Aaron Durbin (adurbin@chromium.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/11238
commit 88a1e23233a1f8c81f9f6e20650bee3bd0c245c7 Author: Rizwan Qureshi rizwan.qureshi@intel.com Date: Tue Jul 21 20:21:50 2015 +0530
skylake: Update Memory and Silicon Init params
Update the MemoryInit and SilicoInit params as per FSP 1.3.0 release.
Note: add SvGv and Rmt to Upd.
BRANCH=None BUG=None TEST=Build and Boot FAB3 (Kunimitsu) CQ-DEPEND=CL:*226035, CL:*226045
Original-Change-Id: I62000f6a485fee42ef733c3b548192f2bedfce49 Original-Signed-off-by: Rizwan Qureshi rizwan.qureshi@intel.com Original-Signed-off-by: Robbie Zhang robbie.zhang@intel.com Original-Reviewed-on: https://chromium-review.googlesource.com/291573 Original-Reviewed-by: Aaron Durbin adurbin@chromium.org Original-Tested-by: Wenkai Du wenkai.du@intel.com
Change-Id: Iaafa658b4e710fe512526a521cf6c529efb19bf0 Signed-off-by: Rizwan Qureshi rizwan.qureshi@intel.com Signed-off-by: Robbie Zhang robbie.zhang@intel.com --- src/soc/intel/skylake/chip.c | 176 ++++++++++++++++++++++++++++- src/soc/intel/skylake/chip.h | 15 ++- src/soc/intel/skylake/romstage/romstage.c | 180 +----------------------------- 3 files changed, 194 insertions(+), 177 deletions(-)
diff --git a/src/soc/intel/skylake/chip.c b/src/soc/intel/skylake/chip.c index b1b66fc..f79a02d 100644 --- a/src/soc/intel/skylake/chip.c +++ b/src/soc/intel/skylake/chip.c @@ -69,6 +69,7 @@ void soc_silicon_init_params(SILICON_INIT_UPD *params) { const struct device *dev; const struct soc_intel_skylake_config *config; + int i;
/* Set the parameters for SiliconInit */ dev = dev_find_slot(0, PCI_DEVFN(PCH_DEV_SLOT_LPC, 0)); @@ -76,7 +77,27 @@ void soc_silicon_init_params(SILICON_INIT_UPD *params) return; config = dev->chip_info;
+ for (i = 0; i < PchSerialIoIndexMax; i++) + params->SerialIoDevMode[i] = config->SerialIoDevMode[i]; + + params->SataSalpSupport = config->SataSalpSupport; + params->SataPortsEnable[0] = config->SataPortsEnable[0]; + params->SsicPortEnable = config->SsicPortEnable; + params->SmbusEnable = config->SmbusEnable; + params->Cio2Enable = config->Cio2Enable; + params->ScsEmmcEnabled = config->ScsEmmcEnabled; + params->ScsEmmcHs400Enabled = config->ScsEmmcHs400Enabled; + params->ScsSdCardEnabled = config->ScsSdCardEnabled; + params->IshEnable = 0; + params->EnableAzalia = config->EnableAzalia; + params->IoBufferOwnership = config->IoBufferOwnership; + params->DspEnable = config->DspEnable; + params->XdciEnable = config->XdciEnable; params->Device4Enable = config->Device4Enable; + + /* Show SPI controller if enabled in devicetree.cb */ + dev = dev_find_slot(0, PCH_DEVFN_SPI); + params->ShowSpiController = dev->enabled; }
void soc_display_silicon_init_params(const SILICON_INIT_UPD *original, @@ -84,13 +105,166 @@ void soc_display_silicon_init_params(const SILICON_INIT_UPD *original, { /* Display the parameters for SiliconInit */ printk(BIOS_SPEW, "UPD values for SiliconInit:\n"); - + soc_display_upd_value("LogoPtr", 4, + (uint32_t)original->LogoPtr, + (uint32_t)params->LogoPtr); + soc_display_upd_value("LogoSize", 4, + (uint32_t)original->LogoSize, + (uint32_t)params->LogoSize); + soc_display_upd_value("GraphicsConfigPtr", 