Attention is currently required from: Arthur Heymans, Nico Huber, Angel Pons. Arthur Heymans has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/59131 )
Change subject: device/pci_device.c: Improve pci_bridge_route() readability ......................................................................
Patch Set 3:
(2 comments)
File src/device/pci_device.c:
https://review.coreboot.org/c/coreboot/+/59131/comment/ee899fdc_f76773d6 PS1, Line 1337: u32 raw; : struct { : u8 primary; : u8 secondary; : u8 subordinate; : u8 _latency; : } __packed;
Depends on the implementation of pci_write_config32(). IMHO, it should be aware of the endianness and then converting the word here locally would actually break things.
Usually, I would recommend explicit serialization / de-serialization. But in this case don't we actually want to write 3 registers? Would it hurt to use pci_write_config8()?
For readability, I'd simply use plain, simple variables, e.g.
u8 primary, secondary, subordinate; if (state == PCI_ROUTE_CLOSE) { primary = 0x00; secondary = 0xff; subordinate = 0xfe; } else if (...) { ... } else { ... }
Then, either serialize the results into a u32 in a single spot and use pci_write_config32(), or just use pci_write_config8() three times.
Thanks. Went for the 3 config writes, because it makes it easier to search for.
https://review.coreboot.org/c/coreboot/+/59131/comment/c1f455b7_f3ea1607 PS2, Line 1351: : buses.primary = 0xff; : buses.secondary = 0xfe;
Should be `secondary` and `subordinate`, right?
Uh I missed the << 8 probably. Fixed it.
