Hello Rajneesh Bhardwaj, Rushikesh S Kadam, build bot (Jenkins), Furquan Shaikh,
https://review.coreboot.org/22237
Change subject: soc/intel/skylake: Turnoff XTAL Disqualification for XTAL Shutdown ......................................................................
24MHz Crystal Shutdown Qualification bit (0x31Ch[22]) need to be '0' if system can enter S0ix with XTAL Shutdown. Note: This patch should be applyied togather with below two patches so that system can enter S0ix with XTAL Shutdown. 1. https://review.coreboot.org/c/22236 2. https://review.coreboot.org/c/22240
BUG=None BRANCH=None TEST=Build for kabylake board with XTAL Disqualification off in pmc.h And read 24MHz Crystal Shutdown Qualification bit (0x31Ch[22])
iotools mmio_read32 0xFE00031c should return '0' on BIT[22]
Change-Id: I8abc6e9b88b3bc25cf865824aa14b292ac0524ef Signed-off-by: Roy Mingi Park roy.mingi.park@intel.com --- M src/soc/intel/skylake/include/soc/pmc.h 1 file changed, 1 insertion(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/37/22237/2
