/coreboot/+/57353 )
Change subject: soc/intel/common/cse: Add support for stitching CSE components ......................................................................
This change adds support for allowing mainboards to stitch CSE components during build time instead of adding a pre-built CSE binary. Several Kconfig options are added to allow mainboard to provide the file names for different CSE region components. This makes use of the newly added cse_serger and cse_fpt tools to create following partitions: 1. BP1 - RO 2. BP2 - RW 3. Layout
In addition to this, it accepts CSE data partition as an input using Kconfig CSE_DATA_FILE. All these partitions are then assembled together as per the following mainboard FMAP regions: 1. BP1(RO) : CSE_RO 2. BP2(RW) : CSE_RW 3. Layout : CSE_LAYOUT 4. Data : CSE_DATA
Finally, it generates the target $(OBJ_ME_BIN) which is used to put together the binary in final coreboot.rom image.
Several helper functions are added to soc/intel/Makefile.inc to allow SoCs to define which components use: 1. Decomposed files: Files decomposed from Intel release CSE binary in FPT format. 2. Input files: Mainboard provided input files using corresponding Kconfigs. 3. Dummy: Components that are required to have dummy entries in BPDT header.
These helpers are added to soc/intel/Makefile.inc to ensure that the functions are defined by the time the invocations are encountered in SoC Makefile.inc.
BUG=b:189177580
Change-Id: I8359cd49ad256703285e55bc4319c6e9c9fccb67 Signed-off-by: Bernardo Perez Priego bernardo.perez.priego@intel.com Signed-off-by: Furquan Shaikh furquan@google.com --- A src/soc/intel/Makefile.inc M src/soc/intel/common/block/cse/Kconfig M src/soc/intel/common/block/cse/Makefile.inc 3 files changed, 170 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/53/57353/20
