Attention is currently required from: Dinesh Gehlot.
Julius Werner has posted comments on this change by Dinesh Gehlot. ( https://review.coreboot.org/c/coreboot/+/83864?usp=email )
Change subject: src: Log boot info before cse sync ......................................................................
Patch Set 1:
File src/soc/intel/common/block/cse/cse_lite.c:
https://review.coreboot.org/c/coreboot/+/83864/comment/0fc0065a_e60ab91b?usp... : PS1, Line 1434: elog_add_vboot_info(); You can't just remove these from platform-independent files and move them into an Intel-only file, you're gonna break all other platforms.
If you want to move these before CSE sync, it would probably be best to leave the code where it is and change the boot state hook to some event that occurs before CSE sync (e.g. `BS_PRE_DEVICE, BS_ON_ENTRY`).
