Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/61701 )
Change subject: mb/google/var/taeko: Add gpios to lock ......................................................................
Variant should honor locked gpios from baseboard, but not the last. Variant can add more gpios to lock if needed.
BUG=b:216583542 TEST='emerge-brya coreboot chromeos-bootimage', flash and verify that taeko boots successfully to kernel.
Signed-off-by: Eric Lai ericr_lai@compal.corp-partner.google.com Change-Id: Ib30815dbe99342b6afd9af9f1aa9ff61c9a4fe80 Reviewed-on: https://review.coreboot.org/c/coreboot/+/61701 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Nick Vaccaro nvaccaro@google.com Reviewed-by: Subrata Banik subratabanik@google.com --- M src/mainboard/google/brya/variants/taeko/gpio.c 1 file changed, 13 insertions(+), 13 deletions(-)
Approvals: build bot (Jenkins): Verified Nick Vaccaro: Looks good to me, approved Subrata Banik: Looks good to me, approved
diff --git a/src/mainboard/google/brya/variants/taeko/gpio.c b/src/mainboard/google/brya/variants/taeko/gpio.c index a97aef8..2005760 100644 --- a/src/mainboard/google/brya/variants/taeko/gpio.c +++ b/src/mainboard/google/brya/variants/taeko/gpio.c @@ -33,9 +33,9 @@ /* B2 : VRALERT# ==> NC */ PAD_NC(GPP_B2, NONE), /* B3 : PROC_GP2 ==> NC */ - PAD_NC(GPP_B3, NONE), + PAD_NC_LOCK(GPP_B3, NONE, LOCK_CONFIG), /* B15 : TIME_SYNC0 ==> NC */ - PAD_NC(GPP_B15, NONE), + PAD_NC_LOCK(GPP_B15, NONE, LOCK_CONFIG),
/* C3 : SML0CLK ==> NC */ PAD_NC(GPP_C3, NONE), @@ -45,23 +45,23 @@ PAD_NC(GPP_C6, NONE),
/* D3 : ISH_GP3 ==> NC */ - PAD_NC(GPP_D3, NONE), + PAD_NC_LOCK(GPP_D3, NONE, LOCK_CONFIG), /* D5 : SRCCLKREQ0# ==> SSD_CLKREQ_ODL */ PAD_CFG_NF(GPP_D5, NONE, DEEP, NF1), /* D9 : ISH_SPI_CS# ==> NC */ - PAD_NC(GPP_D9, NONE), + PAD_NC_LOCK(GPP_D9, NONE, LOCK_CONFIG), /* D10 : ISH_SPI_CLK ==> NC */ - PAD_NC(GPP_D10, NONE), + PAD_NC_LOCK(GPP_D10, NONE, LOCK_CONFIG), /* D13 : ISH_UART0_RXD ==> NC */ - PAD_NC(GPP_D13, NONE), + PAD_NC_LOCK(GPP_D13, NONE, LOCK_CONFIG), /* D14 : ISH_UART0_TXD ==> NC */ - PAD_NC(GPP_D14, NONE), + PAD_NC_LOCK(GPP_D14, NONE, LOCK_CONFIG), /* D15 : ISH_UART0_RTS# ==> NC */ - PAD_NC(GPP_D15, NONE), + PAD_NC_LOCK(GPP_D15, NONE, LOCK_CONFIG), /* D16 : ISH_UART0_CTS# ==> NC */ - PAD_NC(GPP_D16, NONE), + PAD_NC_LOCK(GPP_D16, NONE, LOCK_CONFIG), /* D17 : UART1_RXD ==> NC */ - PAD_NC(GPP_D17, NONE), + PAD_NC_LOCK(GPP_D17, NONE, LOCK_CONFIG),
/* E0 : SATAXPCIE0 ==> NC */ PAD_NC(GPP_E0, NONE), @@ -70,11 +70,11 @@ /* E5 : SATA_DEVSLP1 ==> NC */ PAD_NC(GPP_E5, NONE), /* E10 : THC0_SPI1_CS# ==> NC */ - PAD_NC(GPP_E10, NONE), + PAD_NC_LOCK(GPP_E10, NONE, LOCK_CONFIG), /* E16 : RSVD_TP ==> NC */ PAD_NC(GPP_E16, NONE), /* E17 : THC0_SPI1_INT# ==> NC */ - PAD_NC(GPP_E17, NONE), + PAD_NC_LOCK(GPP_E17, NONE, LOCK_CONFIG), /* E18 : DDP1_CTRLCLK ==> NC */ PAD_NC(GPP_E18, NONE), /* E19 : DDP1_CTRLDATA ==> NC */ @@ -106,7 +106,7 @@ /* H9 : I2C4_SCL ==> NC */ PAD_NC(GPP_H9, NONE), /* H13 : I2C7_SCL ==> EN_PP3300_SD */ - PAD_CFG_GPO(GPP_H13, 1, DEEP), + PAD_CFG_GPO_LOCK(GPP_H13, 1, LOCK_CONFIG), /* H15 : DDPB_CTRLCLK ==> NC */ PAD_NC(GPP_H15, NONE), /* H17 : DDPB_CTRLDATA ==> NC */
