Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/4256
commit 40556974c47ea5883e69dccaca27c4831dcb89cc Author: Stefan Reinauer reinauer@chromium.org Date: Wed Jun 19 13:47:46 2013 -0700
Drop obsolete CONSOLE_LOGBUF
This was used by Ron 13ys ago and was never used again ever since.
Change-Id: I8ae8a570d67fa0b34b17c9e3709845687f73c724 Signed-off-by: Stefan Reinauer reinauer@google.com Reviewed-on: https://gerrit.chromium.org/gerrit/59320 Reviewed-by: Stefan Reinauer reinauer@chromium.org Tested-by: Stefan Reinauer reinauer@chromium.org Commit-Queue: Stefan Reinauer reinauer@chromium.org --- payloads/libpayload/include/coreboot_tables.h | 2 +- src/console/Kconfig | 4 ---- src/console/Makefile.inc | 1 - src/console/logbuf_console.c | 21 --------------------- src/include/boot/coreboot_tables.h | 2 +- src/lib/coreboot_table.c | 6 ++---- 6 files changed, 4 insertions(+), 32 deletions(-)
diff --git a/payloads/libpayload/include/coreboot_tables.h b/payloads/libpayload/include/coreboot_tables.h index 375d33b..26838e8 100644 --- a/payloads/libpayload/include/coreboot_tables.h +++ b/payloads/libpayload/include/coreboot_tables.h @@ -133,7 +133,7 @@ struct cb_console { #define CB_TAG_CONSOLE_SERIAL8250 0 #define CB_TAG_CONSOLE_VGA 1 // OBSOLETE #define CB_TAG_CONSOLE_BTEXT 2 // OBSOLETE -#define CB_TAG_CONSOLE_LOGBUF 3 +#define CB_TAG_CONSOLE_LOGBUF 3 // OBSOLETE #define CB_TAG_CONSOLE_SROM 4 // OBSOLETE #define CB_TAG_CONSOLE_EHCI 5
diff --git a/src/console/Kconfig b/src/console/Kconfig index c23f862..12b942d 100644 --- a/src/console/Kconfig +++ b/src/console/Kconfig @@ -377,10 +377,6 @@ config DEFAULT_CONSOLE_LOGLEVEL help Map the log level config names to an integer.
-config CONSOLE_LOGBUF - bool - default n - config NO_POST bool "Don't show any POST codes" default n diff --git a/src/console/Makefile.inc b/src/console/Makefile.inc index 9edec3c..62be1d2 100644 --- a/src/console/Makefile.inc +++ b/src/console/Makefile.inc @@ -22,7 +22,6 @@ ramstage-$(CONFIG_CONSOLE_SERIAL8250) += uart8250_console.c ramstage-$(CONFIG_CONSOLE_SERIAL8250MEM) += uart8250mem_console.c ramstage-$(CONFIG_SPKMODEM) += spkmodem_console.c ramstage-$(CONFIG_USBDEBUG) += usbdebug_console.c -ramstage-$(CONFIG_CONSOLE_LOGBUF) += logbuf_console.c ramstage-$(CONFIG_CONSOLE_NE2K) += ne2k_console.c ramstage-$(CONFIG_CONSOLE_CBMEM) += cbmem_console.c ramstage-$(CONFIG_CONSOLE_QEMU_DEBUGCON) += qemu_debugcon_console.c diff --git a/src/console/logbuf_console.c b/src/console/logbuf_console.c deleted file mode 100644 index a76791d..0000000 --- a/src/console/logbuf_console.c +++ /dev/null @@ -1,21 +0,0 @@ -#include <console/console.h> - -#define LOGBUF_SIZE 1024 - -// KEEP THIS GLOBAL. -// I need the address so I can watch it with the ARIUM hardware. RGM. -char logbuf[LOGBUF_SIZE]; -int logbuf_offset = 0; - -static void logbuf_tx_byte(unsigned char byte) -{ - logbuf[logbuf_offset] = byte; - logbuf_offset = (logbuf_offset +1) % LOGBUF_SIZE; -} - -static const struct console_driver __console = { - .init = 0, - .tx_byte = logbuf_tx_byte, - .rx_byte = 0, - .tst_byte = 0, -};} diff --git a/src/include/boot/coreboot_tables.h b/src/include/boot/coreboot_tables.h index 87819ce..aa8409a 100644 --- a/src/include/boot/coreboot_tables.h +++ b/src/include/boot/coreboot_tables.h @@ -163,7 +163,7 @@ struct lb_console { #define LB_TAG_CONSOLE_SERIAL8250 0 #define LB_TAG_CONSOLE_VGA 1 // OBSOLETE #define LB_TAG_CONSOLE_BTEXT 2 // OBSOLETE -#define LB_TAG_CONSOLE_LOGBUF 3 +#define LB_TAG_CONSOLE_LOGBUF 3 // OBSOLETE #define LB_TAG_CONSOLE_SROM 4 // OBSOLETE #define LB_TAG_CONSOLE_EHCI 5 #define LB_TAG_CONSOLE_SERIAL8250MEM 6 diff --git a/src/lib/coreboot_table.c b/src/lib/coreboot_table.c index a0a806d..772729a 100644 --- a/src/lib/coreboot_table.c +++ b/src/lib/coreboot_table.c @@ -137,7 +137,8 @@ static struct lb_serial *lb_serial(struct lb_header *header) #endif }
-#if CONFIG_CONSOLE_SERIAL || CONFIG_CONSOLE_LOGBUF || CONFIG_USBDEBUG +#if CONFIG_CONSOLE_SERIAL8250 || CONFIG_CONSOLE_SERIAL8250MEM || \ + CONFIG_CONSOLE_SERIAL_UART || CONFIG_USBDEBUG static void add_console(struct lb_header *header, u16 consoletype) { struct lb_console *console; @@ -157,9 +158,6 @@ static void lb_console(struct lb_header *header) #if CONFIG_CONSOLE_SERIAL8250MEM || CONFIG_CONSOLE_SERIAL_UART add_console(header, LB_TAG_CONSOLE_SERIAL8250MEM); #endif -#if CONFIG_CONSOLE_LOGBUF - add_console(header, LB_TAG_CONSOLE_LOGBUF); -#endif #if CONFIG_USBDEBUG add_console(header, LB_TAG_CONSOLE_EHCI); #endif
