Werner Zeh has posted comments on this change. ( https://review.coreboot.org/19978 )
Change subject: rx6110sa: Add possibility to use both I2C and SMBus for the RTC ......................................................................
Patch Set 4:
(3 comments)
https://review.coreboot.org/#/c/19978/4/src/drivers/i2c/rx6110sa/rx6110sa.c File src/drivers/i2c/rx6110sa/rx6110sa.c:
Line 16:
Why the extra line?
It slipped in, will remove it.
PS4, Line 32: CONFIG_RX6110SA_USE_SMBUS
IS_ENABLED(...)
Oh yes, definitively.
Line 41: uint8_t val;
You probably want to initialize this to 0 as there isn't any error checking
Sure.
