Patrick Georgi has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/30377 )
Change subject: x86/smm/smmhandler.S: Use tabs instead of white spaces ......................................................................
Change-Id: I7a10ddf79cf457b5dde21714b13890fc9510e7ce Signed-off-by: Elyes HAOUAS ehaouas@noos.fr Reviewed-on: https://review.coreboot.org/c/30377 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Tristan Corrick tristan@corrick.kiwi --- M src/cpu/x86/smm/smmhandler.S 1 file changed, 29 insertions(+), 29 deletions(-)
Approvals: build bot (Jenkins): Verified Tristan Corrick: Looks good to me, approved
diff --git a/src/cpu/x86/smm/smmhandler.S b/src/cpu/x86/smm/smmhandler.S index 0989e89..06c7fa4 100644 --- a/src/cpu/x86/smm/smmhandler.S +++ b/src/cpu/x86/smm/smmhandler.S @@ -107,13 +107,13 @@ ud2 untampered_lapic: #endif - movw $(smm_gdtptr16 - smm_handler_start + SMM_HANDLER_OFFSET), %bx + movw $(smm_gdtptr16 - smm_handler_start + SMM_HANDLER_OFFSET), %bx lgdtl %cs:(%bx)
- movl %cr0, %eax - andl $0x7FFAFFD1, %eax /* PG,AM,WP,NE,TS,EM,MP = 0 */ - orl $0x60000001, %eax /* CD, NW, PE = 1 */ - movl %eax, %cr0 + movl %cr0, %eax + andl $0x7FFAFFD1, %eax /* PG,AM,WP,NE,TS,EM,MP = 0 */ + orl $0x60000001, %eax /* CD, NW, PE = 1 */ + movl %eax, %cr0
/* Enable protected mode */ ljmpl $0x08, $1f @@ -124,39 +124,39 @@ wbinvd
/* Use flat data segment */ - movw $0x10, %ax - movw %ax, %ds - movw %ax, %es - movw %ax, %ss - movw %ax, %fs - movw %ax, %gs + movw $0x10, %ax + movw %ax, %ds + movw %ax, %es + movw %ax, %ss + movw %ax, %fs + movw %ax, %gs
/* Get this CPU's LAPIC ID */ - movl $(LOCAL_APIC_ADDR | LAPIC_ID), %esi - movl (%esi), %ecx - shr $24, %ecx + movl $(LOCAL_APIC_ADDR | LAPIC_ID), %esi + movl (%esi), %ecx + shr $24, %ecx
/* This is an ugly hack, and we should find a way to read the CPU index * without relying on the LAPIC ID. */ #if IS_ENABLED(CONFIG_CPU_AMD_AGESA_FAMILY15_TN) /* LAPIC IDs start from 0x10; map that to the proper core index */ - subl $0x10, %ecx + subl $0x10, %ecx #endif
/* calculate stack offset by multiplying the APIC ID * by 1024 (0x400), and save that offset in ebp. */ - shl $10, %ecx - movl %ecx, %ebp + shl $10, %ecx + movl %ecx, %ebp
/* We put the stack for each core right above * its SMM entry point. Core 0 starts at 0xa8000, * we spare 0x10 bytes for the jump to be sure. */ - movl $0xa8010, %eax - subl %ecx, %eax /* subtract offset, see above */ - movl %eax, %ebx /* Save bottom of stack in ebx */ + movl $0xa8010, %eax + subl %ecx, %eax /* subtract offset, see above */ + movl %eax, %ebx /* Save bottom of stack in ebx */
#define SMM_STACK_SIZE (0x400 - 0x10) /* clear stack */ @@ -171,13 +171,13 @@ movl %ebx, %esp
/* Get SMM revision */ - movl $0xa8000 + 0x7efc, %ebx /* core 0 address */ - subl %ebp, %ebx /* subtract core X offset */ - movl (%ebx), %eax - pushl %eax + movl $0xa8000 + 0x7efc, %ebx /* core 0 address */ + subl %ebp, %ebx /* subtract core X offset */ + movl (%ebx), %eax + pushl %eax
/* Call 32bit C handler */ - call smi_handler + call smi_handler
/* To return, just do rsm. It will "clean up" protected mode */ rsm @@ -227,14 +227,14 @@ .code16 jumptable: /* core 3 */ - ljmp $0xa000, $SMM_HANDLER_OFFSET + ljmp $0xa000, $SMM_HANDLER_OFFSET .align 1024, 0x00 /* core 2 */ - ljmp $0xa000, $SMM_HANDLER_OFFSET + ljmp $0xa000, $SMM_HANDLER_OFFSET .align 1024, 0x00 /* core 1 */ - ljmp $0xa000, $SMM_HANDLER_OFFSET + ljmp $0xa000, $SMM_HANDLER_OFFSET .align 1024, 0x00 /* core 0 */ - ljmp $0xa000, $SMM_HANDLER_OFFSET + ljmp $0xa000, $SMM_HANDLER_OFFSET .align 1024, 0x00