4, + (uint32_t)original->GraphicsConfigPtr, + (uint32_t)params->GraphicsConfigPtr); + soc_display_upd_value("MicrocodeRegionBase", 4, + (uint32_t)original->MicrocodeRegionBase, + (uint32_t)params->MicrocodeRegionBase); + soc_display_upd_value("MicrocodeRegionSize", 4, + (uint32_t)original->MicrocodeRegionSize, + (uint32_t)params->MicrocodeRegionSize); + soc_display_upd_value("TurboMode", 1, + (uint32_t)original->TurboMode, + (uint32_t)params->TurboMode); soc_display_upd_value("GpioTablePtr", 4, (uint32_t)original->GpioTablePtr, (uint32_t)params->GpioTablePtr); soc_display_upd_value("Device4Enable", 1, original->Device4Enable, params->Device4Enable); + soc_display_upd_value("SataSalpSupport", 1, original->SataSalpSupport, + params->SataSalpSupport); + soc_display_upd_value("SataPortsEnable[0]", 1, + original->SataPortsEnable[0], params->SataPortsEnable[0]); + soc_display_upd_value("SataPortsEnable[1]", 1, + original->SataPortsEnable[1], params->SataPortsEnable[1]); + soc_display_upd_value("SataPortsEnable[2]", 1, + original->SataPortsEnable[2], params->SataPortsEnable[2]); + soc_display_upd_value("SataPortsEnable[3]", 1, + original->SataPortsEnable[3], params->SataPortsEnable[3]); + soc_display_upd_value("SataPortsEnable[4]", 1, + original->SataPortsEnable[4], params->SataPortsEnable[4]); + soc_display_upd_value("SataPortsEnable[5]", 1, + original->SataPortsEnable[5], params->SataPortsEnable[5]); + soc_display_upd_value("SataPortsEnable[6]", 1, + original->SataPortsEnable[6], params->SataPortsEnable[6]); + soc_display_upd_value("SataPortsEnable[7]", 1, + original->SataPortsEnable[7], params->SataPortsEnable[7]); + soc_display_upd_value("SataPortsDevSlp[0]", 1, + original->SataPortsDevSlp[0], params->SataPortsDevSlp[0]); + soc_display_upd_value("SataPortsDevSlp[1]", 1, + original->SataPortsDevSlp[1], params->SataPortsDevSlp[1]); + soc_display_upd_value("SataPortsDevSlp[2]", 1, + original->SataPortsDevSlp[2], params->SataPortsDevSlp[2]); + soc_display_upd_value("SataPortsDevSlp[3]", 1, + original->SataPortsDevSlp[3], params->SataPortsDevSlp[3]); + soc_display_upd_value("SataPortsDevSlp[4]", 1, + original->SataPortsDevSlp[4], params->SataPortsDevSlp[4]); + soc_display_upd_value("SataPortsDevSlp[5]", 1, + original->SataPortsDevSlp[5], params->SataPortsDevSlp[5]); + soc_display_upd_value("SataPortsDevSlp[6]", 1, + original->SataPortsDevSlp[6], params->SataPortsDevSlp[6]); + soc_display_upd_value("SataPortsDevSlp[7]", 1, + original->SataPortsDevSlp[7], params->SataPortsDevSlp[7]); + soc_display_upd_value("EnableAzalia", 1, + original->EnableAzalia, params->EnableAzalia); + soc_display_upd_value("DspEnable", 1, original->DspEnable, + params->DspEnable); + soc_display_upd_value("IoBufferOwnership", 1, + original->IoBufferOwnership, params->IoBufferOwnership); + soc_display_upd_value("PortUsb20Enable[0]", 1, + original->PortUsb20Enable[0], params->PortUsb20Enable[0]); + soc_display_upd_value("PortUsb20Enable[1]", 1, + original->PortUsb20Enable[1], params->PortUsb20Enable[1]); + soc_display_upd_value("PortUsb20Enable[2]", 1, + original->PortUsb20Enable[2], params->PortUsb20Enable[2]); + soc_display_upd_value("PortUsb20Enable[3]", 