Michał Żygowski has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/59520 )
Change subject: security/intel/txt: Fix GETSEC checks in romstage ......................................................................
IA32_FEATURE_CONTROL does not need to be checked by BIOS, in fact these bits are needed only by SENTER and SINIT ACM. ACM ENTERACCS does not check these bits according to Intel SDM. Also noticed that the lock bit of IA32_FEATURE_CONTROL cannot be cleared by issuing neither global reset nor full reset on Sandybridge/Ivybridge platforms which results in a reset loop. However, check the IA32_FEATURE_CONTROL SENTER bits in ramstage where the register is properly set on all cores already.
TEST=Run ACM SCLEAN on Dell OptiPlex 9010 with i7-3770/Q77
Signed-off-by: Michał Żygowski michal.zygowski@3mdeb.com Change-Id: Ie9103041498f557b85019a56e1252090a4fcd0c9 --- M src/security/intel/txt/getsec.c M src/security/intel/txt/romstage.c 2 files changed, 31 insertions(+), 11 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/20/59520/1
diff --git a/src/security/intel/txt/getsec.c b/src/security/intel/txt/getsec.c index e85de7d..ca6d9a3 100644 --- a/src/security/intel/txt/getsec.c +++ b/src/security/intel/txt/getsec.c @@ -9,9 +9,11 @@ #include <cpu/x86/mp.h> #include <cpu/x86/msr.h> #include <types.h> +#include <rules.h>
#include "txt_register.h" #include "txt_getsec.h" +#include "txt.h"
/** * Check for SMX support and enable it if possible. @@ -24,16 +26,26 @@ /* * Check if SMX and VMX is supported by CPU. */ - if (!(ecx & CPUID_SMX) || !(ecx & CPUID_VMX)) + if (!(ecx & CPUID_SMX) || !(ecx & CPUID_VMX)) { + printk(BIOS_ERR, "SMX/VMX not supported by CPU\n"); return false; - + } /* - * Check if SMX, VMX and GetSec instructions haven't been disabled. + * This requirement is not needed for ENTERACCS, but for SENTER (see SDM). + * Skip check in romstage because IA32_FEATURE_CONTROL cannot be unlocked + * even after a global reset e.g. on Sandy/IvyBridge. However the register + * gets set properly in ramstage where all CPUs are already initialized. */ - msr_t msr = rdmsr(IA32_FEATURE_CONTROL); - if ((msr.lo & 0xff06) != 0xff06) - return false; - + if (!ENV_ROMSTAGE_OR_BEFORE) { + /* + * Check if SMX, VMX and GetSec instructions haven't been disabled. + */ + msr_t msr = rdmsr(IA32_FEATURE_CONTROL); + if ((msr.lo & 0xff06) != 0xff06) { + printk(BIOS_ERR, "GETSEC not enabled in IA32_FEATURE_CONTROL MSR\n"); + return false; + } + } /* * Enable SMX. Required to execute GetSec instruction. * Chapter 2.2.4.3 diff --git a/src/security/intel/txt/romstage.c b/src/security/intel/txt/romstage.c index f4e099b..009f3cb 100644 --- a/src/security/intel/txt/romstage.c +++ b/src/security/intel/txt/romstage.c @@ -5,6 +5,7 @@ #include <cf9_reset.h> #include <console/console.h> #include <cpu/intel/common/common.h> +#include <cpu/x86/cr.h> #include <cpu/x86/msr.h> #include <southbridge/intel/common/pmbase.h> #include <timer.h> @@ -83,14 +84,21 @@ void intel_txt_romstage_init(void) { /* Bail early if the CPU doesn't support TXT */ - if (!is_txt_cpu()) + if (!is_txt_cpu()) { + printk(BIOS_ERR, "TEE-TXT: CPU not TXT capable.\n"); return; + }
- /* We need to use GETSEC here, so enable it */ - enable_getsec_or_reset(); + /* + * We need to use GETSEC here, so enable it. + * CR4_SMXE is all we need to be able to call GETSEC[CAPABILTIES]. + */ + write_cr4(read_cr4() | CR4_SMXE);
- if (!is_txt_chipset()) + if (!is_txt_chipset()) { + printk(BIOS_ERR, "TEE-TXT: Chipset not TXT capable.\n"); return; + }
const uint8_t txt_ests = read8((void *)TXT_ESTS);
