Kyösti Mälkki (kyosti.malkki@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/5135
commit 56e9caf5f1b4a6a469ac396e45bf1d2c1c3fe85f Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Fri Jan 31 07:38:21 2014 +0200
ne2k: Move under drivers/net
Change-Id: I978b6009c09c31be4429f57be40ef82f438f7574 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- src/arch/x86/lib/romcc_console.c | 2 +- src/drivers/Makefile.inc | 1 + src/drivers/net/Makefile.inc | 2 + src/drivers/net/ne2k.c | 458 +++++++++++++++++++++++++++++++++++++++ src/drivers/net/ns8390.h | 110 ++++++++++ src/lib/Makefile.inc | 3 - src/lib/ne2k.c | 458 --------------------------------------- src/lib/ns8390.h | 110 ---------- 8 files changed, 572 insertions(+), 572 deletions(-)
diff --git a/src/arch/x86/lib/romcc_console.c b/src/arch/x86/lib/romcc_console.c index 13ee1f0..db84f9e 100644 --- a/src/arch/x86/lib/romcc_console.c +++ b/src/arch/x86/lib/romcc_console.c @@ -35,7 +35,7 @@ #include "lib/uart8250.c" #endif #if CONFIG_CONSOLE_NE2K -#include "lib/ne2k.c" +#include "drivers/net/ne2k.c" #endif
static void __console_tx_byte(unsigned char byte) diff --git a/src/drivers/Makefile.inc b/src/drivers/Makefile.inc index 4b63a8f..eb86a4c 100644 --- a/src/drivers/Makefile.inc +++ b/src/drivers/Makefile.inc @@ -24,6 +24,7 @@ subdirs-y += generic subdirs-y += i2c subdirs-y += intel subdirs-y += maxim +subdirs-y += net subdirs-y += oxford subdirs-y += parade subdirs-y += realtek diff --git a/src/drivers/net/Makefile.inc b/src/drivers/net/Makefile.inc new file mode 100644 index 0000000..9b3008d --- /dev/null +++ b/src/drivers/net/Makefile.inc @@ -0,0 +1,2 @@ +romstage-$(CONFIG_CONSOLE_NE2K) += ne2k.c +ramstage-$(CONFIG_CONSOLE_NE2K) += ne2k.c diff --git a/src/drivers/net/ne2k.c b/src/drivers/net/ne2k.c new file mode 100644 index 0000000..b678d79 --- /dev/null +++ b/src/drivers/net/ne2k.c @@ -0,0 +1,458 @@ +/* +ETHERBOOT - BOOTP/TFTP Bootstrap Program + +Author: Martin Renters + Date: May/94 + + This code is based heavily on David Greenman's if_ed.c driver + + Copyright (C) 1993-1994, David Greenman, Martin Renters. + This software may be used, modified, copied, distributed, and sold, in + both source and binary form provided that the above copyright and these + terms are retained. Under no circumstances are the authors responsible for + the proper functioning of this software, nor do the authors assume any + responsibility for damages incurred with its use. + +Multicast support added by Timothy Legge (timlegge@users.sourceforge.net) 09/28/2003 +Relocation support added by Ken Yap (ken_yap@users.sourceforge.net) 28/12/02 +3c503 support added by Bill Paul (wpaul@ctr.columbia.edu) on 11/15/94 +SMC8416 support added by Bill Paul (wpaul@ctr.columbia.edu) on 12/25/94 +3c503 PIO support added by Jim Hague (jim.hague@acm.org) on 2/17/98 +RX overrun by Klaus Espenlaub (espenlaub@informatik.uni-ulm.de) on 3/10/99 + parts taken from the Linux 8390 driver (by Donald Becker and Paul Gortmaker) +SMC8416 PIO support added by Andrew Bettison (andrewb@zip.com.au) on 4/3/02 + based on the Linux 8390 driver (by Donald Becker and Paul Gortmaker) + +(C) Rudolf Marek r.marek@assembler.cz Simplify for RTL8029, Add coreboot glue logic + +*/ + +#define ETH_ALEN 6 /* Size of Ethernet address */ +#define ETH_HLEN 14 /* Size of ethernet header */ +#define ETH_ZLEN 60 /* Minimum packet */ +#define ETH_FRAME_LEN 1514 /* Maximum packet */ +#define ETH_DATA_ALIGN 2 /* Amount needed to align the data after an ethernet header */ +#define ETH_MAX_MTU (ETH_FRAME_LEN-ETH_HLEN) + +#include "ns8390.h" +#include <ip_checksum.h> +#include <console/ne2k.h> +#include <arch/io.h> + +#define MEM_SIZE MEM_32768 +#define TX_START 64 +#define RX_START (64 + D8390_TXBUF_SIZE) + +static unsigned int get_count(unsigned int eth_nic_base) +{ + unsigned int ret; + outb(D8390_COMMAND_RD2 + D8390_COMMAND_PS1, + eth_nic_base + D8390_P0_COMMAND); + + ret = inb(eth_nic_base + 8 + 0) | (inb(eth_nic_base + 8 + 1) << 8); + + outb(D8390_COMMAND_RD2 + D8390_COMMAND_PS0, + eth_nic_base + D8390_P0_COMMAND); + return ret; +} + +static void set_count(unsigned int eth_nic_base, unsigned int what) +{ + outb(D8390_COMMAND_RD2 + D8390_COMMAND_PS1, + eth_nic_base + D8390_P0_COMMAND); + + outb(what & 0xff,eth_nic_base + 8); + outb((what >> 8) & 0xff,eth_nic_base + 8 + 1); + + outb(D8390_COMMAND_RD2 + D8390_COMMAND_PS0, + eth_nic_base + D8390_P0_COMMAND); +} + +static void eth_pio_write(unsigned