Timothy Pearson (tpearson@raptorengineeringinc.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/14242
commit 6b300cd77f52778e12cbe54abb79607ca44997f6 Author: Timothy Pearson tpearson@raptorengineeringinc.com Date: Mon Apr 4 14:31:52 2016 -0500
mb/asus/kgpe-d16|kcma-d8: Add ehci_async_data_cache CMOS option
Change-Id: I76a1047742369416b90e5c8bf307f85c02ae9bbb Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- src/mainboard/asus/kcma-d8/cmos.default | 1 + src/mainboard/asus/kcma-d8/cmos.layout | 5 +++-- src/mainboard/asus/kgpe-d16/cmos.default | 1 + src/mainboard/asus/kgpe-d16/cmos.layout | 5 +++-- 4 files changed, 8 insertions(+), 4 deletions(-)
diff --git a/src/mainboard/asus/kcma-d8/cmos.default b/src/mainboard/asus/kcma-d8/cmos.default index c8edd97..ba9ba3b 100644 --- a/src/mainboard/asus/kcma-d8/cmos.default +++ b/src/mainboard/asus/kcma-d8/cmos.default @@ -24,6 +24,7 @@ maximum_p_state_limit = 0xf probe_filter = Auto l3_cache_partitioning = Disable gart = Enable +ehci_async_data_cache = Enable experimental_memory_speed_boost = Disable power_on_after_fail = On boot_option = Fallback diff --git a/src/mainboard/asus/kcma-d8/cmos.layout b/src/mainboard/asus/kcma-d8/cmos.layout index 9bda1f6..14e3c9b 100644 --- a/src/mainboard/asus/kcma-d8/cmos.layout +++ b/src/mainboard/asus/kcma-d8/cmos.layout @@ -48,8 +48,9 @@ entries 476 1 e 1 l3_cache_partitioning 478 1 e 1 iommu 479 1 e 1 cpu_core_boost -480 1 e 1 experimental_memory_speed_boost -481 1 r 0 allow_spd_nvram_cache_restore +480 1 e 2 ehci_async_data_cache +481 1 e 1 experimental_memory_speed_boost +482 1 r 0 allow_spd_nvram_cache_restore 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers diff --git a/src/mainboard/asus/kgpe-d16/cmos.default b/src/mainboard/asus/kgpe-d16/cmos.default index 0e7afb3..481022c 100644 --- a/src/mainboard/asus/kgpe-d16/cmos.default +++ b/src/mainboard/asus/kgpe-d16/cmos.default @@ -25,6 +25,7 @@ probe_filter = Auto l3_cache_partitioning = Disable ieee1394_controller = Enable gart = Enable +ehci_async_data_cache = Enable experimental_memory_speed_boost = Disable power_on_after_fail = On boot_option = Fallback diff --git a/src/mainboard/asus/kgpe-d16/cmos.layout b/src/mainboard/asus/kgpe-d16/cmos.layout index 075388e..9e48910 100644 --- a/src/mainboard/asus/kgpe-d16/cmos.layout +++ b/src/mainboard/asus/kgpe-d16/cmos.layout @@ -49,8 +49,9 @@ entries 477 1 e 1 ieee1394_controller 478 1 e 1 iommu 479 1 e 1 cpu_core_boost -480 1 e 1 experimental_memory_speed_boost -481 1 r 0 allow_spd_nvram_cache_restore +480 1 e 2 ehci_async_data_cache +481 1 e 1 experimental_memory_speed_boost +482 1 r 0 allow_spd_nvram_cache_restore 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers
