Martin L Roth has submitted this change. ( https://review.coreboot.org/c/coreboot/+/63576 )
Change subject: lint/checkpatch.pl: Update to v5.18-2 lines related to "CONFIG_" ......................................................................
Signed-off-by: Elyes Haouas ehaouas@noos.fr Change-Id: I8589d053871ad9ac64ae2f8fc380710be8e4556b Reviewed-on: https://review.coreboot.org/c/coreboot/+/63576 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Martin L Roth martinroth@google.com --- M util/lint/checkpatch.pl 1 file changed, 87 insertions(+), 51 deletions(-)
Approvals: build bot (Jenkins): Verified Martin L Roth: Looks good to me, approved
diff --git a/util/lint/checkpatch.pl b/util/lint/checkpatch.pl index a67e6b0..6defb99 100755 --- a/util/lint/checkpatch.pl +++ b/util/lint/checkpatch.pl @@ -71,6 +71,7 @@ my $allow_c99_comments = 1; my $git_command ='git'; # coreboot my $tabsize = 8; +my ${CONFIG_} = "CONFIG_"; # For coreboot jenkins # If taint mode is enabled, Untaint the path - files must be in /bin, /usr/bin or /usr/local/bin if ( ${^TAINT} ) { @@ -141,6 +142,8 @@ --typedefsfile Read additional types from this file --color[=WHEN] Use colors 'always', 'never', or only when output is a terminal ('auto'). Default is 'auto'. + --kconfig-prefix=WORD use WORD as a prefix for Kconfig symbols (default + ${CONFIG_}) -h, --help, --version display this help and exit
When FILE is - read standard input. @@ -327,6 +330,7 @@ 'color=s' => $color, 'no-color' => $color, #keep old behaviors of -nocolor 'nocolor' => $color, #keep old behaviors of -nocolor + 'kconfig-prefix=s' => ${CONFIG_}, 'h|help' => $help, 'version' => $help ) or $help = 2; @@ -2382,6 +2386,28 @@ return length(expand_tabs(substr($line, 0, $last_openparen))) + 1; }
+sub get_raw_comment { + my ($line, $rawline) = @_; + my $comment = ''; + + for my $i (0 .. (length($line) - 1)) { + if (substr($line, $i, 1) eq "$;") { + $comment .= substr($rawline, $i, 1); + } + } + + return $comment; +} + +sub exclude_global_initialisers { + my ($realfile) = @_; + + # Do not check for BPF programs (tools/testing/selftests/bpf/progs/*.c, samples/bpf/*_kern.c, *.bpf.c). + return $realfile =~ m@^tools/testing/selftests/bpf/progs/.*.c$@ || + $realfile =~ m@^samples/bpf/.*_kern.c$@ || + $realfile =~ m@/bpf/.*.bpf.c$@; +} + sub process { my $filename = shift;
@@ -2538,6 +2564,7 @@ $sline =~ s/$;/ /g; #with comments as spaces
my $rawline = $rawlines[$linenr - 1]; + my $raw_comment = get_raw_comment($line, $rawline);
# check if it's a mode change, rename or start of a patch if (!$in_commit_log && @@ -3016,51 +3043,47 @@ # Kconfig supports named choices), so use a word boundary # (\b) rather than a whitespace character (\s) $line =~ /^+\s*(?:config|menuconfig|choice)\b/) { - my $length = 0; - my $cnt = $realcnt; - my $ln = $linenr + 1; - my $f; - my $is_start = 0; - my $is_end = 0; - for (; $cnt > 0 && defined $lines[$ln - 1]; $ln++) { - $f = $lines[$ln - 1]; - $cnt-- if ($lines[$ln - 1] !~ /^-/); - $is_end = $lines[$ln - 1] =~ /^+/; + my $ln = $linenr; + my $needs_help = 0; + my $has_help = 0; + my $help_length = 0; + while (defined $lines[$ln]) { + my $f = $lines[$ln++];
next if ($f =~ /^-/); - last if (!$file && $f =~ /^@@/); + last if ($f !~ /^[+ ]/); # !patch context
- if ($lines[$ln - 1] =~ /^+\s*(?:bool|tristate|prompt)\s*["']/) { - $is_start = 1; - } elsif ($lines[$ln - 1] =~ /^+\s*(?:help|---help---)\s*$/) { - if ($lines[$ln - 1] =~ "---help---") { - WARN("CONFIG_DESCRIPTION", - "prefer 'help' over '---help---' for new help texts\n" . $herecurr); - } - $length = -1; + if ($f =~ /^+\s*(?:bool|tristate|prompt)\s*["']/) { + $needs_help = 1; + next; + } + if ($f =~ /^+\s*help\s*$/) { + $has_help = 1; + next; }
- $f =~ s/^.//; - $f =~ s/#.*//; - $f =~ s/^\s+//; - next if ($f =~ /^$/); + $f =~ s/^.//; # strip patch context [+ ] + $f =~ s/#.*//; # strip # directives + $f =~ s/^\s+//; # strip leading blanks + next if ($f =~ /^$/); # skip blank lines
+ # At the end of this Kconfig block: # This only checks context lines in the patch # and so hopefully shouldn't trigger false # positives, even though some of these are # common words in help texts - if ($f =~ /^\s*(?:config|menuconfig|choice|endchoice| - if|endif|menu|endmenu|source)\b/x) { - $is_end = 1; + if ($f =~ /^(?:config|menuconfig|choice|endchoice| + if|endif|menu|endmenu|source)\b/x) { last; } - $length++; + $help_length++ if ($has_help); } - if ($is_start && $is_end && $length < $min_conf_desc_length) { + if ($needs_help && + $help_length < $min_conf_desc_length) { + my $stat_real = get_stat_real($linenr, $ln - 1); WARN("CONFIG_DESCRIPTION", - "please write a paragraph that describes the config symbol fully\n" . $herecurr); + "please write a help paragraph that fully describes the config symbol\n" . "$here\n$stat_real\n"); } - #print "is_start<$is_start> is_end<$is_end> length<$length>\n"; }
# check for MAINTAINERS entries that don't have the right form @@ -6388,28 +6411,41 @@ } }
-# check for case / default statements not preceded by break/fallthrough/switch - if ($line =~ /^.\s*(?:case\s+(?:$Ident|$Constant)\s*|default):/) { - my $has_break = 0; - my $has_statement = 0; - my $count = 0; - my $prevline = $linenr; - while ($prevline > 1 && ($file || $count < 3) && !$has_break) { - $prevline--; - my $rline = $rawlines[$prevline - 1]; - my $fline = $lines[$prevline - 1]; - last if ($fline =~ /^@@/); - next if ($fline =~ /^-/); - next if ($fline =~ /^.(?:\s*(?:case\s+(?:$Ident|$Constant)[\s$;]*|default):[\s$;]*)*$/); - $has_break = 1 if ($rline =~ /fall[\s_-]*(through|thru)/i); - next if ($fline =~ /^.[\s$;]*$/); - $has_statement = 1; - $count++; - $has_break = 1 if ($fline =~ /\bswitch\b|\b(?:break\s*;[\s$;]*$|exit\s*(\b|return\b|goto\b|continue\b)/); +# check for IS_ENABLED() without CONFIG_<FOO> ($rawline for comments too) + if ($rawline =~ /\bIS_ENABLED\s*(\s*(\w+)\s*)/ && $1 !~ /^${CONFIG_}/) { + WARN("IS_ENABLED_CONFIG", + "IS_ENABLED($1) is normally used as IS_ENABLED(${CONFIG_}$1)\n" . $herecurr); + } + +# check for #if defined CONFIG_<FOO> || defined CONFIG_<FOO>_MODULE + if ($line =~ /^+\s*#\s*if\s+defined(?:\s*(?\s*|\s+)(${CONFIG_}[A-Z_]+)\s*)?\s*||\s*defined(?:\s*(?\s*|\s+)\1_MODULE\s*)?\s*$/) { + my $config = $1; + if (WARN("PREFER_IS_ENABLED", + "Prefer IS_ENABLED(<FOO>) to ${CONFIG_}<FOO> || ${CONFIG_}<FOO>_MODULE\n" . $herecurr) && + $fix) { + $fixed[$fixlinenr] = "+#if IS_ENABLED($config)"; } - if (!$has_break && $has_statement) { - WARN("MISSING_BREAK", - "Possible switch case/default not preceded by break or fallthrough comment\n" . $herecurr); + } + +# check for /* fallthrough */ like comment, prefer fallthrough; + my @fallthroughs = ( + 'fallthrough', + '@fallthrough@', + 'lint -fallthrough[ \t]*', + 'intentional(?:ly)?[ \t]*fall(?:(?:s | |-)[Tt]|t)hr(?:ough|u|ew)', + '(?:else,?\s*)?FALL(?:S | |-)?THR(?:OUGH|U|EW)[ \t.!]*(?:-[^\n\r]*)?', + 'Fall(?:(?:s | |-)[Tt]|t)hr(?:ough|u|ew)[ \t.!]*(?:-[^\n\r]*)?', + 'fall(?:s | |-)?thr(?:ough|u|ew)[ \t.!]*(?:-[^\n\r]*)?', + ); + if ($raw_comment ne '') { + foreach my $ft (@fallthroughs) { + if ($raw_comment =~ /$ft/) { + my $msg_level = &WARN; + $msg_level = &CHK if ($file); + &{$msg_level}("PREFER_FALLTHROUGH", + "Prefer 'fallthrough;' over fallthrough comment\n" . $herecurr); + last; + } } }