char *src, unsigned int dst, unsigned int cnt, + unsigned int eth_nic_base) +{ + outb(D8390_COMMAND_RD2 | D8390_COMMAND_STA, eth_nic_base + D8390_P0_COMMAND); + outb(D8390_ISR_RDC, eth_nic_base + D8390_P0_ISR); + outb(cnt, eth_nic_base + D8390_P0_RBCR0); + outb(cnt >> 8, eth_nic_base + D8390_P0_RBCR1); + outb(dst, eth_nic_base + D8390_P0_RSAR0); + outb(dst >> 8, eth_nic_base + D8390_P0_RSAR1); + outb(D8390_COMMAND_RD1 | D8390_COMMAND_STA, eth_nic_base + D8390_P0_COMMAND); + + while (cnt--) { + outb(*(src++), eth_nic_base + NE_ASIC_OFFSET + NE_DATA); + } + /* + #warning "Add timeout" + */ + /* wait for operation finish */ + while ((inb(eth_nic_base + D8390_P0_ISR) & D8390_ISR_RDC) != D8390_ISR_RDC) + ; +} + +void ne2k_append_data(unsigned char *d, int len, unsigned int base) +{ + eth_pio_write(d, (TX_START << 8) + 42 + get_count(base), len, base); + set_count(base, get_count(base)+len); +} + +#ifdef __ROMCC__ + +void eth_pio_write_byte(int data, unsigned short dst, unsigned int eth_nic_base) +{ + outb(D8390_COMMAND_RD2 | D8390_COMMAND_STA, eth_nic_base + D8390_P0_COMMAND); + outb(D8390_ISR_RDC, eth_nic_base + D8390_P0_ISR); + outb(1, eth_nic_base + D8390_P0_RBCR0); + outb(0, eth_nic_base + D8390_P0_RBCR1); + outb(dst, eth_nic_base + D8390_P0_RSAR0); + outb(dst >> 8, eth_nic_base + D8390_P0_RSAR1); + outb(D8390_COMMAND_RD1 | D8390_COMMAND_STA, eth_nic_base + D8390_P0_COMMAND); + outb(data, eth_nic_base + NE_ASIC_OFFSET + NE_DATA); + + while ((inb(eth_nic_base + D8390_P0_ISR) & D8390_ISR_RDC) != D8390_ISR_RDC) + ; +} + +void ne2k_append_data_byte(int d, unsigned int base) +{ + eth_pio_write_byte(d, (TX_START << 8) + 42 + get_count(base), base); + set_count(base, get_count(base)+1); +} + +static unsigned char eth_pio_read_byte(unsigned int src, + unsigned int eth_nic_base) +{ + outb(D8390_COMMAND_RD2 | D8390_COMMAND_STA, eth_nic_base + D8390_P0_COMMAND); + outb(0, eth_nic_base + D8390_P0_RBCR0); + outb(1, eth_nic_base + D8390_P0_RBCR1); + outb(src, eth_nic_base + D8390_P0_RSAR0); + outb(src >> 8, eth_nic_base + D8390_P0_RSAR1); + outb(D8390_COMMAND_RD0 | D8390_COMMAND_STA, eth_nic_base + D8390_P0_COMMAND); + return inb(eth_nic_base + NE_ASIC_OFFSET + NE_DATA); +} + + +/* Variation of compute_ip_checksum which works on SRAM */ +unsigned long compute_ip_checksum_from_sram(unsigned short offset, unsigned short length, + unsigned int eth_nic_base) +{ + unsigned long sum; + unsigned long i; + /* In the most straight forward way possible, + * compute an ip style checksum. + */ + sum = 0; + for(i = 0; i < length; i++) { + unsigned long v; + v = eth_pio_read_byte((TX_START << 8)+i+offset, eth_nic_base); + if (i & 1) { + v <<= 8; + } + /* Add the new value */ + sum += v; + /* Wrap around the carry */ + if (sum > 0xFFFF) { + sum = (sum + (sum >> 16)) & 0xFFFF; + } + } + return (~((sum & 0xff) | (((sum >> 8) & 0xff) << 8) )) & 0xffff; +} + + +static void str2ip_load(const char *str, unsigned short offset, unsigned int eth_nic_base) +#else +static void str2ip(const char *str, unsigned char *ip) +#endif +{ + unsigned char c, i = 0; + int acc = 0; + + do { + c = str[i]; + if ((c >= '0') && (c <= '9')) { + acc *= 10; + acc += (c - '0'); + } else { +#ifdef __ROMCC__ + eth_pio_write_byte(acc, (TX_START << 8)+offset, eth_nic_base); + offset++; +#else + *ip++ = acc; +#endif + acc = 0; + } + i++; + } while (c != '\0'); +} + +#ifdef __ROMCC__ +static void str2mac_load(const char *str, unsigned short offset, unsigned int eth_nic_base) +#else +static void str2mac(const char *str, unsigned char *mac) +#endif +{ + unsigned char c, i = 0; + int acc = 0; + + do { + + c = str[i]; + if ((c >= '0') && (c <= '9')) { + acc *= 16; + acc += (c - '0'); + } else if ((c >= 'a') && (c <= 'f')) { + acc *= 16; + acc += ((c - 'a') + 10) ; + } else if ((c >= 'A') && (c <= 'F')) { + acc *= 16; + acc += ((c - 'A') + 10) ; + } else { +#ifdef __ROMCC__ + eth_pio_write_byte(acc, ((TX_START << 8)+offset), eth_nic_base); + offset++; +#else + *mac++ = acc; +#endif + acc = 0; + } + + i++; + } while (c != '\0'); +} + + +#ifndef __ROMCC__ +static void ns8390_tx_header(unsigned int eth_nic_base, int pktlen) { + unsigned short chksum; + unsigned char hdr[] = { +#else +static const unsigned char hdr[] = { +#endif + /* + * ETHERNET HDR + */ + + // destination macaddr + 0x02, 0x00, 0x00, 0x00, 0x00, 0x01, + /* source mac */ + 0x02, 0x00, 0x00, 0xC0, 0xFF, 0xEE, + /* ethtype (IP) */ + 0x08, 0x00, + /* + * IP HDR + */ + 0x45, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, + /* TTL, proto (UDP), chksum_hi, chksum_lo, IP0, IP1, IP2, IP3, */ + 0x40, 0x11, 0x0, 0x0, 0x7f, 0x0, 0x0, 0x1, + /* IP0, IP1, IP2, IP3 */ + 0xff, 0xff, 0xff, 0xff, + /* + * UDP HDR + */ + /* SRC PORT DST PORT (2bytes each), ulen, uchksum (must be zero or correct */ + 0x1a, 0x0b, 0x1a, 0x0a, 0x00, 0x9, 0x00, 0x00, + }; + +#ifndef __ROMCC__ + str2mac(CONFIG_CONSOLE_NE2K_DST_MAC, &hdr[0]); + str2ip(CONFIG_CONSOLE_NE2K_DST_IP, &hdr[30]); + str2ip(CONFIG_CONSOLE_NE2K_SRC_IP, &hdr[26]); + + /* zero checksum */ + hdr[24] = 0; + hdr[25] = 0; + + /* update IP packet len */ + hdr[16] = ((28 + pktlen) >> 8) & 0xff; + hdr[17] = (28 + pktlen) & 0xff; + + /* update UDP len */ + hdr[38] = (8 + pktlen) >> 8; + hdr[39] = 8 + pktlen; + + chksum = compute_ip_checksum(&hdr[14], 20); + + hdr[25] = chksum >> 8; + hdr[24] = chksum; + eth_pio_write(hdr, (TX_START << 8), sizeof(hdr), eth_nic_base); +} + + +#else + +/* ROMCC madness */ +static void ns8390_tx_header(unsigned int eth_nic_base, int pktlen) +{ + unsigned short chksum; + + eth_pio_write(hdr, (TX_START << 8), sizeof(hdr), eth_nic_base); + + str2mac_load(CONFIG_CONSOLE_NE2K_DST_MAC, 0, eth_nic_base); + + str2ip_load(CONFIG_CONSOLE_NE2K_DST_IP, 30, eth_nic_base); + str2ip_load(CONFIG_CONSOLE_NE2K_SRC_IP, 26, eth_nic_base); + /* zero checksum */ + eth_pio_write_byte(0, (TX_START << 8)+24, eth_nic_base); + eth_pio_write_byte(0, (TX_START << 8)+25, eth_nic_base); + + /* update IP packet len */ + eth_pio_write_byte(((28 + pktlen) >> 8) & 0xff, (TX_START << 8)+16, eth_nic_base); + eth_pio_write_byte( (28 + pktlen) & 0xff, (TX_START << 8)+17, eth_nic_base); + + /* update UDP len */ + eth_pio_write_byte((8 + pktlen) >> 8, (TX_START << 8)+38, eth_nic_base); + eth_pio_write_byte( 8 + pktlen, (TX_START << 8)+39, eth_nic_base); + + chksum = compute_ip_checksum_from_sram(14, 20, eth_nic_base); + + eth_pio_write_byte(chksum, (TX_START << 8)+24, eth_nic_base); + eth_pio_write_byte(chksum >> 8, (TX_START << 8)+25, eth_nic_base); +} + +#endif + +void ne2k_transmit(unsigned int eth_nic_base) { + unsigned int pktsize; + unsigned int len = get_count(eth_nic_base); + + // so place whole header inside chip buffer + ns8390_tx_header(eth_nic_base, len); + + // commit sending now + outb(D8390_COMMAND_PS0 | D8390_COMMAND_RD2 | D8390_COMMAND_STA, eth_nic_base + D8390_P0_COMMAND); + + outb(TX_START, eth_nic_base + D8390_P0_TPSR); + + pktsize = 42 + len; + if (pktsize < 64) + pktsize = 64; + + outb(pktsize, eth_nic_base + D8390_P0_TBCR0); + outb(pktsize >> 8, eth_nic_base + D8390_P0_TBCR1); + + outb(D8390_ISR_PTX, eth_nic_base + D8390_P0_ISR); + + outb(D8390_COMMAND_PS0 | D8390_COMMAND_TXP | D8390_COMMAND_RD2 | D8390_COMMAND_STA, eth_nic_base + D8390_P0_COMMAND); + + /* wait for operation finish */ + while ((inb(eth_nic_base + D8390_P0_ISR) & D8390_ISR_PTX) != D8390_ISR_PTX) ; + + set_count(eth_nic_base, 0); +} + +#ifdef __PRE_RAM__ + +static void ns8390_reset(unsigned int eth_nic_base) +{ + int i; + + outb(D8390_COMMAND_PS0 | D8390_COMMAND_RD2 | + D8390_COMMAND_STP, eth_nic_base + D8390_P0_COMMAND); + + outb(0x48, eth_nic_base + D8390_P0_DCR); + outb(0, eth_nic_base + D8390_P0_RBCR0); + outb(0, eth_nic_base + D8390_P0_RBCR1); + outb(0x20, eth_nic_base + D8390_P0_RCR); + outb(2, eth_nic_base + D8390_P0_TCR); + outb(TX_START, eth_nic_base + D8390_P0_TPSR); + outb(RX_START, eth_nic_base + D8390_P0_PSTART); + outb(MEM_SIZE, eth_nic_base + D8390_P0_PSTOP); + outb(MEM_SIZE - 1, eth_nic_base + D8390_P0_BOUND); + outb(0xFF, eth_nic_base + D8390_P0_ISR); + outb(0, eth_nic_base + D8390_P0_IMR); + + outb(D8390_COMMAND_PS1 | + D8390_COMMAND_RD2 | D8390_COMMAND_STP, + eth_nic_base + D8390_P0_COMMAND); + + for (i = 0; i < ETH_ALEN; i++) + outb(0x0C, eth_nic_base + D8390_P1_PAR0 + i); + + for (i = 0; i < ETH_ALEN; i++) + outb(0xFF, eth_nic_base + D8390_P1_MAR0 + i); + + outb(RX_START, eth_nic_base + D8390_P1_CURR); + outb(D8390_COMMAND_PS0 | + D8390_COMMAND_RD2 | D8390_COMMAND_STA, + eth_nic_base + D8390_P0_COMMAND); + outb(0xFF, eth_nic_base + D8390_P0_ISR); + outb(0, eth_nic_base + D8390_P0_TCR); + outb(4, eth_nic_base + D8390_P0_RCR); + set_count(eth_nic_base, 0); +} + + +int ne2k_init(unsigned int eth_nic_base) { + + device_t dev; + unsigned char c; + + /* Power management controller */ + dev = pci_locate_device(PCI_ID(0x10ec, + 0x8029), 0); + + if (dev == PCI_DEV_INVALID) + return 0; + + pci_write_config32(dev, 