Felix Held (felix-coreboot@felixheld.de) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/12297
commit 2b2826e6c1deb24026c996772f40e4d4b3a44d2f Author: Felix Held felix-coreboot@felixheld.de Date: Tue Nov 3 00:59:49 2015 +0100
asus/kgpe-d16: fix DIMMSetVoltages
The RAM voltages can be set per socket, which contains two nodes.
Only reset the allowed voltages per socket before processing a new socket and not after every node.
Change-Id: Ia0e47676c7a3eebd56a17ab6de0e9690bf8cf703 Signed-off-by: Felix Held felix-coreboot@felixheld.de --- src/mainboard/asus/kgpe-d16/romstage.c | 20 ++++++++++++++------ 1 file changed, 14 insertions(+), 6 deletions(-)
diff --git a/src/mainboard/asus/kgpe-d16/romstage.c b/src/mainboard/asus/kgpe-d16/romstage.c index 76cbb8e..b8789b3 100644 --- a/src/mainboard/asus/kgpe-d16/romstage.c +++ b/src/mainboard/asus/kgpe-d16/romstage.c @@ -172,7 +172,7 @@ void DIMMSetVoltages(struct MCTStatStruc *pMCTstat, uint8_t node; uint8_t socket; uint8_t allowed_voltages = 0xf; /* The mainboard VRMs allow 1.15V, 1.25V, 1.35V, and 1.5V */ - uint8_t node_allowed_voltages; + uint8_t socket_allowed_voltages; uint32_t set_voltage = 0;
if (get_option(&nvram, "minimum_memory_voltage") == CB_SUCCESS) { @@ -190,28 +190,36 @@ void DIMMSetVoltages(struct MCTStatStruc *pMCTstat, } }
+ /* unneeded, but makes the compiler happy */ + socket_allowed_voltages = allowed_voltages; + for (node = 0; node < MAX_NODES_SUPPORTED; node++) { socket = node / 2; - node_allowed_voltages = allowed_voltages; struct DCTStatStruc *pDCTstat; pDCTstat = pDCTstatA + node; + + /* reset socket_allowed_voltages before processing each socket */ + if (!(node % 2)) + socket_allowed_voltages = allowed_voltages; + if (pDCTstat->NodePresent) { for (dimm = 0; dimm < MAX_DIMMS_SUPPORTED; dimm++) { if (pDCTstat->DIMMValid & (1 << dimm)) { - node_allowed_voltages &= pDCTstat->DimmSupportedVoltages[dimm]; + socket_allowed_voltages &= pDCTstat->DimmSupportedVoltages[dimm]; } } }
+ /* set voltage per socket after processing last contained node */ if (pDCTstat->NodePresent && (node % 2)) { /* Set voltages */ - if (node_allowed_voltages & 0x8) { + if (socket_allowed_voltages & 0x8) { set_voltage = 1150; set_ddr3_voltage(socket, 3); - } else if (node_allowed_voltages & 0x4) { + } else if (socket_allowed_voltages & 0x4) { set_voltage = 1250; set_ddr3_voltage(socket, 2); - } else if (node_allowed_voltages & 0x2) { + } else if (socket_allowed_voltages & 0x2) { set_voltage = 1350; set_ddr3_voltage(socket, 1); } else {
