Attention is currently required from: David Wu, Tarun Tuli, Martin L Roth.
Hello build bot (Jenkins), David Wu, Tarun Tuli, Martin L Roth, Dtrain Hsu, Kangheui Won, Reka Norman, Tyler Wang, Eric Lai,
https://review.coreboot.org/c/coreboot/+/71170
to look at the new patch set (#14).
Change subject: mb/google/nissa/var/craask: Modify GPIOs for NVMe ......................................................................
Modify NVMe clkreq pin to GPP_D7 from GPP_D6.The design change is for commonality of GPIO settings. To reserve craask GPIO table and add craaskneto/craaskino's NVMe GPIO setting. In the change, clkreq# will be 2 and clksrc is still 1.
BUG=b:259211172 TEST=Verify on reworked craask DUT to boot up from NVMe.
Change-Id: If45c1a87144d5370b1ca2525295fb7947639362f Signed-off-by: Ren Kuo ren.kuo@quanta.corp-partner.google.com --- M src/mainboard/google/brya/variants/craask/fw_config.c M src/mainboard/google/brya/variants/craask/gpio.c M src/mainboard/google/brya/variants/craask/overridetree.cb 3 files changed, 25 insertions(+), 39 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/70/71170/14