0x10, eth_nic_base | 1 ); + pci_write_config8(dev, 0x4, 0x1); + + c = inb(eth_nic_base + NE_ASIC_OFFSET + NE_RESET); + outb(c, eth_nic_base + NE_ASIC_OFFSET + NE_RESET); + + (void) inb(0x84); + + outb(D8390_COMMAND_STP | D8390_COMMAND_RD2, eth_nic_base + D8390_P0_COMMAND); + outb(D8390_RCR_MON, eth_nic_base + D8390_P0_RCR); + + outb(D8390_DCR_FT1 | D8390_DCR_LS, eth_nic_base + D8390_P0_DCR); + outb(MEM_8192, eth_nic_base + D8390_P0_PSTART); + outb(MEM_16384, eth_nic_base + D8390_P0_PSTOP); + + ns8390_reset(eth_nic_base); + return 1; +} + +#else + +#include <delay.h> +#include <stdlib.h> +#include <string.h> +#include <arch/io.h> + +#include <console/console.h> +#include <device/device.h> +#include <device/pci.h> +#include <device/pci_ids.h> +#include <device/pci_ops.h> + +static void read_resources(struct device *dev) +{ + struct resource *res; + + res = new_resource(dev, PCI_BASE_ADDRESS_0); + res->base = CONFIG_CONSOLE_NE2K_IO_PORT; + res->size = 32; + res->align = 5; + res->gran = 5; + res->limit = res->base + res->size - 1; + res->flags = IORESOURCE_IO | IORESOURCE_FIXED | IORESOURCE_STORED | + IORESOURCE_ASSIGNED; + return; +} + +static struct device_operations ne2k_ops = { + .read_resources = read_resources, + .set_resources = pci_dev_set_resources, + .enable_resources = pci_dev_enable_resources, + .init = 0, + .scan_bus = 0, +}; + +static const struct pci_driver ne2k_driver __pci_driver = { + .ops = &ne2k_ops, + .vendor = 0x10ec, + .device = 0x8029, +}; + +#endif diff --git a/src/drivers/net/ns8390.h b/src/drivers/net/ns8390.h new file mode 100644 index 0000000..eeffe45 --- /dev/null +++ b/src/drivers/net/ns8390.h @@ -0,0 +1,110 @@ +/************************************************************************** +ETHERBOOT - BOOTP/TFTP Bootstrap Program + +Author: Martin Renters + Date: Jun/94 + +**************************************************************************/ + +//FILE_LICENCE ( BSD2 ); + +#define VENDOR_NONE 0 +#define VENDOR_WD 1 +#define VENDOR_NOVELL 2 +#define VENDOR_3COM 3 + +#define FLAG_PIO 0x01 +#define FLAG_16BIT 0x02 +#define FLAG_790 0x04 + +#define MEM_8192 32 +#define MEM_16384 64 +#define MEM_32768 128 + +#define ISA_MAX_ADDR 0x400 + +/************************************************************************** +NE1000/2000 definitions +**************************************************************************/ +#define NE_ASIC_OFFSET 0x10 +#define NE_RESET 0x0F /* Used to reset card */ +#define NE_DATA 0x00 /* Used to read/write NIC mem */ + +#define COMPEX_RL2000_TRIES 200 + +/************************************************************************** +8390 Register Definitions +**************************************************************************/ +#define D8390_P0_COMMAND 0x00 +#define D8390_P0_PSTART 0x01 +#define D8390_P0_PSTOP 0x02 +#define D8390_P0_BOUND 0x03 +#define D8390_P0_TSR 0x04 +#define D8390_P0_TPSR 0x04 +#define D8390_P0_TBCR0 0x05 +#define D8390_P0_TBCR1 0x06 +#define D8390_P0_ISR 0x07 +#define D8390_P0_RSAR0 0x08 +#define D8390_P0_RSAR1 0x09 +#define D8390_P0_RBCR0 0x0A +#define D8390_P0_RBCR1 0x0B +#define D8390_P0_RSR 0x0C +#define D8390_P0_RCR 0x0C +#define D8390_P0_TCR 0x0D +#define D8390_P0_DCR 0x0E +#define D8390_P0_IMR 0x0F +#define D8390_P1_COMMAND 0x00 +#define D8390_P1_PAR0 0x01 +#define D8390_P1_PAR1 0x02 +#define D8390_P1_PAR2 0x03 +#define D8390_P1_PAR3 0x04 +#define D8390_P1_PAR4 0x05 +#define D8390_P1_PAR5 0x06 +#define D8390_P1_CURR 0x07 +#define D8390_P1_MAR0 0x08 + +#define D8390_COMMAND_PS0 0x0 /* Page 0 select */ +#define D8390_COMMAND_PS1 0x40 /* Page 1 select */ +#define D8390_COMMAND_PS2 0x80 /* Page 2 select */ +#define D8390_COMMAND_RD2 0x20 /* Remote DMA control */ +#define D8390_COMMAND_RD1 0x10 +#define D8390_COMMAND_RD0 0x08 +#define D8390_COMMAND_TXP 0x04 /* transmit packet */ +#define D8390_COMMAND_STA 0x02 /* start */ +#define D8390_COMMAND_STP 0x01 /* stop */ + +#define D8390_RCR_MON 0x20 /* monitor mode */ + +#define D8390_DCR_FT1 0x40 +#define D8390_DCR_LS 0x08 /* Loopback select */ +#define D8390_DCR_WTS 0x01 /* Word transfer select */ + +#define D8390_ISR_PRX 0x01 /* successful recv */ +#define D8390_ISR_PTX 0x02 /* successful xmit */ +#define D8390_ISR_RXE 0x04 /* receive error */ +#define D8390_ISR_TXE 0x08 /* transmit error */ +#define D8390_ISR_OVW 0x10 /* Overflow */ +#define D8390_ISR_CNT 0x20 /* Counter overflow */ +#define D8390_ISR_RDC 0x40 /* Remote DMA