Attention is currently required from: Julius Werner, Karthik Ramasubramanian. Hello build bot (Jenkins), Julius Werner, Karthik Ramasubramanian,
https://review.coreboot.org/c/coreboot/+/58203
Change subject: arch/x86/assembly_entry: Remove cpu_info ......................................................................
Since cpu_info() is no longer required to use threads, we no longer need to initialize it in romstage or earlier. This code was also incomplete since it didn't initialize the %gs segment.
BUG=b:179699789 TEST=Boot guybrush to OS
Signed-off-by: Raul E Rangel rrangel@chromium.org Change-Id: I615b718e9f035ca68ecca9f57d7f4121db0c83b0 --- M src/arch/x86/assembly_entry.S 1 file changed, 0 insertions(+), 3 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/03/58203/2
