Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/11055
commit 3d9c72ee7ef82d69b5186d40e6c742a7b7b878cf Author: Rizwan Qureshi rizwan.qureshi@intel.com Date: Thu Jul 23 22:31:51 2015 +0530
Add SoC specific microcode update check in ramstage
Some Intel SoCs which support SGX feature, report the microcode patch revision one less than the actual revision. This results in the same microcode patch getting loaded again. Add a SoC specific check to avoid relading the same patch.
BUG=chrome-os-partner:42046 BRANCH=None TEST=Built for glados and tested on RVP3 CQ-DEPEND=CL:286054
Change-Id: Iab4c34c6c55119045947f598e89352867c67dcb8 Signed-off-by: Patrick Georgi pgeorgi@chromium.org Original-Commit-Id: ab2ed73db3581cd432f9bc84acca47f5e53a0e9b Original-Change-Id: I4f7bf9c841e5800668208c11b0afcf8dba48a775 Original-Signed-off-by: Rizwan Qureshi rizwan.qureshi@intel.com Original-Reviewed-on: https://chromium-review.googlesource.com/287513 Original-Reviewed-by: Aaron Durbin adurbin@chromium.org --- src/cpu/intel/microcode/microcode.c | 16 ++++++++++++++++ src/include/cpu/intel/microcode.h | 4 ++++ 2 files changed, 20 insertions(+)
diff --git a/src/cpu/intel/microcode/microcode.c b/src/cpu/intel/microcode/microcode.c index 3492bfd..1ee1299 100644 --- a/src/cpu/intel/microcode/microcode.c +++ b/src/cpu/intel/microcode/microcode.c @@ -28,6 +28,7 @@ #include <cpu/cpu.h> #include <cpu/x86/msr.h> #include <cpu/intel/microcode.h> +#include <rules.h>
#if !defined(__PRE_RAM__) #include <cbfs.h> @@ -95,6 +96,14 @@ void intel_microcode_load_unlocked(const void *microcode_patch) if (current_rev == m->rev) return;
+#if ENV_RAMSTAGE + /*SoC specific check to update microcode*/ + if (soc_ucode_update_required(current_rev, m->rev) < 0) { + printk(BIOS_DEBUG, "Skip microcode update\n"); + return; + } +#endif + msr.lo = (unsigned long)m + sizeof(struct microcode); msr.hi = 0; wrmsr(0x79, msr); @@ -202,3 +211,10 @@ void intel_update_microcode_from_cbfs(void) spin_unlock(µcode_lock); #endif } + +#if ENV_RAMSTAGE +__attribute__((weak)) int soc_ucode_update_required(u32 currrent_patch_id, u32 new_patch_id) +{ + return 0; +} +#endif diff --git a/src/include/cpu/intel/microcode.h b/src/include/cpu/intel/microcode.h index d2fa1b7..d951a63 100644 --- a/src/include/cpu/intel/microcode.h +++ b/src/include/cpu/intel/microcode.h @@ -29,6 +29,10 @@ const void *intel_microcode_find(void); * well as ensuring the microcode matches the family and revision (i.e. with * intel_microcode_find()). */ void intel_microcode_load_unlocked(const void *microcode_patch); + +/* SoC specific check to determine if microcode update is really + * required, return value of < 0 will skip microcode update. */ +int soc_ucode_update_required(u32 currrent_patch_id, u32 new_patch_id); #endif
#endif