1, + original->PortUsb20Enable[3], params->PortUsb20Enable[3]); + soc_display_upd_value("PortUsb20Enable[4]", 1, + original->PortUsb20Enable[4], params->PortUsb20Enable[4]); + soc_display_upd_value("PortUsb20Enable[5]", 1, + original->PortUsb20Enable[5], params->PortUsb20Enable[5]); + soc_display_upd_value("PortUsb20Enable[6]", 1, + original->PortUsb20Enable[6], params->PortUsb20Enable[6]); + soc_display_upd_value("PortUsb20Enable[7]", 1, + original->PortUsb20Enable[7], params->PortUsb20Enable[7]); + soc_display_upd_value("PortUsb20Enable[8]", 1, + original->PortUsb20Enable[8], params->PortUsb20Enable[8]); + soc_display_upd_value("PortUsb20Enable[9]", 1, + original->PortUsb20Enable[9], params->PortUsb20Enable[9]); + soc_display_upd_value("PortUsb20Enable[10]", 1, + original->PortUsb20Enable[10], params->PortUsb20Enable[10]); + soc_display_upd_value("PortUsb20Enable[11]", 1, + original->PortUsb20Enable[11], params->PortUsb20Enable[11]); + soc_display_upd_value("PortUsb20Enable[12]", 1, + original->PortUsb20Enable[12], params->PortUsb20Enable[12]); + soc_display_upd_value("PortUsb20Enable[13]", 1, + original->PortUsb20Enable[13], params->PortUsb20Enable[13]); + soc_display_upd_value("PortUsb20Enable[14]", 1, + original->PortUsb20Enable[14], params->PortUsb20Enable[14]); + soc_display_upd_value("PortUsb20Enable[15]", 1, + original->PortUsb20Enable[15], params->PortUsb20Enable[15]); + soc_display_upd_value("PortUsb30Enable[0]", 1, + original->PortUsb30Enable[0], params->PortUsb30Enable[0]); + soc_display_upd_value("PortUsb30Enable[1]", 1, + original->PortUsb30Enable[1], params->PortUsb30Enable[1]); + soc_display_upd_value("PortUsb30Enable[2]", 1, + original->PortUsb30Enable[2], params->PortUsb30Enable[2]); + soc_display_upd_value("PortUsb30Enable[3]", 1, + original->PortUsb30Enable[3], params->PortUsb30Enable[3]); + soc_display_upd_value("PortUsb30Enable[4]", 1, + original->PortUsb30Enable[4], params->PortUsb30Enable[4]); + soc_display_upd_value("PortUsb30Enable[5]", 1, + original->PortUsb30Enable[5], params->PortUsb30Enable[5]); + soc_display_upd_value("PortUsb30Enable[6]", 1, + original->PortUsb30Enable[6], params->PortUsb30Enable[6]); + soc_display_upd_value("PortUsb30Enable[7]", 1, + original->PortUsb30Enable[7], params->PortUsb30Enable[7]); + soc_display_upd_value("PortUsb30Enable[8]", 1, + original->PortUsb30Enable[8], params->PortUsb30Enable[8]); + soc_display_upd_value("PortUsb30Enable[9]", 1, + original->PortUsb30Enable[9], params->PortUsb30Enable[9]); + soc_display_upd_value("XdciEnable", 1, original->XdciEnable, + params->XdciEnable); + soc_display_upd_value("SsicPortEnable", 1, original->SsicPortEnable, + params->SsicPortEnable); + soc_display_upd_value("SmbusEnable", 1, original->SmbusEnable, + params->SmbusEnable); + soc_display_upd_value("SerialIoDevMode[0]", 1, + original->SerialIoDevMode[0], params->SerialIoDevMode[0]); + soc_display_upd_value("SerialIoDevMode[1]", 1, + original->SerialIoDevMode[1], params->SerialIoDevMode[1]); + soc_display_upd_value("SerialIoDevMode[2]", 1, + original->SerialIoDevMode[2], params->SerialIoDevMode[2]); + soc_display_upd_value("SerialIoDevMode[3]", 1, + original->SerialIoDevMode[3], params->SerialIoDevMode[3]); + soc_display_upd_value("SerialIoDevMode[4]", 