Andrey Petrov has uploaded this change for review. ( https://review.coreboot.org/20075
Change subject: mainboard/intel/cannonlake_rvp: Initial set of board files ......................................................................
Change-Id: I82bd5c785e451f02b827765c54d432517afd7de0 Signed-off-by: Andrey Petrov andrey.petrov@intel.com --- A src/mainboard/intel/cannonlake_rvp/Kconfig A src/mainboard/intel/cannonlake_rvp/Kconfig.name A src/mainboard/intel/cannonlake_rvp/Makefile.inc A src/mainboard/intel/cannonlake_rvp/devicetree.cb A src/mainboard/intel/cannonlake_rvp/romstage.c 5 files changed, 63 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/75/20075/1
diff --git a/src/mainboard/intel/cannonlake_rvp/Kconfig b/src/mainboard/intel/cannonlake_rvp/Kconfig new file mode 100644 index 0000000..b2223b0 --- /dev/null +++ b/src/mainboard/intel/cannonlake_rvp/Kconfig @@ -0,0 +1,30 @@ +if BOARD_INTEL_CANNONLAKE_RVP + +config BOARD_SPECIFIC_OPTIONS + def_bool y + select BOARD_ROMSIZE_KB_16384 + select SOC_INTEL_CANNONLAKE + +config MAINBOARD_DIR + string + default "intel/cannonlake_rvp" + +config MAINBOARD_PART_NUMBER + string + default "Cannonlake RVP" + +config MAINBOARD_VENDOR + string + default "Intel" + +config IFD_BIN_PATH + string + depends on HAVE_IFD_BIN + default "3rdparty/blobs/mainboard/$(CONFIG_MAINBOARD_DIR)/descriptor.bin" + +config ME_BIN_PATH + string + depends on HAVE_ME_BIN + default "3rdparty/blobs/mainboard/$(CONFIG_MAINBOARD_DIR)/me.bin" + +endif diff --git a/src/mainboard/intel/cannonlake_rvp/Kconfig.name b/src/mainboard/intel/cannonlake_rvp/Kconfig.name new file mode 100644 index 0000000..4935603 --- /dev/null +++ b/src/mainboard/intel/cannonlake_rvp/Kconfig.name @@ -0,0 +1,2 @@ +config BOARD_INTEL_CANNONLAKE_RVP + bool "Cannonlake DDR4 RVP" diff --git a/src/mainboard/intel/cannonlake_rvp/Makefile.inc b/src/mainboard/intel/cannonlake_rvp/Makefile.inc new file mode 100644 index 0000000..75c34dd --- /dev/null +++ b/src/mainboard/intel/cannonlake_rvp/Makefile.inc @@ -0,0 +1 @@ +#Nothing here yet diff --git a/src/mainboard/intel/cannonlake_rvp/devicetree.cb b/src/mainboard/intel/cannonlake_rvp/devicetree.cb new file mode 100644 index 0000000..c7001a4 --- /dev/null +++ b/src/mainboard/intel/cannonlake_rvp/devicetree.cb @@ -0,0 +1,9 @@ +chip soc/intel/cannonlake + + device cpu_cluster 0 on + device lapic 0 on end + end + + device domain 0 on + end +end diff --git a/src/mainboard/intel/cannonlake_rvp/romstage.c b/src/mainboard/intel/cannonlake_rvp/romstage.c new file mode 100644 index 0000000..64752e2 --- /dev/null +++ b/src/mainboard/intel/cannonlake_rvp/romstage.c @@ -0,0 +1,21 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2010 coresystems GmbH + * Copyright (C) 2014 Google Inc. + * Copyright (C) 2017 Intel Corporation. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ +//Nothing here yet, but file needed for build.