complete */ +#define D8390_ISR_RST 0x80 /* reset */ + +#define D8390_RSTAT_PRX 0x01 /* successful recv */ +#define D8390_RSTAT_CRC 0x02 /* CRC error */ +#define D8390_RSTAT_FAE 0x04 /* Frame alignment error */ +#define D8390_RSTAT_OVER 0x08 /* FIFO overrun */ + +#define D8390_TXBUF_SIZE 6 +#define D8390_RXBUF_END 32 +#define D8390_PAGE_SIZE 256 + +struct ringbuffer { + unsigned char status; + unsigned char next; + unsigned short len; +}; +/* + * Local variables: + * c-basic-offset: 8 + * End: + */ + diff --git a/src/lib/Makefile.inc b/src/lib/Makefile.inc index 3bad3fd..79ceebf 100644 --- a/src/lib/Makefile.inc +++ b/src/lib/Makefile.inc @@ -47,7 +47,6 @@ romstage-$(CONFIG_COMPRESS_RAMSTAGE) += lzma.c romstage-$(CONFIG_CACHE_AS_RAM) += ramtest.c romstage-$(CONFIG_CONSOLE_SERIAL8250) += uart8250.c romstage-$(CONFIG_CONSOLE_SERIAL8250MEM) += uart8250mem.c -romstage-$(CONFIG_CONSOLE_NE2K) += ne2k.c
ifeq ($(CONFIG_EARLY_CBMEM_INIT),y) romstage-$(CONFIG_COLLECT_TIMESTAMPS) += timestamp.c @@ -113,8 +112,6 @@ ramstage-y += cbmem_info.c ramstage-y += hexdump.c romstage-y += hexdump.c
-ramstage-$(CONFIG_CONSOLE_NE2K) += ne2k.c - romstage-$(CONFIG_CACHE_RELOCATED_RAMSTAGE_OUTSIDE_CBMEM) += ramstage_cache.c
ifneq ($(CONFIG_HAVE_ARCH_MEMSET),y) diff --git a/src/lib/ne2k.c b/src/lib/ne2k.c deleted file mode 100644 index b678d79..0000000 --- a/src/lib/ne2k.c +++ /dev/null @@ -1,458 +0,0 @@ -/* -ETHERBOOT - BOOTP/TFTP Bootstrap Program - -Author: Martin Renters - Date: May/94 - - This code is based heavily on David Greenman's if_ed.c driver - - Copyright (C) 1993-1994, David Greenman, Martin Renters. - This software may be used, modified, copied, distributed, and sold, in - both source and binary form provided that the above copyright and these - terms are retained. Under no circumstances are the authors responsible for - the proper functioning of this software, nor do the authors assume any - responsibility for damages incurred with its use. - -Multicast support added by Timothy Legge (timlegge@users.sourceforge.net) 09/28/2003 -Relocation support added by Ken Yap (ken_yap@users.sourceforge.net) 28/12/02 -3c503 support added by Bill Paul (wpaul@ctr.columbia.edu) on 11/15/94 -SMC8416 support added by Bill Paul (wpaul@ctr.columbia.edu) on 12/25/94 -3c503 PIO support added by Jim Hague (jim.hague@acm.org) on 2/17/98 -RX overrun by Klaus Espenlaub (espenlaub@informatik.uni-ulm.de) on 3/10/99 - parts taken from the Linux 8390 driver (by Donald Becker and Paul Gortmaker) -SMC8416 PIO support added by Andrew Bettison (andrewb@zip.com.au) on 4/3/02 - based on the Linux 8390 driver (by Donald Becker and Paul Gortmaker) - -(C) Rudolf Marek r.marek@assembler.cz Simplify for RTL8029, Add coreboot glue logic - -*/ - -#define ETH_ALEN 6 /* Size of Ethernet address */ -#define ETH_HLEN 14 /* Size of ethernet header */ -#define ETH_ZLEN 60 /* Minimum packet */ -#define ETH_FRAME_LEN 1514 /* Maximum packet */ -#define ETH_DATA_ALIGN 2 /* Amount needed to align the data after an ethernet header */ -#define ETH_MAX_MTU (ETH_FRAME_LEN-ETH_HLEN) - -#include "ns8390.h" -#include <ip_checksum.h> -#include <console/ne2k.h> -#include <arch/io.h> - -#define MEM_SIZE MEM_32768 -#define TX_START 64 -#define RX_START (64 + D8390_TXBUF_SIZE) - -static unsigned int get_count(unsigned int eth_nic_base) -{ - unsigned int ret; - outb(D8390_COMMAND_RD2 + D8390_COMMAND_PS1, - eth_nic_base + D8390_P0_COMMAND); - - ret = inb(eth_nic_base + 8 + 0) | (inb(eth_nic_base + 8 + 1) << 8); - - outb(D8390_COMMAND_RD2 + D8390_COMMAND_PS0, - eth_nic_base + D8390_P0_COMMAND); - return ret; -} - -static void set_count(unsigned int eth_nic_base, unsigned int what) -{ - outb(D8390_COMMAND_RD2 + D8390_COMMAND_PS1, - eth_nic_base + D8390_P0_COMMAND); - - outb(what & 0xff,eth_nic_base + 8); - outb((what >> 8) & 0xff,eth_nic_base + 8 + 1); - - outb(D8390_COMMAND_RD2 + D8390_COMMAND_PS0, - eth_nic_base + D8390_P0_COMMAND); -} - -static void eth_pio_write(unsigned char *src, unsigned int dst, unsigned int cnt, - unsigned int eth_nic_base) -{ - outb(D8390_COMMAND_RD2 | D8390_COMMAND_STA, eth_nic_base + D8390_P0_COMMAND); - outb(D8390_ISR_RDC, eth_nic_base + D8390_P0_ISR); - outb(cnt, eth_nic_base + D8390_P0_RBCR0); - outb(cnt >> 8, eth_nic_base + D8390_P0_RBCR1); - outb(dst, eth_nic_base + D8390_P0_RSAR0); - outb(dst >> 8, eth_nic_base + D8390_P0_RSAR1); - outb(D8390_COMMAND_RD1 | D8390_COMMAND_STA, eth_nic_base + D8390_P0_COMMAND); - - while (cnt--) { - outb(*(src++), eth_nic_base + NE_ASIC_OFFSET + NE_DATA); - } - /* - #warning "Add timeout" - */ - /* wait for operation finish */ - while ((inb(eth_nic_base + D8390_P0_ISR) & D8390_ISR_RDC) != D8390_ISR_RDC) - ; -} - -void ne2k_append_data(unsigned char *d, int len, unsigned int base) -{ - eth_pio_write(d, (TX_START << 8) + 42 + get_count(base), len, base); - set_count(base, get_count(base)+len); -} - -#ifdef __ROMCC__ - -void eth_pio_write_byte(int data, unsigned short dst, unsigned int eth_nic_base) -{ - outb(D8390_COMMAND_RD2 | D8390_COMMAND_STA, eth_nic_base + D8390_P0_COMMAND); - outb(D8390_ISR_RDC, eth_nic_base + D8390_P0_ISR); - outb(1, eth_nic_base + D8390_P0_RBCR0); - outb(0, eth_nic_base + D8390_P0_RBCR1); - outb(dst, eth_nic_base + D8390_P0_RSAR0); - outb(dst >> 8, eth_nic_base + D8390_P0_RSAR1); - outb(D8390_COMMAND_RD1 | D8390_COMMAND_STA, eth_nic_base + D8390_P0_COMMAND); - outb(data, eth_nic_base + NE_ASIC_OFFSET + NE_DATA); - - while ((inb(eth_nic_base + D8390_P0_ISR) & D8390_ISR_RDC) != D8390_ISR_RDC) - ; -} - -void ne2k_append_data_byte(int d, unsigned int base) -{ - eth_pio_write_byte(d, (TX_START << 8) + 42 + get_count(base), base); - set_count(base, get_count(base)+1); -} - -static unsigned char eth_pio_read_byte(unsigned int src, - unsigned int eth_nic_base) -{ - outb(D8390_COMMAND_RD2 | D8390_COMMAND_STA, eth_nic_base + D8390_P0_COMMAND); - outb(0, eth_nic_base + D8390_P0_RBCR0); - outb(1, eth_nic_base + D8390_P0_RBCR1); - outb(src, eth_nic_base + D8390_P0_RSAR0); - outb(src >> 8, eth_nic_base + D8390_P0_RSAR1); - outb(D8390_COMMAND_RD0 | D8390_COMMAND_STA, eth_nic_base + D8390_P0_COMMAND); - return inb(eth_nic_base + NE_ASIC_OFFSET + NE_DATA); -} - - -/* Variation of compute_ip_checksum which works on SRAM */ -unsigned long compute_ip_checksum_from_sram(unsigned short offset, unsigned short length, - unsigned int eth_nic_base) -{ - unsigned long sum; - unsigned long i; - /* In the most straight forward way possible, - * compute an ip style checksum. - */ - sum = 0; - for(i = 0; i < length; i++) { - unsigned long v; - v = eth_pio_read_byte((TX_START << 8)+i+offset, eth_nic_base); - if (i & 1) { - v <<= 8; - } - /* Add the new value */ - sum += v; - /* Wrap around the carry */ - if (sum > 0xFFFF) { - sum = (sum + (sum >> 16)) & 0xFFFF; - } - } - return (~((sum & 0xff) | (((sum >> 8) & 0xff) << 8) )) & 0xffff; -} - - -static void str2ip_load(const char *str, unsigned short offset, unsigned int eth_nic_base) -#else -static void str2ip(const char *str, unsigned char *ip) -#endif -{ - unsigned char c, i = 0; - int acc = 0; - - do { - c = str[i]; - if ((c >= '0') && (c <= '9')) { - acc *= 10; - acc += (c - '0'); - } else { -#ifdef __ROMCC__ - eth_pio_write_byte(acc, (TX_START << 8)+offset, eth_nic_base); - offset++; -#else - *ip++ = acc; -#endif - acc = 0; - } - i++; - } while (c != '\0'); -} - -#ifdef __ROMCC__ -static void str2mac_load(const char *str, unsigned short offset, unsigned int eth_nic_base) -#else -static void str2mac(const char *str, unsigned char *mac) -#endif -{ - unsigned char c, i = 0; - int acc = 0; - - do { - - c = str[i]; - if ((c >= '0') && (c <= '9')) { - acc *= 16; - acc += (c - '0'); - } else if ((c >= 'a') && (c <= 'f')) { - acc *= 16; - acc += ((c - 'a') + 10) ; - } else if ((c >= 'A') && (c <= 'F')) { - acc *= 16; - acc += ((c - 'A') + 10) ; - } else { -#ifdef __ROMCC__ - eth_pio_write_byte(acc, ((TX_START << 8)+offset), eth_nic_base); - offset++; -#else - *mac++ = acc; -#endif - acc = 0; - } - - i++; - } while (c != '\0'); -} - - -#ifndef __ROMCC__ -static void ns8390_tx_header(unsigned int eth_nic_base, int pktlen) { - unsigned short chksum; - unsigned char hdr[] = { -#else -static const unsigned char hdr[] = { -#endif - /* - * ETHERNET HDR - */ - - // destination macaddr - 0x02, 0x00, 0x00, 0x00, 0x00, 0x01, - /* source mac */ - 0x02, 0x00, 0x00, 0xC0, 0xFF, 0xEE, - /* ethtype (IP) */ - 0x08, 0x00, - /* - * IP HDR - */ - 0x45, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, - /* TTL, proto (UDP), chksum_hi, chksum_lo, IP0, IP1, IP2, IP3, */ - 0x40, 0x11, 0x0, 0x0, 0x7f, 0x0, 0x0, 0x1, - /* IP0, IP1, IP2, IP3 */ - 0xff, 0xff, 0xff, 0xff, - /* - * UDP HDR - */ - /* SRC PORT DST PORT (2bytes each), ulen, uchksum (must be zero or correct */ - 0x1a, 0x0b, 0x1a, 0x0a, 0x00, 0x9, 0x00, 0x00, - }; - -#ifndef __ROMCC__ - str2mac(CONFIG_CONSOLE_NE2K_DST_MAC, &hdr[0]); - str2ip(CONFIG_CONSOLE_NE2K_DST_IP, &hdr[30]); - str2ip(CONFIG_CONSOLE_NE2K_SRC_IP, &hdr[26]); - - /* zero checksum */ - hdr[24] = 0; - hdr[25] = 0; - - /* update IP packet len */ - hdr[16] = ((28 + pktlen) >> 8) & 0xff; - hdr[17] = (28 + pktlen) & 0xff; - - /* update UDP len */ - hdr[38] = (8 + pktlen) >> 8; - hdr[39] = 8 + pktlen; - - chksum = compute_ip_checksum(&hdr[14], 20); - - hdr[25] = chksum >> 8; - hdr[24] = chksum; - eth_pio_write(hdr, (TX_START << 8), sizeof(hdr), eth_nic_base); -} - - -#else - -/* ROMCC madness */ -static void ns8390_tx_header(unsigned int eth_nic_base, int pktlen) -{ - unsigned short chksum; - - eth_pio_write(hdr, (TX_START << 8), sizeof(hdr), eth_nic_base); - - str2mac_load(CONFIG_CONSOLE_NE2K_DST_MAC, 0, eth_nic_base); - - str2ip_load(CONFIG_CONSOLE_NE2K_DST_IP, 30, eth_nic_base); - str2ip_load(CONFIG_CONSOLE_NE2K_SRC_IP, 26, eth_nic_base); - /* zero checksum */ - eth_pio_write_byte(0, (TX_START << 8)+24, eth_nic_base); - eth_pio_write_byte(0, (TX_START << 8)+25, eth_nic_base); - - /* update IP packet len */ - eth_pio_write_byte(((28 + pktlen) >> 8) & 0xff, (TX_START << 8)+16, eth_nic_base); - eth_pio_write_byte( (28 + pktlen) & 0xff, (TX_START << 8)+17, eth_nic_base); - - /* update UDP len */ - eth_pio_write_byte((8 + pktlen) >> 8, (TX_START << 8)+38, eth_nic_base); - eth_pio_write_byte( 8 + pktlen, (TX_START << 8)+39, eth_nic_base); - - chksum = compute_ip_checksum_from_sram(14, 20, eth_nic_base); - - eth_pio_write_byte(chksum, (TX_START << 8)+24, eth_nic_base); - eth_pio_write_byte(chksum >> 8, (TX_START << 8)+25, eth_nic_base); -} - -#endif - -void ne2k_transmit(unsigned int eth_nic_base) { - unsigned int pktsize; - unsigned int len = get_count(eth_nic_base); - - // so place whole header inside chip buffer - ns8390_tx_header(eth_nic_base, len); - - // commit sending now - outb(D8390_COMMAND_PS0 | D8390_COMMAND_RD2 | D8390_COMMAND_STA, eth_nic_base + D8390_P0_COMMAND); - - outb(TX_START, eth_nic_base + D8390_P0_TPSR); - - pktsize = 42 + len; - if (pktsize < 64) - pktsize = 64; - - outb(pktsize, eth_nic_base + D8390_P0_TBCR0); - outb(pktsize >> 8, eth_nic_base + D8390_P0_TBCR1); - - outb(D8390_ISR_PTX, eth_nic_base + D8390_P0_ISR); - - outb(D8390_COMMAND_PS0 | D8390_COMMAND_TXP | D8390_COMMAND_RD2 | D8390_COMMAND_STA, eth_nic_base + D8390_P0_COMMAND); - - /* wait for operation finish */ - while ((inb(eth_nic_base + D8390_P0_ISR) & D8390_ISR_PTX) != D8390_ISR_PTX) ; - - set_count(eth_nic_base, 0); -} - -#ifdef __PRE_RAM__ - -static void ns8390_reset(unsigned int eth_nic_base) -{ - int i; - - outb(D8390_COMMAND_PS0 | D8390_COMMAND_RD2 | - D8390_COMMAND_STP, eth_nic_base + D8390_P0_COMMAND); - - outb(0x48, eth_nic_base + D8390_P0_DCR); - outb(0, eth_nic_base + D8390_P0_RBCR0); - outb(0, eth_nic_base + D8390_P0_RBCR1); - outb(0x20, eth_nic_base + D8390_P0_RCR); - outb(2, eth_nic_base + D8390_P0_TCR); - outb(TX_START, eth_nic_base + D8390_P0_TPSR); - outb(RX_START, eth_nic_base + D8390_P0_PSTART); - outb(MEM_SIZE, eth_nic_base + D8390_P0_PSTOP); - outb(MEM_SIZE - 1, eth_nic_base + D8390_P0_BOUND); - outb(0xFF, eth_nic_base + D8390_P0_ISR); - outb(0, eth_nic_base + D8390_P0_IMR); - - outb(D8390_COMMAND_PS1 | - D8390_COMMAND_RD2 | D8390_COMMAND_STP, - eth_nic_base + D8390_P0_COMMAND); - - for (i = 0; i < ETH_ALEN; i++) - outb(0x0C, eth_nic_base + D8390_P1_PAR0 + i); - - for (i = 0; i < ETH_ALEN; i++) - outb(0xFF, eth_nic_base + D8390_P1_MAR0 + i); - - outb(RX_START, eth_nic_base + D8390_P1_CURR); - outb(D8390_COMMAND_PS0 | - D8390_COMMAND_RD2 | D8390_COMMAND_STA, - eth_nic_base + D8390_P0_COMMAND); - outb(0xFF, eth_nic_base + D8390_P0_ISR); - outb(0, eth_nic_base + D8390_P0_TCR); - outb(4, eth_nic_base + D8390_P0_RCR); - set_count(eth_nic_base, 0); -} - - -int ne2k_init(unsigned int eth_nic_base) { - - device_t dev; - unsigned char c; - - /* Power management controller */ - dev = pci_locate_device(PCI_ID(0x10ec, - 0x8029), 0); - - if (dev == PCI_DEV_INVALID) - return 0; - - pci_write_config32(dev, 0x10, eth_nic_base | 1 ); - pci_write_config8(dev, 0x4, 0x1); - - c = inb(eth_nic_base + NE_ASIC_OFFSET + NE_RESET); - outb(c, eth_nic_base + NE_ASIC_OFFSET + NE_RESET); - - (void) inb(0x84); - - outb(D8390_COMMAND_STP | D8390_COMMAND_RD2, eth_nic_base + D8390_P0_COMMAND); - outb(D8390_RCR_MON, eth_nic_base + D8390_P0_RCR); - - outb(D8390_DCR_FT1 | D8390_DCR_LS, eth_nic_base + D8390_P0_DCR); - outb(MEM_8192, eth_nic_base + D8390_P0_PSTART); - outb(MEM_16384, eth_nic_base + D8390_P0_PSTOP); - - ns8390_reset(eth_nic_base); - return 1; -} - -#else - -#include <delay.h> -#include <stdlib.h> -#include <string.h> -#include <arch/io.h> - -#include <console/console.h> -#include <device/device.h> -#include <device/pci.h> -#include <device/pci_ids.h> -#include <device/pci_ops.h> - -static void read_resources(struct device *dev) -{ - struct resource *res; - - res = new_resource(dev, PCI_BASE_ADDRESS_0); - res->base = CONFIG_CONSOLE_NE2K_IO_PORT; - res->size = 32; - res->align = 5; - res->gran = 5; - res->limit = res->base + res->size - 1; - res->flags = IORESOURCE_IO | IORESOURCE_FIXED | IORESOURCE_STORED | - IORESOURCE_ASSIGNED; - return; -} - -static struct device_operations ne2k_ops = { - .read_resources = read_resources, - .set_resources = pci_dev_set_resources, - .enable_resources = pci_dev_enable_resources, - .init = 0, - .scan_bus = 0, -}; - -static const struct pci_driver ne2k_driver __pci_driver = { - .ops = &ne2k_ops, - .vendor = 0x10ec, - .device = 0x8029, -}; - -#endif diff --git a/src/lib/ns8390.h b/src/lib/ns8390.h deleted file mode 100644 index eeffe45..0000000 --- a/src/lib/ns8390.h +++ /dev/null @@ -1,110 +0,0 @@ -/************************************************************************** -ETHERBOOT - BOOTP/TFTP Bootstrap Program - -Author: Martin Renters - Date: Jun/94 - -**************************************************************************/ - -//FILE_LICENCE ( BSD2 ); - -#define VENDOR_NONE 0 -#define VENDOR_WD 1 -#define VENDOR_NOVELL 2 -#define VENDOR_3COM 3 - -#define FLAG_PIO 0x01 -#define FLAG_16BIT 0x02 -#define FLAG_790 0x04 - -#define MEM_8192 32 -#define MEM_16384 64 -#define MEM_32768 128 - -#define ISA_MAX_ADDR 0x400 - -/************************************************************************** -NE1000/2000 definitions -**************************************************************************/ -#define NE_ASIC_OFFSET 0x10 -#define NE_RESET 0x0F /* Used to reset card */ -#define NE_DATA 0x00 /* Used to read/write NIC mem */ - -#define COMPEX_RL2000_TRIES 200 - -/************************************************************************** -8390 Register Definitions -**************************************************************************/ -#define D8390_P0_COMMAND 0x00 -#define D8390_P0_PSTART 0x01 -#define D8390_P0_PSTOP 0x02 -#define D8390_P0_BOUND 0x03 -#define D8390_P0_TSR 0x04 -#define D8390_P0_TPSR 0x04 -#define D8390_P0_TBCR0 0x05 -#define D8390_P0_TBCR1 0x06 -#define D8390_P0_ISR 0x07 -#define D8390_P0_RSAR0 0x08 -#define D8390_P0_RSAR1 0x09 -#define D8390_P0_RBCR0 0x0A -#define D8390_P0_RBCR1 0x0B -#define D8390_P0_RSR 0x0C -#define D8390_P0_RCR 0x0C -#define D8390_P0_TCR 0x0D -#define D8390_P0_DCR 0x0E -#define D8390_P0_IMR 0x0F -#define D8390_P1_COMMAND 0x00 -#define D8390_P1_PAR0 0x01 -#define D8390_P1_PAR1 0x02 -#define D8390_P1_PAR2 0x03 -#define D8390_P1_PAR3 0x04 -#define D8390_P1_PAR4 0x05 -#define D8390_P1_PAR5 0x06 -#define D8390_P1_CURR 0x07 -#define D8390_P1_MAR0 0x08 - -#define D8390_COMMAND_PS0 0x0 /* Page 0 select */ -#define D8390_COMMAND_PS1 0x40 /* Page 1 select */ -#define D8390_COMMAND_PS2 0x80 /* Page 2 select */ -#define D8390_COMMAND_RD2 0x20 /* Remote DMA control */ -#define D8390_COMMAND_RD1 0x10 -#define D8390_COMMAND_RD0 0x08 -#define D8390_COMMAND_TXP 0x04 /* transmit packet */ -#define D8390_COMMAND_STA 0x02 /* start */ -#define D8390_COMMAND_STP 0x01 /* stop */ - -#define D8390_RCR_MON 0x20 /* monitor mode */ - -#define D8390_DCR_FT1 0x40 -#define D8390_DCR_LS 0x08 /* Loopback select */ -#define D8390_DCR_WTS 0x01 /* Word transfer select */ - -#define D8390_ISR_PRX 0x01 /* successful recv */ -#define D8390_ISR_PTX 0x02 /* successful xmit */ -#define D8390_ISR_RXE 0x04 /* receive error */ -#define D8390_ISR_TXE 0x08 /* transmit error */ -#define D8390_ISR_OVW 0x10 /* Overflow */ -#define D8390_ISR_CNT 0x20 /* Counter overflow */ -#define D8390_ISR_RDC 0x40 /* Remote DMA complete */ -#define D8390_ISR_RST 0x80 /* reset */ - -#define D8390_RSTAT_PRX 0x01 /* successful recv */ -#define D8390_RSTAT_CRC 0x02 /* CRC error */ -#define D8390_RSTAT_FAE 0x04 /* Frame alignment error */ -#define D8390_RSTAT_OVER 0x08 /* FIFO overrun */ - -#define D8390_TXBUF_SIZE 6 -#define D8390_RXBUF_END 32 -#define D8390_PAGE_SIZE 256 - -struct ringbuffer { - unsigned char status; - unsigned char next; - unsigned short len; -}; -/* - * Local variables: - * c-basic-offset: 8 - * End: - */ -