1, + original->SerialIoDevMode[4], params->SerialIoDevMode[4]); + soc_display_upd_value("SerialIoDevMode[5]", 1, + original->SerialIoDevMode[5], params->SerialIoDevMode[5]); + soc_display_upd_value("SerialIoDevMode[6]", 1, + original->SerialIoDevMode[6], params->SerialIoDevMode[6]); + soc_display_upd_value("SerialIoDevMode[7]", 1, + original->SerialIoDevMode[7], params->SerialIoDevMode[7]); + soc_display_upd_value("SerialIoDevMode[8]", 1, + original->SerialIoDevMode[8], params->SerialIoDevMode[8]); + soc_display_upd_value("SerialIoDevMode[9]", 1, + original->SerialIoDevMode[9], params->SerialIoDevMode[9]); + soc_display_upd_value("SerialIoDevMode[10]", 1, + original->SerialIoDevMode[10], params->SerialIoDevMode[10]); + soc_display_upd_value("Cio2Enable", 1, original->Cio2Enable, + params->Cio2Enable); + soc_display_upd_value("ScsEmmcEnabled", 1, original->ScsEmmcEnabled, + params->ScsEmmcEnabled); + soc_display_upd_value("ScsEmmcHs400Enabled", 1, + original->ScsEmmcHs400Enabled, params->ScsEmmcHs400Enabled); + soc_display_upd_value("ScsSdCardEnabled", 1, original->ScsSdCardEnabled, + params->ScsSdCardEnabled); + soc_display_upd_value("IshEnable", 1, original->IshEnable, + params->IshEnable); + soc_display_upd_value("ShowSpiController", 1, + original->ShowSpiController, params->ShowSpiController); + soc_display_upd_value("HsioMessaging", 1, original->HsioMessaging, + params->HsioMessaging); + soc_display_upd_value("Heci3Enabled", 1, original->Heci3Enabled, + params->Heci3Enabled); }
static void pci_set_subsystem(device_t dev, unsigned vendor, unsigned device) diff --git a/src/soc/intel/skylake/chip.h b/src/soc/intel/skylake/chip.h index 9fe1ed2..e962b37 100644 --- a/src/soc/intel/skylake/chip.h +++ b/src/soc/intel/skylake/chip.h @@ -128,7 +128,7 @@ struct soc_intel_skylake_config { int tcc_offset;
/* - * The following fields come from fsp_vpd.h. + * The following fields come from FspUpdVpd.h. * These are configuration values that are passed to FSP during * MemoryInit. */ @@ -141,6 +141,19 @@ struct soc_intel_skylake_config { /* Probeless Trace function */ u8 ProbelessTrace;
+ /* + * System Agent dynamic frequency configuration + * When enabled memory will be trained at two different frequencies. + * 0 = Disabled + * 1 = FixedLow + * 2 = FixedHigh + * 3 = Enabled + */ + u8 SaGv; + + /* Enable/disable Rank Margin Tool */ + u8 Rmt; + /* Lan */ u8 EnableLan;
diff --git a/src/soc/intel/skylake/romstage/romstage.c b/src/soc/intel/skylake/romstage/romstage.c index 253eaba..2ce5ce3 100644 --- a/src/soc/intel/skylake/romstage/romstage.c +++ b/src/soc/intel/skylake/romstage/romstage.c @@ -81,15 +81,12 @@ void soc_memory_init_params(MEMORY_INIT_UPD *params) { const struct device *dev; const struct soc_intel_skylake_config *config; - int i; +
/* Set the parameters for MemoryInit */ dev = dev_find_slot(0, PCI_DEVFN(PCH_DEV_SLOT_LPC, 0)); config = dev->chip_info;
