Aaron Durbin (adurbin@chromium.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/11182
commit d21947ea0d6f5e6bc178a442de21fe3204a5e9ef Author: Aaron Durbin adurbin@chromium.org Date: Tue Aug 4 14:02:54 2015 -0500
skylake: fill out gen_pmcon_* bitfields
Open coding bitfields is really annoying as no one knows what they are unless you have a doc in front of you. Fill in the bitfields for the GEN_PMCON_A and GEN_PMCON_B registers.
BUG=chrome-os-partner:43522 BRANCH=None TEST=Built and booted glados.
Original-Change-Id: Id48de68eaa3896c17d5da2ffb0bcf17062f73e5e Original-Signed-off-by: Aaron Durbin adurbin@chromium.org Original-Reviewed-on: https://chromium-review.googlesource.com/290336 Original-Reviewed-by: Duncan Laurie dlaurie@chromium.org
Change-Id: I968be9736419e26a771e0a0c3c964d540fbb1efe Signed-off-by: Aaron Durbin adurbin@chromium.org --- src/soc/intel/skylake/include/soc/pmc.h | 29 +++++++++++++++++++++++++++++ src/soc/intel/skylake/pmc.c | 13 +++++++++---- 2 files changed, 38 insertions(+), 4 deletions(-)
diff --git a/src/soc/intel/skylake/include/soc/pmc.h b/src/soc/intel/skylake/include/soc/pmc.h index 5b5d663..5774d46 100644 --- a/src/soc/intel/skylake/include/soc/pmc.h +++ b/src/soc/intel/skylake/include/soc/pmc.h @@ -32,12 +32,41 @@ #define SCIS_IRQ23 7 #define PWRMBASE 0x48 #define GEN_PMCON_A 0xa0 +#define DC_PP_DIS (1 << 30) +#define DSX_PP_DIS (1 << 29) +#define AG3_PP_EN (1 << 28) +#define SX_PP_EN (1 << 27) +#define DISB (1 << 23) +#define MEM_SR (1 << 21) +#define MS4V (1 << 18) +#define GBL_RST_STS (1 << 16) +#define ALLOW_ICLK_PLL_SD_INC0 (1 << 15) +#define MPHY_CRICLK_GATE_OVER (1 << 14) +#define ALLOW_OPI_PLL_SD_INC0 (1 << 13) +#define ALLOW_SPXB_CG_INC0 (1 << 12) +#define BIOS_PCI_EXP_EN (1 << 10) +#define PWRBTN_LVL (1 << 9) +#define ALLOW_L1LOW_C0 (1 << 7) +#define ALLOW_L1LOW_OPI_ON (1 << 6) #define SMI_LOCK (1 << 4) #define GEN_PMCON_B 0xa4 #define SLP_STR_POL_LOCK (1 << 18) #define ACPI_BASE_LOCK (1 << 17) #define SUS_PWR_FLR (1 << 14) +#define WOL_EN_OVRD (1 << 13) +#define DIS_SLP_X_STRCH_SUS_UP (1 << 12) +#define SLP_S3_MIN_ASST_WDTH_MASK (0x3 << 10) +#define SLP_S3_MIN_ASST_WDTH_60USEC (0 << 10) +#define SLP_S3_MIN_ASST_WDTH_1MS (1 << 10) +#define SLP_S3_MIN_ASST_WDTH_50MS (2 << 10) +#define SLP_S3_MIN_ASST_WDTH_2S (3 << 10) #define HOST_RST_STS (1 << 9) +#define S4MAW_MASK (0x3 << 4) +#define S4MAW_1S (1 << 4) +#define S4MAW_2S (2 << 4) +#define S4MAW_3S (3 << 4) +#define S4MAW_4S (0 << 4) +#define S4ASE (1 << 3) #define RTC_BATTERY_DEAD (1 << 2) #define PWR_FLR (1 << 1) #define SLEEP_AFTER_POWER_FAIL (1 << 0) diff --git a/src/soc/intel/skylake/pmc.c b/src/soc/intel/skylake/pmc.c index b95441c..b62a288 100644 --- a/src/soc/intel/skylake/pmc.c +++ b/src/soc/intel/skylake/pmc.c @@ -39,12 +39,15 @@ #endif
static const struct reg_script pch_pmc_misc_init_script[] = { - /* Setup SLP signal assertion, SLP_S4=4s, SLP_S3=50ms */ - REG_PCI_RMW16(GEN_PMCON_B, ~((3 << 4)|(1 << 10)), - (1 << 3)|(1 << 11)|(1 << 12)), + /* SLP_S4=4s, SLP_S3=50ms, disable SLP_X stretching after SUS loss. */ + REG_PCI_RMW16(GEN_PMCON_B, + ~(S4MAW_MASK | SLP_S3_MIN_ASST_WDTH_MASK), + S4MAW_4S | SLP_S3_MIN_ASST_WDTH_50MS | + DIS_SLP_X_STRCH_SUS_UP), + /* Enable SCI and clear SLP requests. */ REG_IO_RMW32(ACPI_BASE_ADDRESS + PM1_CNT, ~SLP_TYP, SCI_EN), /* Indicate DRAM init done for MRC */ - REG_PCI_OR8(GEN_PMCON_A, (1 << 23)), + REG_PCI_OR8(GEN_PMCON_A, DISB), REG_SCRIPT_END };
@@ -237,6 +240,8 @@ static void pmc_init(struct device *dev) /* Initialize power management */ pch_power_options();
+ /* Note that certain bits may be cleared from running script as + * certain bit fields are write 1 to clear. */ reg_script_run_on_dev(dev, pch_pmc_misc_init_script); pch_set_acpi_mode();