- for (i = 0; i < PchSerialIoIndexMax; i++) - params->SerialIoDevMode[i] = config->SerialIoDevMode[i]; - memcpy(params->PcieRpEnable, config->PcieRpEnable, sizeof(params->PcieRpEnable)); memcpy(params->PcieRpClkReqSupport, config->PcieRpClkReqSupport, @@ -104,24 +101,9 @@ void soc_memory_init_params(MEMORY_INIT_UPD *params) params->EnableLan = config->EnableLan; params->EnableSata = config->EnableSata; params->SataMode = config->SataMode; - params->SataSalpSupport = config->SataSalpSupport; - params->SataPortsEnable[0] = config->SataPortsEnable[0]; - params->SsicPortEnable = config->SsicPortEnable; params->EnableTraceHub = config->EnableTraceHub; - params->SmbusEnable = config->SmbusEnable; - params->Cio2Enable = config->Cio2Enable; - params->ScsEmmcEnabled = config->ScsEmmcEnabled; - params->ScsEmmcHs400Enabled = config->ScsEmmcHs400Enabled; - params->ScsSdCardEnabled = config->ScsSdCardEnabled; - params->IshEnable = 0; - params->EnableAzalia = config->EnableAzalia; - params->IoBufferOwnership = config->IoBufferOwnership; - params->DspEnable = config->DspEnable; - params->XdciEnable = config->XdciEnable; - - /* Show SPI controller if enabled in devicetree.cb */ - dev = dev_find_slot(0, PCH_DEVFN_SPI); - params->ShowSpiController = dev->enabled; + params->SaGv = config->SaGv; + params->RMT = config->Rmt; }
void soc_display_memory_init_params(const MEMORY_INIT_UPD *old, @@ -248,51 +230,10 @@ void soc_display_memory_init_params(const MEMORY_INIT_UPD *old, soc_display_upd_value("IedSize", 4, old->IedSize, new->IedSize); soc_display_upd_value("TsegSize", 4, old->TsegSize, new->TsegSize); soc_display_upd_value("MmioSize", 2, old->MmioSize, new->MmioSize); - soc_display_upd_value("ProbelessTrace", 1, old->ProbelessTrace, - new->ProbelessTrace); soc_display_upd_value("EnableLan", 1, old->EnableLan, new->EnableLan); soc_display_upd_value("EnableSata", 1, old->EnableSata, new->EnableSata); soc_display_upd_value("SataMode", 1, old->SataMode, new->SataMode); - soc_display_upd_value("SataSalpSupport", 1, old->SataSalpSupport, - new->SataSalpSupport); - soc_display_upd_value("SataPortsEnable[0]", 1, old->SataPortsEnable[0], - new->SataPortsEnable[0]); - soc_display_upd_value("SataPortsEnable[1]", 1, old->SataPortsEnable[1], - new->SataPortsEnable[1]); - soc_display_upd_value("SataPortsEnable[2]", 1, old->SataPortsEnable[2], - new->SataPortsEnable[2]); - soc_display_upd_value("SataPortsEnable[3]", 1, old->SataPortsEnable[3], - new->SataPortsEnable[3]); - soc_display_upd_value("SataPortsEnable[4]", 1, old->SataPortsEnable[4], - new->SataPortsEnable[4]); - soc_display_upd_value("SataPortsEnable[5]", 1, old->SataPortsEnable[5], - new->SataPortsEnable[5]); - soc_display_upd_value("SataPortsEnable[6]", 1, old->SataPortsEnable[6], - new->SataPortsEnable[6]); - soc_display_upd_value("SataPortsEnable[7]", 1, old->SataPortsEnable[7], - new->SataPortsEnable[7]); - soc_display_upd_value("SataPortsDevSlp[0]", 1, old->SataPortsDevSlp[0], - new->SataPortsDevSlp[0]); - soc_display_upd_value("SataPortsDevSlp[1]", 1, old->SataPortsDevSlp[1], - new->SataPortsDevSlp[1]); - soc_display_upd_value("SataPortsDevSlp[2]", 1, old->SataPortsDevSlp[2], - new->SataPortsDevSlp[2]); - soc_display_upd_value("SataPortsDevSlp[3]", 1, old->SataPortsDevSlp[3], - new->SataPortsDevSlp[3]); - soc_display_upd_value("SataPortsDevSlp[4]", 1, old->SataPortsDevSlp[4], - new->SataPortsDevSlp[4]); - soc_display_upd_value("SataPortsDevSlp[5]", 1, old->SataPortsDevSlp[5], - new->SataPortsDevSlp[5]); - soc_display_upd_value("SataPortsDevSlp[6]", 1, old->SataPortsDevSlp[6], - new->SataPortsDevSlp[6]); - soc_display_upd_value("SataPortsDevSlp[7]", 1, old->SataPortsDevSlp[7], - new->SataPortsDevSlp[7]); - soc_display_upd_value("EnableAzalia", 1, old->EnableAzalia, - new->EnableAzalia); - soc_display_upd_value("DspEnable", 1, old->DspEnable, new->DspEnable); - soc_display_upd_value("IoBufferOwnership", 1, old->IoBufferOwnership, - new->IoBufferOwnership); soc_display_upd_value("EnableTraceHub", 1, old->EnableTraceHub, new->EnableTraceHub); soc_display_upd_value("PcieRpEnable[0]", 1, old->PcieRpEnable[0], @@ -455,123 +396,12 @@ void soc_display_memory_init_params(const MEMORY_INIT_UPD *old, soc_display_upd_value("PcieRpClkReqNumber[19]", 1, old->PcieRpClkReqNumber[19], new->PcieRpClkReqNumber[19]); - soc_display_upd_value("PortUsb20Enable[0]", 1, old->PortUsb20Enable[0], - new->PortUsb20Enable[0]); - soc_display_upd_value("PortUsb20Enable[1]", 1, old->PortUsb20Enable[1], - new->PortUsb20Enable[1]); - soc_display_upd_value("PortUsb20Enable[2]", 1, old->PortUsb20Enable[2], - new->PortUsb20Enable[2]); - soc_display_upd_value("PortUsb20Enable[3]", 1, old->PortUsb20Enable[3], - new->PortUsb20Enable[3]); - soc_display_upd_value("PortUsb20Enable[4]", 1, old->PortUsb20Enable[4], - new->PortUsb20Enable[4]); - soc_display_upd_value("PortUsb20Enable[5]", 1, old->PortUsb20Enable[5], - new->PortUsb20Enable[5]); - soc_display_upd_value("PortUsb20Enable[6]", 1, old->PortUsb20Enable[6], - new->PortUsb20Enable[6]); - soc_display_upd_value("PortUsb20Enable[7]", 1, old->PortUsb20Enable[7], - new->PortUsb20Enable[7]); - soc_display_upd_value("PortUsb20Enable[8]", 1, old->PortUsb20Enable[8], - new->PortUsb20Enable[8]); - soc_display_upd_value("PortUsb20Enable[9]", 1, old->PortUsb20Enable[9], - new->PortUsb20Enable[9]); - soc_display_upd_value("PortUsb20Enable[10]", 1, - old->PortUsb20Enable[10], - new->PortUsb20Enable[10]); - soc_display_upd_value("PortUsb20Enable[11]", 1, - old->PortUsb20Enable[11], - new->PortUsb20Enable[11]); - soc_display_upd_value("PortUsb20Enable[12]", 1, - old->PortUsb20Enable[12], - new->PortUsb20Enable[12]); - soc_display_upd_value("PortUsb20Enable[13]", 1, - old->PortUsb20Enable[13], - new->PortUsb20Enable[13]); - soc_display_upd_value("PortUsb20Enable[14]", 1, - old->PortUsb20Enable[14], - new->PortUsb20Enable[14]); - soc_display_upd_value("PortUsb20Enable[15]", 1, - old->PortUsb20Enable[15], - new->PortUsb20Enable[15]); - soc_display_upd_value("PortUsb30Enable[0]", 1, old->PortUsb30Enable[0], - new->PortUsb30Enable[0]); - soc_display_upd_value("PortUsb30Enable[1]", 1, old->PortUsb30Enable[1], - new->PortUsb30Enable[1]); - soc_display_upd_value("PortUsb30Enable[2]", 1, old->PortUsb30Enable[2], - new->PortUsb30Enable[2]); - soc_display_upd_value("PortUsb30Enable[3]", 1, old->PortUsb30Enable[3], - new->PortUsb30Enable[3]); - soc_display_upd_value("PortUsb30Enable[4]", 1, old->PortUsb30Enable[4], - new->PortUsb30Enable[4]); - soc_display_upd_value("PortUsb30Enable[5]", 1, old->PortUsb30Enable[5], - new->PortUsb30Enable[5]); - soc_display_upd_value("PortUsb30Enable[6]", 1, old->PortUsb30Enable[6], - new->PortUsb30Enable[6]); - soc_display_upd_value("PortUsb30Enable[7]", 1, old->PortUsb30Enable[7], - new->PortUsb30Enable[7]); - soc_display_upd_value("PortUsb30Enable[8]", 1, old->PortUsb30Enable[8], - new->PortUsb30Enable[8]); - soc_display_upd_value("PortUsb30Enable[9]", 1, old->PortUsb30Enable[9], - new->PortUsb30Enable[9]); - soc_display_upd_value("XdciEnable", 1, old->XdciEnable, - new->XdciEnable); - soc_display_upd_value("SsicPortEnable", 1, old->SsicPortEnable, - new->SsicPortEnable); - soc_display_upd_value("SmbusEnable", 1, old->SmbusEnable, - new->SmbusEnable); - soc_display_upd_value("SerialIoDevMode[0]", 1, old->SerialIoDevMode[0], - new->SerialIoDevMode[0]); - soc_display_upd_value("SerialIoDevMode[1]", 1, old->SerialIoDevMode[1], - new->SerialIoDevMode[1]); - soc_display_upd_value("SerialIoDevMode[2]", 1, old->SerialIoDevMode[2], - new->SerialIoDevMode[2]); - soc_display_upd_value("SerialIoDevMode[3]", 1, old->SerialIoDevMode[3], - new->SerialIoDevMode[3]); - soc_display_upd_value("SerialIoDevMode[4]", 1, old->SerialIoDevMode[4], - new->SerialIoDevMode[4]); - soc_display_upd_value("SerialIoDevMode[5]", 1, old->SerialIoDevMode[5], - new->SerialIoDevMode[5]); - soc_display_upd_value("SerialIoDevMode[6]", 1, old->SerialIoDevMode[6], - new->SerialIoDevMode[6]); - soc_display_upd_value("SerialIoDevMode[7]", 1, old->SerialIoDevMode[7], - new->SerialIoDevMode[7]); - soc_display_upd_value("SerialIoDevMode[8]", 1, old->SerialIoDevMode[8], - new->SerialIoDevMode[8]); - soc_display_upd_value("SerialIoDevMode[9]", 1, old->SerialIoDevMode[9], - new->SerialIoDevMode[9]); - soc_display_upd_value("SerialIoDevMode[10]", 1, - old->SerialIoDevMode[10], - new->SerialIoDevMode[10]); - soc_display_upd_value("Cio2Enable", 1, old->Cio2Enable, - new->Cio2Enable); - soc_display_upd_value("ScsEmmcEnabled", 1, old->ScsEmmcEnabled, - new->ScsEmmcEnabled); - soc_display_upd_value("ScsEmmcHs400Enabled", 1, - old->ScsEmmcHs400Enabled, - new->ScsEmmcHs400Enabled); - soc_display_upd_value("ScsSdCardEnabled", 1, old->ScsSdCardEnabled, - new->ScsSdCardEnabled); - soc_display_upd_value("IshEnable", 1, old->IshEnable, new->IshEnable); - soc_display_upd_value("ShowSpiController", 1, old->ShowSpiController, - new->ShowSpiController); - soc_display_upd_value("PttSwitch", 1, old->PttSwitch, new->PttSwitch); - soc_display_upd_value("HeciTimeouts", 1, old->HeciTimeouts, - new->HeciTimeouts); - soc_display_upd_value("HsioMessaging", 1, old->HsioMessaging, - new->HsioMessaging); - soc_display_upd_value("Heci3Enabled", 1, old->Heci3Enabled, - new->Heci3Enabled); soc_display_upd_value("IgdDvmt50PreAlloc", 1, old->IgdDvmt50PreAlloc, new->IgdDvmt50PreAlloc); - soc_display_upd_value("PrimaryDisplay", 1, old->PrimaryDisplay, - new->PrimaryDisplay); soc_display_upd_value("InternalGfx", 1, old->InternalGfx, new->InternalGfx); soc_display_upd_value("ApertureSize", 1, old->ApertureSize, new->ApertureSize); - soc_display_upd_value("SkipExtGfxScan", 1, old->SkipExtGfxScan, - new->SkipExtGfxScan); - soc_display_upd_value("ScanExtGfxForLegacyOpRom", 1, - old->ScanExtGfxForLegacyOpRom, - new->ScanExtGfxForLegacyOpRom); + soc_display_upd_value("SaGv", 1, old->SaGv, new->SaGv); + soc_display_upd_value("RMT", 1, old->RMT, new->RMT); }
